Vista - Problem ejecting USB mass storage device
Old 05-20-2007   #1 (permalink)
Mel
when i select to safely remove my usb stick, i get the following error;
"Windows cant stop your Generic Volume device because it is in use." etc.
now, ive used Process Explorer to try to find what process has a handle on
my usb, but a search yields no results, there is nothing binding my usb!
im using the same usb (DSE MicroDrive) that i used to use on my xp machine.
this only started on this xp machine.
any advice would be appreciated!!
Old 05-20-2007   #2 (permalink)
freddy
RE: Problem ejecting USB mass storage device
Mel,
If it were me with this issue, I'd just go ahead and remove the USB stick
and not be concerned with the message. That message is intended to make sure
you don't remove it before all data has been written, to prevent interruption
of data transfer. That's what the "safely remove" part of the message means.
If you're finished and data transfer is done, just go ahead and remove the
device. In the past, some people unplugged their USB devices before data
transfer completed and thus lost data. So, Microsoft came up with this
procedure to prevent that.
freddy
Old 05-20-2007   #3 (permalink)
Charles W Davis
Re: Problem ejecting USB mass storage device
Mel,
If you were using Windows Explorer to access the USB device, you should
close that first. Just a thought.
"Mel" <mel44@discussions.microsoft.com> wrote in message
news:1A17E6B7-B14B-47A7-8952-930A85EC876B@microsoft.com...
> machine.
Old 05-23-2007   #4 (permalink)
Mel
i duno, im not comfortable just pulling it out. i have really important
documents, i wouldnt want to lose. either way, its the principle of the
matter, something is not right, and id rather fix it the proper way
"freddy" wrote:
> Mel,
> freddy
Old 06-03-2007   #5 (permalink)
Tim Thein
I with you. I also have the same problem as you do.
Problem Ejecting USB Mass Storage Device General Discussion
Problem Ejecting USB Mass Storage Device Vista hardware & devices
problem ejecting USB mass storage drive Vista General
usb mass storage device problem Vista hardware & devices
"problem ejecting USB mass storage device" Vista hardware & devices
