| | Realtek High Definition Audio Problem There seems to be many threads on this forum regarding the problem with the Realtek High Definition Audio. I also have this problem. My computer shows that my SPDIF is connected and is the default output device for sound. Despite my analogue speakers being plugged in, Vista reports that they are not. I have followed all of the tips in this forum to no avail but I have managed to find a way of getting the sound working, albeit temporarily. This is what I did: 1. Uninstall the Realtek drivers. 2. Reboot the computer. 3. The system should revert to the built-in HD Audio drivers provided my Microsoft. 4. Uninstall the Microsoft HD Audio drivers. 5. Reinstall the latest Realtek drivers. 6. During the install process the Realtek HD Audio system tray icon should appear and indicate that the speakers are detected. 7. The sound should now work. Now this is all great, trouble is when you restart the computer it reverts back to SPDIF output and the speakers again appear unplugged, which stops you selected them as the default output device. Any comments or suggestions on how this problem can be sorted without a full reinstall of Vista would be great. Thanks, Jim |
| | RE: Realtek High Definition Audio Problem Sussed it. You need to disable the front panel jack detection in the Realtek sound manager utility. You can access this by clicking on the folder icon on the right hand side of the utility screen, above the jack diagrams. Jim "Jim Corbett" wrote: > There seems to be many threads on this forum regarding the problem with the > Realtek High Definition Audio. > > I also have this problem. My computer shows that my SPDIF is connected and > is the default output device for sound. Despite my analogue speakers being > plugged in, Vista reports that they are not. > > I have followed all of the tips in this forum to no avail but I have managed > to find a way of getting the sound working, albeit temporarily. > > This is what I did: > > 1. Uninstall the Realtek drivers. > 2. Reboot the computer. > 3. The system should revert to the built-in HD Audio drivers provided my > Microsoft. > 4. Uninstall the Microsoft HD Audio drivers. > 5. Reinstall the latest Realtek drivers. > 6. During the install process the Realtek HD Audio system tray icon should > appear and indicate that the speakers are detected. > 7. The sound should now work. > > Now this is all great, trouble is when you restart the computer it reverts > back to SPDIF output and the speakers again appear unplugged, which stops you > selected them as the default output device. > > Any comments or suggestions on how this problem can be sorted without a full > reinstall of Vista would be great. > > Thanks, > > Jim |
| | Re: Realtek High Definition Audio Problem Jim Corbett;2841837 Wrote: Quote: > Sussed it. You need to disable the front panel jack detection in the > Realtek > sound manager utility. You can access this by clicking on the folder > icon on > the right hand side of the utility screen, above the jack diagrams. > > Jim > im having the same problem as you did about this sound issue on vista. can you,please,retype the solution little more precise,i would be very gratefull. thanx, sholeem -- sholeem ------------------------------------------------------------------------ sholeem's Profile: http://forums.techarena.in/members/153599.htm View this thread: http://forums.techarena.in/vista-har...ces/745161.htm http://forums.techarena.in |
| | Re: Realtek High Definition Audio Problem On Nov 10, 8:27*pm, sholeem <sholeem.41g...@newsgroup> wrote: Quote: > Jim Corbett;2841837 Wrote: > Quote: > > Sussed it. *You need to disable the front panel jack detection in the > > Realtek > > sound manager utility. *You can access this by clicking on the folder > > icon on > > the right hand side of the utility screen, above the jack diagrams. Quote: > > Jim > hi there Jim, > > im having the same problem as you did about this sound issue on vista. > can you,please,retype the solution little more precise,i would be very > gratefull. > > thanx, > sholeem > > -- > sholeem > ------------------------------------------------------------------------ > sholeem's Profile:http://forums.techarena.in/members/153599.htm > View this thread:http://forums.techarena.in/vista-har...es/745161..htm > > http://forums.techarena.in "Front Audio" jacks. When you find it, make sure to turn it "off." |
| Sound problem - realtek high definition audio | Vista hardware & devices | |||
| Realtek High Definition Audio Driver Re-Release | Vista hardware & devices | |||
| REALTEK High Definition Audio 1.48 (beta) for Vista x86/x64 | Vista hardware & devices | |||
| REALTEK HIGH DEFINITION AUDIO FOR HP M7160N | Vista General | |||
| Realtek ALC850 (High Definition Audio) Driver | Vista hardware & devices | |||
