Vista - Can't Connect Motorola Razr Phone Help Please?
Old 05-07-2007   #1 (permalink)
WSLB
I'm trying to connect my phone through USB to my computer but it wont
install. The computer will recognize the device and ask if I would like to
install and so I do. But it never installs properly. I already have the
program installed and when I do a search on my phone it can't locate it. I
just need some information on how to get it working.
Old 05-08-2007   #2 (permalink)
LP
RE: Can't Connect Motorola Razr Phone Help Please?
Go Here
http://www.7900novadrive.com/V3/v3x.htm#3
Old 07-15-2007   #3 (permalink)
Gene1757
This was great help, thanks
"LP" wrote:
> Go Here
Motorola Phone Tools Vista General
MOTOROLA RAZR HELP Vista file management
Motorola Phone Toola v4 Vista General
Motorola Razr V3c and Build 6000 Don't Mix (Recently Got a Cell Phone Virus while trying to set up Motorola Phone Tools 4.0) Vista General
Motorola Razr V3 no Vista drivers need help Vista hardware & devices
