| | Vista - vista sound driver problem |
| 05-04-2007 | #1 |
| | vista sound driver problem every time i shut down vista the sound drivers are changed , i then reinstall the latest realtech drivers but when i shut down my system they revert to ones that do not work . any way to stop vista changing the drivers ? |
| My System Specs |
| 05-04-2007 | #2 |
| | RE: vista sound driver problem the sound device is onboard my motherboard , the board is the asus a8v-vm se .. it uses a realtech driver which keeps getting replace , please help as it is driving my crazy ![]() "russ_will" wrote: > every time i shut down vista the sound drivers are changed , i then reinstall > the latest realtech drivers but when i shut down my system they revert to > ones that do not work . any way to stop vista changing the drivers ? |
| My System Specs |
| 05-05-2007 | #3 |
| | Re: vista sound driver problem Specifically, what is the sound device's name in Device Manager, under Sound, video and game controllers (when the driver from Realtek is installed)? Are there files from Realtek in C:\Program Files\Realtek\InstallShield? "russ_will" <russwill@discussions.microsoft.com> wrote in message news:0AD93DF0-D6F6-45CB-9C59-95D830D241FB@microsoft.com... > the sound device is onboard my motherboard , the board is the asus a8v-vm > se > . it uses a realtech driver which keeps getting replace , please help as > it > is driving my crazy ![]() > > "russ_will" wrote: > >> every time i shut down vista the sound drivers are changed , i then >> reinstall >> the latest realtech drivers but when i shut down my system they revert to >> ones that do not work . any way to stop vista changing the drivers ? |
| My System Specs |
| 05-05-2007 | #4 |
| | Re: vista sound driver problem it says in device manager = realtec high definition audio , i am using the drivers fron the realtech website (version 1.66) . audion chip is the realtech alc660 6-channel codec , it installs well but changes to just high def audion for some reason if shutdown for longer than a few min "dean-dean" wrote: > Specifically, what is the sound device's name in Device Manager, under > Sound, video and game controllers (when the driver from Realtek is > installed)? Are there files from Realtek in C:\Program > Files\Realtek\InstallShield? > > > "russ_will" <russwill@discussions.microsoft.com> wrote in message > news:0AD93DF0-D6F6-45CB-9C59-95D830D241FB@microsoft.com... > > the sound device is onboard my motherboard , the board is the asus a8v-vm > > se > > . it uses a realtech driver which keeps getting replace , please help as > > it > > is driving my crazy ![]() > > > > "russ_will" wrote: > > > >> every time i shut down vista the sound drivers are changed , i then > >> reinstall > >> the latest realtech drivers but when i shut down my system they revert to > >> ones that do not work . any way to stop vista changing the drivers ? > > |
| My System Specs |
| 05-05-2007 | #5 |
| | Re: vista sound driver problem Try this (you should have files in C:\Program Files\Realtek\InstallShield, from the Realtek installation): First, allow Vista to change your audio driver to the generic High Definition driver (the one that doesn't work). On your keyboard, press the Windows key + R. In the Run box, type msconfig On the Startup tab of System Configuration, if there are any files from Realtek Semiconductor, remove the checkmark for those, such as RtHDVCpl.exe (there may be others). (Apply, OK) and restart. (Tell System Configuration not to show you it's message or run again when you see that prompt after re-booting). Note: the appropriate startup item(s) will be re-entered automatically when the new driver from Realtek is installed. Then, in Device Manager, double-click the generic High Definition driver, under "Sound, video and game controllers", and, on the Driver tab, choose Update Driver. Then choose "Browse my computer for driver software." Under "Search for driver software in this location", Browse to C:\Program Files\Realtek\InstallShield. Click OK once you've found that folder, then click Next... "russ_will" <russwill@discussions.microsoft.com> wrote in message news:7C7B3966-0490-4652-802E-1CB869F26D69@microsoft.com... > it says in device manager = realtec high definition audio , i am using the > drivers fron