Driver for RT73 USB Wireless LAN Card
  1. #1
    Mogens Guest
    I wonder if anybody could help here. My problem is that I lost my wireless
    connection when upgrading from XP Media Center to Vista Home Premium and now
    I get the message "Download and install the driver for RT73 USB Wireless LAN
    Card" every time I start my PC, but I can't find this driver anywhere and I
    don't
    have any CD as my Medion Media Center PC came with the XP Media Center
    preinstalled. Can anyone help me with a driver or where to fin one? Thanks in
    advance.
    Kind regards
  2. #2
    Brink's Avatar
    Administrator
    Texas, USA
    64-bit Vista Ultimate SP2, Windows 7 Ultimate SP1, Windows 8 Enterprise
    Local Time: 03:09 PM
    usa us texas
    Hi Mogens,
    I can't find any drivers for it for Vista. Only XP. Here's the download link:
    http://totallydrivers.com/device.php?id=71844
    Hope this one will work for you,
  3. #3
    Barb Bowman Guest
    Re: Driver for RT73 USB Wireless LAN Card
    Unfortunately, many drivers for wireless are ONLY available on
    Windows Update for Vista. This means that you have to have a wired
    connection, establish connectivity to the Internet with the wireless
    NIC in the machine (and turned on, if applicable). Sometimes the
    driver is immediately offered automatically, sometimes you need to
    run update driver from device manager.
    Please report back if you are able to install it this way
    On Sat, 19 May 2007 14:06:01 -0700, Mogens
    >don't
    >advance.
    >Kind regards
    Barb Bowman
    MS Windows-MVP
    Expert Zone & Vista Community Columnist
    http://www.microsoft.com/windowsxp/e...ts/bowman.mspx
    http://blogs.digitalmediaphile.com/barb/
  4. #4
    Mogens Guest
    Thanks very much. Unfortunately the downloadlink on the site you suggested
    doesn't work. Do you eventually have any other suggestions?
    Kind regards
    Mogens
    "brink" wrote:
    > Hi Mogens,
    > download link:
    > '_http://totallydrivers.com/device.php?id=71844_'
    > (http://totallydrivers.com/device.php?id=71844)
    > Shawn
    > brink
    > "Practice makes perfect, then you reinstall"
    > Vista 64 Home Premium
    > 1.5 Gig DDR2 533 Mhz (PC4200) RAM
  5. #5
    Mogens Guest
    Hi Barb,
    I've also tried the download link brink suggested, but as you can see, that
    doesn't work either, so it seems to be a big problem to find anything.
    Kind regards
    Mogens
    > >don't
    > >advance.
    > >Kind regards
    > Barb Bowman
    > MS Windows-MVP
  6. #6
    Barb Bowman Guest
    http://drivers.softpedia.com/progDow...oad-20350.html
    On Sun, 20 May 2007 12:49:00 -0700, Mogens
    >Kind regards
    >Mogens
    >"brink" wrote:
    >> Hi Mogens,
    >> download link:
    >> Shawn
    >> brink
    Barb Bowman
    MS Windows-MVP
  7. #7
    Mogens Guest
    Thanks very much Shawn, but this was the download link, that Brink also
    suggested and it also seems to be a dead link. Just to be sure I've also
    tried the download links suggested from another machine running XP but still
    they are totally dead.
    regards
    Mogens
    > >Kind regards
    > >Mogens
    > >"brink" wrote:
    > >> Hi Mogens,
    > >> download link:
    > >> Shawn
    > >> brink
    > Barb Bowman
    > MS Windows-MVP
  8. #8
    Brink's Avatar
    Administrator
    Texas, USA
    usa us texas
    Ok,
    Here's a link where it works. I double checked it & it will download:
    http://totallydrivers.com/device.php?id=90474
    Sorry,
  9. #9
    Mogens Guest
    THANK YOU VERY MUCH - IT WORKED and now after download and installation I'm
    running wireless agan. Thank you very much for your help.
    Kind regards
    Mogens
    "brink" wrote:
    > Ok,
    > '_http://totallydrivers.com/device.php?id=90474_'
    > (http://totallydrivers.com/device.php?id=90474)
    > Shawn
    > brink
  10. #10
    Brink's Avatar
    Administrator
    Texas, USA
    usa us texas
    Quote Originally Posted by Mogens View Post
    Kind regards
    Mogens
    Glad to hear,
Driver for RT73 USB Wireless LAN Card problems?
Wireless Card Driver(Wireless not working) hemplacrosse4 Network & Sharing 0 24 Sep 2008
Driver for RT73 USB Wireless LAN Card Mogens Vista installation & setup 2 21 May 2007
Airlink wireless card 64-bit driver Rico Vista networking & sharing 1 18 Nov 2006
ntive driver support for my wireless card Steven Wabik Vista hardware & devices 7 17 Jun 2006
*native driver support for my wireless card Steven Wabik Vista hardware & devices 2 14 Jun 2006
