| | CPU/System Fan Control setting in bios The monitoring tools in bios shows info about CPU/system fan control. What do all of the things under the CPU/system fan control mean exactly? Should the setting be change? CPU temperature 36c/96.5f CPU fan speed: 2730 RPM system fan speed 1170 RPM CPU/system fan control: enabled Fan high temp: 65C CPU fan high voltage 12.0v System fan high voltage 12.0v Fan Low temp: 55c CPU fan low voltage: 5.5v system fan low voltage 5.5v |
| | Re: CPU/System Fan Control setting in bios Basically, your motherboard can control your fans. The top is the actual readings from your CPU and system fans. Your CPU is running at 36 degrees celsius. CPU fan and system fan speeds are below. The CPU/System fan control means that when your CPU is at 55 degrees or less, it will run at 5.5 volts, meaning a slower spinning fan and a much quieter fan. At full speed (12 volts, and above 65 degrees), it will run a bit louder. -- Dustin Harper dharper@vistarip.com http://www.vistarip.com -- "GT" <GT@discussions.microsoft.com> wrote in message news:94358757-B840-4819-985E-045AC013FA0A@microsoft.com... > The monitoring tools in bios shows info about CPU/system fan control. What > do > all of the things under the CPU/system fan control mean exactly? Should > the > setting be change? > > CPU temperature 36c/96.5f > CPU fan speed: 2730 RPM > system fan speed 1170 RPM > > CPU/system fan control: enabled > Fan high temp: 65C > CPU fan high voltage 12.0v > System fan high voltage 12.0v > > Fan Low temp: 55c > CPU fan low voltage: 5.5v > system fan low voltage 5.5v |
| | Re: CPU/System Fan Control setting in bios Those settings are fine, its just showing you the temperature of the processor, some voltages, and RPM settings. If you want to learn more about it, I suggest going to a place like www.cluboc.net (shameless plug ),www.hardforum.com, or www.anandtech.com "GT" <GT@discussions.microsoft.com> wrote in message news:94358757-B840-4819-985E-045AC013FA0A@microsoft.com... > The monitoring tools in bios shows info about CPU/system fan control. What > do > all of the things under the CPU/system fan control mean exactly? Should > the > setting be change? > > CPU temperature 36c/96.5f > CPU fan speed: 2730 RPM > system fan speed 1170 RPM > > CPU/system fan control: enabled > Fan high temp: 65C > CPU fan high voltage 12.0v > System fan high voltage 12.0v > > Fan Low temp: 55c > CPU fan low voltage: 5.5v > system fan low voltage 5.5v |
| | Re: CPU/System Fan Control setting in bios Should i change the default setting to make it better or is default setting good enough. What do you think? Fan high temp: 65C CPU fan high voltage 12.0v System fan high voltage 12.0v Fan Low temp: 55c CPU fan low voltage: 5.5v system fan low voltage 5.5v "Dustin Harper" wrote: > Basically, your motherboard can control your fans. The top is the actual > readings from your CPU and system fans. Your CPU is running at 36 degrees > celsius. CPU fan and system fan speeds are below. > > The CPU/System fan control means that when your CPU is at 55 degrees or > less, it will run at 5.5 volts, meaning a slower spinning fan and a much > quieter fan. At full speed (12 volts, and above 65 degrees), it will run a > bit louder. > > -- > Dustin Harper > dharper@vistarip.com > http://www.vistarip.com > > -- > "GT" <GT@discussions.microsoft.com> wrote in message > news:94358757-B840-4819-985E-045AC013FA0A@microsoft.com... > > The monitoring tools in bios shows info about CPU/system fan control. What > > do > > all of the things under the CPU/system fan control mean exactly? Should > > the > > setting be change? > > > > CPU temperature 36c/96.5f > > CPU fan speed: 2730 RPM > > system fan speed 1170 RPM > > > > CPU/system fan control: enabled > > Fan high temp: 65C > > CPU fan high voltage 12.0v > > System fan high voltage 12.0v > > > > Fan Low temp: 55c > > CPU fan low voltage: 5.5v > > system fan low voltage 5.5v > |