the realtech website (version 1.66) . audion chip is the > realtech alc660 6-channel codec , it installs well but changes to just > high > def audion for some reason if shutdown for longer than a few min > > "dean-dean" wrote: > >> Specifically, what is the sound device's name in Device Manager, under >> Sound, video and game controllers (when the driver from Realtek is >> installed)? Are there files from Realtek in C:\Program >> Files\Realtek\InstallShield? >> >> >> "russ_will" <russwill@discussions.microsoft.com> wrote in message >> news:0AD93DF0-D6F6-45CB-9C59-95D830D241FB@microsoft.com... >> > the sound device is onboard my motherboard , the board is the asus >> > a8v-vm >> > se >> > . it uses a realtech driver which keeps getting replace , please help >> > as >> > it >> > is driving my crazy ![]() >> > >> > "russ_will" wrote: >> > >> >> every time i shut down vista the sound drivers are changed , i then >> >> reinstall >> >> the latest realtech drivers but when i shut down my system they revert >> >> to >> >> ones that do not work . any way to stop vista changing the drivers ? >> >> |
| My System Specs |
| 05-05-2007 | #6 |
| | Re: vista sound driver problem tried it , not sure why but it did not work . wish i got xp now as vistais to buggy for my liking "dean-dean" wrote: > Try this (you should have files in C:\Program Files\Realtek\InstallShield, > from the Realtek installation): > > First, allow Vista to change your audio driver to the generic High > Definition driver (the one that doesn't work). On your keyboard, press the > Windows key + R. In the Run box, type > > msconfig > > On the Startup tab of System Configuration, if there are any files from > Realtek Semiconductor, remove the checkmark for those, such as RtHDVCpl.exe > (there may be others). (Apply, OK) and restart. (Tell System Configuration > not to show you it's message or run again when you see that prompt after > re-booting). Note: the appropriate startup item(s) will be re-entered > automatically when the new driver from Realtek is installed. > > Then, in Device Manager, double-click the generic High Definition driver, > under "Sound, video and game controllers", and, on the Driver tab, choose > Update Driver. Then choose "Browse my computer for driver software." Under > "Search for driver software in this location", Browse to C:\Program > Files\Realtek\InstallShield. Click OK once you've found that folder, then > click Next... > > "russ_will" <russwill@discussions.microsoft.com> wrote in message > news:7C7B3966-0490-4652-802E-1CB869F26D69@microsoft.com... > > it says in device manager = realtec high definition audio , i am using the > > drivers fron the realtech website (version 1.66) . audion chip is the > > realtech alc660 6-channel codec , it installs well but changes to just > > high > > def audion for some reason if shutdown for longer than a few min > > > > "dean-dean" wrote: > > > >> Specifically, what is the sound device's name in Device Manager, under > >> Sound, video and game controllers (when the driver from Realtek is > >> installed)? Are there files from Realtek in C:\Program > >> Files\Realtek\InstallShield? > >> > >> > >> "russ_will" <russwill@discussions.microsoft.com> wrote in message > >> news:0AD93DF0-D6F6-45CB-9C59-95D830D241FB@microsoft.com... > >> > the sound device is onboard my motherboard , the board is the asus > >> > a8v-vm > >> > se > >> > . it uses a realtech driver which keeps getting replace , please help > >> > as > >> > it > >> > is driving my crazy ![]() > >> > > >> > "russ_will" wrote: > >> > > >> >> every time i shut down vista the sound drivers are changed , i then > >> >> reinstall > >> >> the latest realtech drivers but when i shut down my system they revert > >> >> to > >> >> ones that do not work . any way to stop vista changing the drivers ? > >> > >> > > |
| My System Specs |
| 05-05-2007 | #7 |
