Vista - Showing Com Ports and Bluetooth Problems
Old 04-29-2007   #1 (permalink)
Rick DUncan
How can I view the current com ports on Vista? I am trying to restore my
bluethooth connection to a LifeDrive PDA. It was working but now it says
that another application is using that com port, so I go and create another
and then it says that the com port is being used in another application and
it will open the port when it is free. I've added up to a com 9 but none of
them work.
Help me o wise ones.
Old 06-20-2007   #2 (permalink)
John
RE: Showing Com Ports and Bluetooth Problems
I'm having similar issues with my PDA and a GPS. Any resolution yet?
> them work.
Com ports are always busy when I try to sync with Bluetooth Vista hardware & devices
Bluetooth not showing mobile centre on phone Vista installation & setup
Available Bluetooth Serial Ports in Vista .NET General
Bluetooth and COM Ports Vista networking & sharing
Problem with USB-ports and Bluetooth Vista hardware & devices