| | Re: CPU/System Fan Control setting in bios Standard settings are fine, especially with a regular temp of 36 degrees right now. Unless you are doing any overclocking, which it doesn't sound like it. It won't get any better, performance wise. -- Dustin Harper dharper@vistarip.com http://www.vistarip.com -- "GT" <GT@discussions.microsoft.com> wrote in message news:E3876E7A-EFAA-4C71-97F3-D15FC704A6A7@microsoft.com... > Should i change the default setting to make it better or is default > setting > good enough. What do you think? > > Fan high temp: 65C > CPU fan high voltage 12.0v > System fan high voltage 12.0v > > Fan Low temp: 55c > CPU fan low voltage: 5.5v > system fan low voltage 5.5v > > > > > "Dustin Harper" wrote: > >> Basically, your motherboard can control your fans. The top is the actual >> readings from your CPU and system fans. Your CPU is running at 36 degrees >> celsius. CPU fan and system fan speeds are below. >> >> The CPU/System fan control means that when your CPU is at 55 degrees or >> less, it will run at 5.5 volts, meaning a slower spinning fan and a much >> quieter fan. At full speed (12 volts, and above 65 degrees), it will run >> a >> bit louder. >> >> -- >> Dustin Harper >> dharper@vistarip.com >> http://www.vistarip.com >> >> -- >> "GT" <GT@discussions.microsoft.com> wrote in message >> news:94358757-B840-4819-985E-045AC013FA0A@microsoft.com... >> > The monitoring tools in bios shows info about CPU/system fan control. >> > What >> > do >> > all of the things under the CPU/system fan control mean exactly? Should >> > the >> > setting be change? >> > >> > CPU temperature 36c/96.5f >> > CPU fan speed: 2730 RPM >> > system fan speed 1170 RPM >> > >> > CPU/system fan control: enabled >> > Fan high temp: 65C >> > CPU fan high voltage 12.0v >> > System fan high voltage 12.0v >> > >> > Fan Low temp: 55c >> > CPU fan low voltage: 5.5v >> > system fan low voltage 5.5v >> |
| | #6 (permalink) |
| | Re: CPU/System Fan Control setting in bios that is what the BIOS shows. you can use another program to read that data and display it in VISTA .. I use Speed fan, shows CPU, FANS AND HARD DRIVES, Temps and fan speeds, mikeyhsd@comcast.net "GT" <GT@discussions.microsoft.com> wrote in message news:94358757-B840-4819-985E-045AC013FA0A@microsoft.com... The monitoring tools in bios shows info about CPU/system fan control. What do all of the things under the CPU/system fan control mean exactly? Should the setting be change? CPU temperature 36c/96.5f CPU fan speed: 2730 RPM system fan speed 1170 RPM CPU/system fan control: enabled Fan high temp: 65C CPU fan high voltage 12.0v System fan high voltage 12.0v Fan Low temp: 55c CPU fan low voltage: 5.5v system fan low voltage 5.5v |
| | #7 (permalink) |
| | Re: CPU/System Fan Control setting in bios since i cleaned the pentium D cooler rpm is at 3670/80 contantly. i dont see nothing wrong with the cleaning itself, maybe the thermal paste was not appropriate or what?? maybe a bios change? thanks well i plced a thinner layer of thermal paste and it seems good now. how thin the layer should be? sorry if i'm not at the right place to this subject... -- firemusic ------------------------------------------------------------------------ firemusic's Profile: http://forums.techarena.in/members/82796.htm View this thread: http://forums.techarena.in/vista-har...ces/743479.htm http://forums.techarena.in |
| BIOS setting demystified | Overclocking & Cooling | |||
| Could BIOS setting cause BSOD? | Vista hardware & devices | |||
| Bios Setting | Vista installation & setup | |||
| Setting AHCI in Bios & Activation | Vista hardware & devices | |||
| WinTV PVR 350, wont work with bios setting to AHCI | Vista hardware & devices | |||