| | Re: vista sound driver problem Sorry to hear that it didn't work. The only thing I can think of is to try the setup file from Realtek again. Right-click on the .exe file that starts the installation, and choose Properties. If it is blocked on the General tab, click on the Unblock button (Apply, OK). Then right-click on the file again, and choose Run as Administrator. "russ_will" <russwill@discussions.microsoft.com> wrote in message news:7BDB80C5-B95D-4AB4-ADA6-68A7DB0DB0F3@microsoft.com... > tried it , not sure why but it did not work . wish i got xp now as> vista > is to buggy for my liking > > "dean-dean" wrote: > >> Try this (you should have files in C:\Program >> Files\Realtek\InstallShield, >> from the Realtek installation): >> >> First, allow Vista to change your audio driver to the generic High >> Definition driver (the one that doesn't work). On your keyboard, press >> the >> Windows key + R. In the Run box, type >> >> msconfig >> >> On the Startup tab of System Configuration, if there are any files from >> Realtek Semiconductor, remove the checkmark for those, such as >> RtHDVCpl.exe >> (there may be others). (Apply, OK) and restart. (Tell System >> Configuration >> not to show you it's message or run again when you see that prompt after >> re-booting). Note: the appropriate startup item(s) will be re-entered >> automatically when the new driver from Realtek is installed. >> >> Then, in Device Manager, double-click the generic High Definition driver, >> under "Sound, video and game controllers", and, on the Driver tab, choose >> Update Driver. Then choose "Browse my computer for driver software." >> Under >> "Search for driver software in this location", Browse to C:\Program >> Files\Realtek\InstallShield. Click OK once you've found that folder, >> then >> click Next... >> >> "russ_will" <russwill@discussions.microsoft.com> wrote in message >> news:7C7B3966-0490-4652-802E-1CB869F26D69@microsoft.com... >> > it says in device manager = realtec high definition audio , i am using >> > the >> > drivers fron the realtech website (version 1.66) . audion chip is the >> > realtech alc660 6-channel codec , it installs well but changes to just >> > high >> > def audion for some reason if shutdown for longer than a few min >> > >> > "dean-dean" wrote: >> > >> >> Specifically, what is the sound device's name in Device Manager, under >> >> Sound, video and game controllers (when the driver from Realtek is >> >> installed)? Are there files from Realtek in C:\Program >> >> Files\Realtek\InstallShield? >> >> >> >> >> >> "russ_will" <russwill@discussions.microsoft.com> wrote in message >> >> news:0AD93DF0-D6F6-45CB-9C59-95D830D241FB@microsoft.com... >> >> > the sound device is onboard my motherboard , the board is the asus >> >> > a8v-vm >> >> > se >> >> > . it uses a realtech driver which keeps getting replace , please >> >> > help >> >> > as >> >> > it >> >> > is driving my crazy ![]() >> >> > >> >> > "russ_will" wrote: >> >> > >> >> >> every time i shut down vista the sound drivers are changed , i then >> >> >> reinstall >> >> >> the latest realtech drivers but when i shut down my system they >> >> >> revert >> >> >> to >> >> >> ones that do not work . any way to stop vista changing the drivers >> >> >> ? >> >> >> >> >> >> |
| My System Specs |
| 05-05-2007 | #8 |
| | Re: vista sound driver problem i have been building my own pc's since 98 , i have never had a problem like this before . i have tried everything i can think of but nothing works , wish i had kept my old system with xp on ![]() "dean-dean" wrote: > Sorry to hear that it didn't work. The only thing I can think of is to try > the setup file from Realtek again. Right-click on the .exe file that > starts the installation, and choose Properties. If it is blocked on the > General tab, click on the Unblock button (Apply, OK). Then right-click on > the file again, and choose Run as Administrator. > > "russ_will" <russwill@discussions.microsoft.com> wrote in message > news:7BDB80C5-B95D-4AB4-ADA6-68A7DB0DB0F3@microsoft.com... > > tried it , not sure why but it did not work . wish i got xp now as> > vista > > is to buggy for my liking > > > > "dean-dean" wrote: > > > >> Try this (you should have files in C:\Program > >> Files\Realtek\InstallShield, > >> from the Realtek installation): > >> > >> First, allow Vista to change your audio driver to the generic High > >> Definition driver (the one that doesn't work). On your keyboard, press > >> the > >> Windows key + R. In the Run box, type > >> > >> msconfig > >> > >> On the Startup tab of System Configuration, if there are any files from > >> Realtek Semiconductor, remove the checkmark for those, such as > >> RtHDVCpl.exe > >> (there