Vista - PowerNow not working on my laptop (in Vista 32bit nor 64bit, works fine under WindowsXP)
Old 06-17-2006   #1 (permalink)
kibusi@vlh.dk
Has anybody experienced PowerNow not working for AMD64 CPUs under Windows
Vista?
No matter what kind of strees is put on the CPU it's stuck at 800MHz (Mobile
AMD64 3200+), Windows XP was able to scale up to up to 2GHz just fine, and
so is my Gentoo Linux - but I just can't get Vista to utilize my CPU
properly
Anyone thoughts anyone?
TIA
Old 06-19-2006   #2 (permalink)
s t e w d o g
RE: PowerNow not working on my laptop (in Vista 32bit nor 64bit, works
I think I've sorted my problem with Amilo A1630 w/ 3200+ and not getting past
the 800 Mhz mark. I am not saying it is a fix but it has worked for me. I
updated the Fujitsu/AMI BIOS to the reference Uniwill BIOS 1.05. I did not
breathe the entire process but lo and behold, into Vista and we have
performance!
Went from a 1 rating to a whoppin' 3! (yes, I know....)
I was previously using Fujitsu-Siemens BIOS 1.03c. Never needed to update it
really. They have released a 1.04 and I should have tried that first but went
to the Uniwill site and downloaded the 1.05 BIOS from
http://www.uniwill.com/UserDownload/258KA0/258KA0.php because I hate Fujitsu.
A note to "I told you so'ers", there are STILL no useful options with these
BIOS ROMs and there are still no settings within to enable Cool n Quiet or
Turbo or whatever has to do with the proc. I reckon something sneaked it's
way in.
Another word of warning. This flash caused all of my hardware to have to be
reinstalled. XP spat me back out so tried Vista and it handled it all for me
nicely. Oh, and these laptops do not come with legacy floppy drives but you
can always boot to memory key and do the flash.
Hope this helps someone. Please remember though, I half expected the
notebook to catch alight at anytime, that's how daring I felt. Don't do it if
you don't mind waiting!
Oh and did I warn you not to do it?
I'm headed back into XP now, see if I can get working again. Checks and
balances.
He who dares. Good luck!
"kibusi@vlh.dk" wrote:
> Hi,
> Vista?
> properly
> TIA
Old 06-20-2006   #3 (permalink)
s t e w d o g
Part 2:
Further warning, my dual booting w/ XP has called for XP to be re-activated.
It appears that there are some sort of hardware identifiers that are changed
with this new BIOS, hence the fact that XP thought I had a different machine.
After activation, I could get in but many things did not work and hardware
that worked before now is looking for it's drivers. Wireless lan cannot
connect even after deleting devices in DM and letting PnP pick them up
again.
I believe that Vista will be ideal for those who get a new motherboard, in
that it detected and re-installed all of the new-found hardware, on the fly.
I also get a few interference lines popping up during the XP loading screen.
Scary. I think I'll re-install XP from scratch but I don't want to loose the
Vista boot loader. Can't say what it would do to Gentoo but this is all a
risk to be weighed.
> performance!
> way in.
> balances.
> > Hi,
> > Vista?
> > properly
> > TIA
Old 06-21-2006   #4 (permalink)
kibusi@vlh.dk
Re: PowerNow not working on my laptop (in Vista 32bit nor 64bit, w
Thanks for the replys - think I'll have a go at the bios update, can't
remember which version I am currently running but think it might be
Fujitsu's 1.04 as it hasn't been that long since I last checked if any
updates should have apperared since I acquired my notebook.
Having to re-install XP doesn't scare me off (actually planning that anyway
because I'm tired of my regional (Danish) installation resulting in mixed
languages whenever I use non-danish programs...), and I really don't expect
my Gentoo-installation to be heavily affected from the BIOS-update (keeps
fingers crossed )
Old 06-21-2006   #5 (permalink)
s t e w d o g
I've since installed the 1.04 bios from Fujitsu (their latest) due to the
display 'glitches' with Uniwill's bios 1.05, and same problem as before. I
am now happily using the Uniwill 1.04 bios and works a charm.
<kibusi@vlh.dk> wrote in message
news:FcidnbGgc8kPNQTZnZ2dnUVZ8qCdnZ2d@giganews.com...
> anyway
> expect
> fingers crossed )
Old 06-27-2006   #6 (permalink)
kibusi@vlh.dk
Indeed Uniwill's 1.04 and 1.05 seems to enable speed-stepping - alas they
introduce another problem for me...
Fujitsu's 1.04 BIOS includes Amikbc (what is that?) v1.02 which fixes some
problems I had with my Hauppage USB TV-tuner (able to boot with it plugged
in and it doesn't freeze the tuner randomly during usage) while Uniwill's
1.04 and 1.05 'only' includes Amikbc v1.01 which renders me unable to boot
the laptop whith the tuner pluged in and causes the tuner to randomly freeze
when using it.
So I'm back to Fujitsu's 1.04 and hoping they will either release a new
fixed BIOS or that some windows-update will fixx the problem as Windows XP
scales fine.
Kim Sindalsen
64bit internet browser works, but 32bit aren't. Vista networking & sharing
32bit apps crash when attempting to get online, 64bit programs work fine. Vista networking & sharing
My new laptop is 64bit but is preinstalled with 32bit... why would they do this? Vista General
32bit apps crash when attempting to get online, 64bit programs work fine. Vista General
Went to 64bit from 32bit on Vista and key not working... Vista General
