Vista - Audio device driver installation failure
Old 05-16-2007   #1 (permalink)
VEGO
Hi there,
I just istalled Vista home premium on my Fujitsu N6010 which works just fine
except my audio. Vista can't install or find driver for my SigmaTel STAC9766
- AC '97 Compliant Codec audio controller. First I upgraded from XP directly
and I just had too much problems and bugs, so I decided to back up my files
and format my HD and install Vista clean. Now everything else is fine except
that audio driver issue.
I didn't have any luck finding a driver that will work.
Please advise.
Old 05-16-2007   #2 (permalink)
freddy
RE: Audio device driver installation failure
VEGO,
This site has some ideas for taking care of the problem
http://www.superwasp.net/weblog/2006...7-on-vista.htm
Let us know whether this does anything,
freddy
"VEGO" wrote:
> Hi there,
> Please advise.
Old 05-17-2007   #3 (permalink)
VEGO
Thanks, that solve my problem, but also for some reason Vista took driver
from my factory CD, before when I just upgraded from XP it didn't, so I did a
clean install andworks fine now.
"freddy" wrote:
> VEGO,
> freddy
> "VEGO" wrote:
> > Hi there,
> > Please advise.
Vista 64-bit USB Audio Device driver install error Drivers
GPO & Device Driver installation Network & Sharing
Installation of Device Driver Software Failed Vista hardware & devices
device driver software installation stopped Vista installation & setup
Yamaha YMF753 AC-XG Audio device driver for Sony VAIO?? Vista hardware & devices