may be others). (Apply, OK) and restart. (Tell System > >> Configuration > >> not to show you it's message or run again when you see that prompt after > >> re-booting). Note: the appropriate startup item(s) will be re-entered > >> automatically when the new driver from Realtek is installed. > >> > >> Then, in Device Manager, double-click the generic High Definition driver, > >> under "Sound, video and game controllers", and, on the Driver tab, choose > >> Update Driver. Then choose "Browse my computer for driver software." > >> Under > >> "Search for driver software in this location", Browse to C:\Program > >> Files\Realtek\InstallShield. Click OK once you've found that folder, > >> then > >> click Next... > >> > >> "russ_will" <russwill@discussions.microsoft.com> wrote in message > >> news:7C7B3966-0490-4652-802E-1CB869F26D69@microsoft.com... > >> > it says in device manager = realtec high definition audio , i am using > >> > the > >> > drivers fron the realtech website (version 1.66) . audion chip is the > >> > realtech alc660 6-channel codec , it installs well but changes to just > >> > high > >> > def audion for some reason if shutdown for longer than a few min > >> > > >> > "dean-dean" wrote: > >> > > >> >> Specifically, what is the sound device's name in Device Manager, under > >> >> Sound, video and game controllers (when the driver from Realtek is > >> >> installed)? Are there files from Realtek in C:\Program > >> >> Files\Realtek\InstallShield? > >> >> > >> >> > >> >> "russ_will" <russwill@discussions.microsoft.com> wrote in message > >> >> news:0AD93DF0-D6F6-45CB-9C59-95D830D241FB@microsoft.com... > >> >> > the sound device is onboard my motherboard , the board is the asus > >> >> > a8v-vm > >> >> > se > >> >> > . it uses a realtech driver which keeps getting replace , please > >> >> > help > >> >> > as > >> >> > it > >> >> > is driving my crazy ![]() > >> >> > > >> >> > "russ_will" wrote: > >> >> > > >> >> >> every time i shut down vista the sound drivers are changed , i then > >> >> >> reinstall > >> >> >> the latest realtech drivers but when i shut down my system they > >> >> >> revert > >> >> >> to > >> >> >> ones that do not work . any way to stop vista changing the drivers > >> >> >> ? > >> >> > >> >> > >> > >> > > |
| My System Specs |
| 05-05-2007 | #9 |
| | Re: vista sound driver problem This is a puzzle. I have the same built-in soundcard that you have, and have not had this problem. Realtek has two different downloads for Vista's driver (one, an .exe installation file, the other a .zip). Have you tried both? Both should be "unblocked". The .zip file installation, once the files are extracted, uses Setup.exe, I believe, to begin the installation. Either .exe file should be Run as Administrator. Or you could try turning UAC off, if it isn't already (and turn it back on after the installation). Another work-around: In Device Manager, double-click the generic High Definition driver, and, on the Driver tab, choose Update Driver. Then choose "Browse my computer for driver software." This time, instead of "Search for driver software in this location", try "Let me pick from a list of device drivers on my computer." Then choose Have Disk. Browse to C:\Program Files\Realtek\InstallShield... "russ_will" <russwill@discussions.microsoft.com> wrote in message news:8B8E065D-CA23-4B40-96BF-28B52ED6A250@microsoft.com... >i have been building my own pc's since 98 , i have never had a problem like > this before . i have tried everything i can think of but nothing works , > wish i had kept my old system with xp on ![]() > > "dean-dean" wrote: > >> Sorry to hear that it didn't work. The only thing I can think of is to >> try >> the setup file from Realtek again. Right-click on the .exe file that >> starts the installation, and choose Properties. If it is blocked on the >> General tab, click on the Unblock button (Apply, OK). Then right-click >> on >> the file again, and choose Run as Administrator. >> >> "russ_will" <russwill@discussions.microsoft.com> wrote in message >> news:7BDB80C5-B95D-4AB4-ADA6-68A7DB0DB0F3@microsoft.com... >> > tried it , not sure why but it did not work . wish i got xp now as>> > vista >> > is to buggy for my liking >> > >> > "dean-dean" wrote: >> > >> >> Try this (you should have files in C:\Program >> >> Files\Realtek\InstallShield, >> >> from the Realtek installation): >> >> >> >> First, allow Vista to change your audio driver to the generic High >> >> Definition driver (the one that doesn't work). On your keyboard, >> >> press >> >> the >> >> Windows key + R. In the Run box, type >> >> >> >> msconfig >> >> >> >> On the Startup tab of System Configuration, if there are any files >> >> from >> >> Realtek Semiconductor, remove the checkmark for those, such as >> >> RtHDVCpl.exe >> >> (there may be others). (Apply, OK) and restart. (Tell System >> >> Configuration >> >> not to show you it's message or run again when you see that prompt >> >> after >> >> re-booting). Note: the appropriate startup item(s) will be re-entered >> >> automatically when the new driver from Realtek is installed. >> >> >> >> Then, in Device Manager, double-click the generic High Definition >> >> driver, >> >> under "Sound, video and game controllers", and, on the Driver tab, >> >> choose >> >> Update Driver. Then choose "Browse my computer for driver software." >> >> Under >> >> "Search for driver software in this location", Browse to C:\Program >> >> Files\Realtek\InstallShield. Click OK once you've found that folder, >> >> then >> >> click Next... >> >> >> >> "russ_will" <russwill@discussions.microsoft.com> wrote in message >> >> news:7C7B3966-0490-4652-802E-1CB869F26D69@microsoft.com... >> >> > it says in device manager = realtec high definition audio , i am >> >> > using >> >> > the >> >> > drivers fron the realtech website (version 1.66) . audion chip is >> >> > the >> >> > realtech alc660 6-channel codec , it installs well but changes to >> >> > just >> >> > high >> >> > def audion for some reason if shutdown for longer than a few min >> >> > >> >> > "dean-dean" wrote: >> >> > >> >> >> Specifically, what is the sound device's name in Device Manager, >> >> >> under >> >> >> Sound, video and game controllers (when the driver from Realtek is >> >> >> installed)? Are there files from Realtek in C:\Program >> >> >> Files\Realtek\InstallShield? >> >> >> >> >> >> >> >> >> "russ_will" <russwill@discussions.microsoft.com> wrote in message >> >> >> news:0AD93DF0-D6F6-45CB-9C59-95D830D241FB@microsoft.com... >> >> >> > the sound device is onboard my motherboard , the board is the >> >> >> > asus >> >> >> > a8v-vm >> >> >> > se >> >> >> > . it uses a realtech driver which keeps getting replace , please >> >> >> > help >> >> >> > as >> >> >> > it >> >> >> > is driving my crazy ![]() >> >> >> > >> >> >> > "russ_will" wrote: >> >> >> > >> >> >> >> every time i shut down vista the sound drivers are changed , i >> >> >> >> then >> >> >> >> reinstall >> >> >> >> the latest realtech drivers but when i shut down my system they >> >> >> >> revert >> >> >> >> to >> >> >> >> ones that do not work . any way to stop vista changing the >> >> >> >> drivers >> >> >> >> ? >> >> >> >> >> >> >> >> >> >> >> >> |
| My System Specs |
| 05-05-2007 | #10 |
| | Re: vista sound driver problem i must be tired and sorry for sounding dumb , whats UAC mean ? "dean-dean" wrote: > This is a puzzle. I have the same built-in soundcard that you have, and > have not had this problem. Realtek has two different downloads for Vista's > driver (one, an .exe installation file, the other a .zip). Have you tried > both? Both should be "unblocked". The .zip file installation, once the > files are extracted, uses Setup.exe, I believe, to begin the installation. > Either .exe file should be Run as Administrator. Or you could try turning > UAC off, if it isn't already (and turn it back on after the installation). > > Another work-around: > > In Device Manager, double-click the generic High Definition driver, and, on > the Driver tab, choose Update Driver. Then choose "Browse my computer for > driver software." This time, instead of "Search for driver software in this > location", try "Let me pick from a list of device drivers on my computer." > Then choose Have Disk. Browse to C:\Program Files\Realtek\InstallShield... > > "russ_will" <russwill@discussions.microsoft.com> wrote in message > news:8B8E065D-CA23-4B40-96BF-28B52ED6A250@microsoft.com... > >i have been building my own pc's since 98 , i have never had a problem like > > this before . i have tried everything i can think of but nothing works , > > wish i had kept my old system with xp on ![]() > > > > "dean-dean" wrote: > > > >> Sorry to hear that it didn't work. The only thing I can think of is to > >> try > >> the setup file from Realtek again. Right-click on the .exe file that > >> starts the installation, and choose Properties. If it is blocked on the > >> General tab, click on the Unblock button (Apply, OK). Then right-click > >> on > >> the file again, and choose Run as Administrator. > >> > >> "russ_will" <russwill@discussions.microsoft.com> wrote in message > >> news:7BDB80C5-B95D-4AB4-ADA6-68A7DB0DB0F3@microsoft.com... > >> > tried it , not sure why but it did not work . wish i got xp now as> >> > vista > >> > is to buggy for my liking > >> > > >> > "dean-dean" wrote: > >> > > >> >> Try this (you should have files in C:\Program > >> >> Files\Realtek\InstallShield, > >> >> from the Realtek installation): > >> >> > >> >> First, allow Vista to change your audio driver to the generic High > >> >> Definition driver (the one that doesn't work). On your keyboard, > >> >> press > >> >> the > >> >> Windows key + R. In the Run box, type > >> >> > >> >> msconfig > >> >> > >> >> On the Startup tab of System Configuration, if there are any files > >> >> from > >> >> Realtek Semiconductor, remove the checkmark for those, such as > >> >> RtHDVCpl.exe > >> >> (there may be others). (Apply, OK) and restart. (Tell System > >> >> Configuration > >> >> not to show you it's message or run again when you see that prompt > >> >> after > >> >> re-booting). Note: the appropriate startup item(s) will be re-entered > >> >> automatically when the new driver from Realtek is installed. > >> >> > >> >> Then, in Device Manager, double-click the generic High Definition > >> >> driver, > >> >> under "Sound, video and game controllers", and, on the Driver tab, > >> >> choose > >> >> Update Driver. Then choose "Browse my computer for driver software." > >> >> Under > >> >> "Search for driver software in this location", Browse to C:\Program > >> >> Files\Realtek\InstallShield. Click OK once you've found that folder, > >> >> then > >> >> click Next... > >> >> > >> >> "russ_will" <russwill@discussions.microsoft.com> wrote in message > >> >> news:7C7B3966-0490-4652-802E-1CB869F26D69@microsoft.com... > >> >> > it says in device manager = realtec high definition audio , i am > >> >> > using > >> >> > the > >> >> > drivers fron the realtech website (version 1.66) . audion chip is > >> >> > the > >> >> > realtech alc660 6-channel codec , it installs well but changes to > >> >> > just > >> >> > high > >> >> > def audion for some reason if shutdown for longer than a few min > >> >> > > >> >> > "dean-dean" wrote: > >> >> > > >> >> >> Specifically, what is the sound device's name in Device Manager, > >> >> >> under > >> >> >> Sound, video and game controllers (when the driver from Realtek is > >> >> >> installed)? Are there files from Realtek in C:\Program > >> >> >> Files\Realtek\InstallShield? > >> >> >> > >> >> >> > >> >> >> "russ_will" <russwill@discussions.microsoft.com> wrote in message > >> >> >> news:0AD93DF0-D6F6-45CB-9C59-95D830D241FB@microsoft.com... > >> >> >> > the sound device is onboard my motherboard , the board is the > >> >> >> > asus > >> >> >> > a8v-vm > >> >> >> > se > >> >> >> > . it uses a realtech driver which keeps getting replace , please > >> >> >> > help > >> >> >> > as > >> >> >> > it > >> >> >> > is driving my crazy ![]() > >> >> >> > > >> >> >> > "russ_will" wrote: > >> >> >> > > >> >> >> >> every time i shut down vista the sound drivers are changed , i > >> >> >> >> then > >> >> >> >> reinstall > >> >> >> >> the latest realtech drivers but when i shut down my system they > >> >> >> >> revert > >> >> >> >> to > >> >> >> >> ones that do not work . any way to stop vista changing the > >> >> >> >> drivers > >> >> >> >> ? > >> >> >> > >> >> >> > >> >> > >> >> > >> > >> > > |
| My System Specs |
| Similar Threads for: vista sound driver problem | ||||
| Sound Driver (problem) | Drivers | |||
| Activation problem when updating sound card driver | Vista installation & setup | |||
| Problem with Sound Driver Vista x64 | Sound & Audio | |||
| Strange sound driver problem | Vista hardware & devices | |||
| Intel UAA sound driver....problem | Vista hardware & devices | |||
