| | Down to 3 issues in my device drivers-Can anyone help with the las OK here is my remaining list 1) Bluetooth Bus Enumerator 2) Broadcom 2045 Bluetooth 2.0 USB Device 3) Microsoft WPD FileSystem Volume Driver I'm not sure what #3 does or even if it's supposed to be working yet. As for 1 and 2 they are both Bluetooth related. I went to the Broadcom site and search several others for any Vista support with no luck. I've tried to reinstall the driver and it says that "Windows can not load the device driver for this hardware". Any help would be appreciated. --Rocco-- |
| | RE: Down to 3 issues in my device drivers-Can anyone help with the las Get widcomm 5.0.1.2500 drivers that works under vista 32 and 64 If there is no update for your adapter, just lookup VID and PID from your card in device manager and edit the original inf file for the installation. More info on this stack here: http://forum.gsmhosting.com/vbb/showthread.php?t=291473 Patrick. "RoccoP" wrote: > OK here is my remaining list > > 1) Bluetooth Bus Enumerator > 2) Broadcom 2045 Bluetooth 2.0 USB Device > 3) Microsoft WPD FileSystem Volume Driver > > I'm not sure what #3 does or even if it's supposed to be working yet. As > for 1 and 2 they are both Bluetooth related. I went to the Broadcom site and > search several others for any Vista support with no luck. I've tried to > reinstall the driver and it says that "Windows can not load the device driver > for this hardware". > > Any help would be appreciated. > > --Rocco-- > |
| | RE: Down to 3 issues in my device drivers-Can anyone help with the las Did you get your Bluetooth HID working in vista, and if so what drivers did you use and where did you find them? -- Cajun Gadget Boy "RoccoP" wrote: > OK here is my remaining list > > 1) Bluetooth Bus Enumerator > 2) Broadcom 2045 Bluetooth 2.0 USB Device > 3) Microsoft WPD FileSystem Volume Driver > > I'm not sure what #3 does or even if it's supposed to be working yet. As > for 1 and 2 they are both Bluetooth related. I went to the Broadcom site and > search several others for any Vista support with no luck. I've tried to > reinstall the driver and it says that "Windows can not load the device driver > for this hardware". > > Any help would be appreciated. > > --Rocco-- > |
| | RE: Down to 3 issues in my device drivers-Can anyone help with the Yes, I did. But I have a Microsoft Keyboard and mouse combo with a microsoft dongle. They work out of the box with the included drivers, just went to Control panel, network, bluetooth and the searched and paired the devices. On another computer I'm using a DLINK dongle, it works with an Olympia headset and they work ok with the widcomm stack. Hope that helps. Patrick. "RJ" wrote: > Did you get your Bluetooth HID working in vista, and if so what drivers did > you use and where did you find them? > -- > Cajun Gadget Boy > > > "RoccoP" wrote: > > > OK here is my remaining list > > > > 1) Bluetooth Bus Enumerator > > 2) Broadcom 2045 Bluetooth 2.0 USB Device > > 3) Microsoft WPD FileSystem Volume Driver > > > > I'm not sure what #3 does or even if it's supposed to be working yet. As > > for 1 and 2 they are both Bluetooth related. I went to the Broadcom site and > > search several others for any Vista support with no luck. I've tried to > > reinstall the driver and it says that "Windows can not load the device driver > > for this hardware". > > > > Any help would be appreciated. > > > > --Rocco-- > > |
| | RE: Down to 3 issues in my device drivers-Can anyone help with the I cannot get a headset working . it is a bluetooth device. I see the bluetooth in the devices, but when i pair, vista wants device drivers. manufacturer does not havbe for this as i assume it was native in XP. Love this device. Works with dongle of course as it is just a pass thoguh from speaker otput, but is supposed to work with bluetooth (built into my HP dv8000 laptop) and cannot get it going. i have tried a few of the wicomm drivers with no luck Any help would be appreciated "gduck" wrote: > Yes, I did. > > But I have a Microsoft Keyboard and mouse combo with a microsoft dongle. > They work out of the box with the included drivers, just went to Control > panel, network, bluetooth and the searched and paired the devices. > > On another computer I'm using a DLINK dongle, it works with an Olympia > headset and they work ok with the widcomm stack. > > Hope that helps. > > Patrick. > > "RJ" wrote: > > > Did you get your Bluetooth HID working in vista, and if so what drivers did > > you use and where did you find them? > > -- > > Cajun Gadget Boy > > > > > > "RoccoP" wrote: > > > > > OK here is my remaining list > > > > > > 1) Bluetooth Bus Enumerator > > > 2) Broadcom 2045 Bluetooth 2.0 USB Device > > > 3) Microsoft WPD FileSystem Volume Driver > > > > > > I'm not sure what #3 does or even if it's supposed to be working yet. As > > > for 1 and 2 they are both Bluetooth related. I went to the Broadcom site and > > > search several others for any Vista support with no luck. I've tried to > > > reinstall the driver and it says that "Windows can not load the device driver > > > for this hardware". > > > > > > Any help would be appreciated. > > > > > > --Rocco-- > > > |
| | #6 (permalink) |
| | RE: Down to 3 issues in my device drivers-Can anyone help with the I've tried doing that. But the only thing I can do is see the bluetooth device (my pocket pc pda) It will not let me use ActiveSync or any other bluetooth services other than "serial port" Anyone have a solution for this? It is a brand new bluetooth device. You'd think microsoft would have gotten bluetooth right before releasing vista 64 since it never worked in xp 64. anyhelp would be great. "gduck" wrote: > Get widcomm 5.0.1.2500 drivers that works under vista 32 and 64 > > If there is no update for your adapter, just lookup VID and PID from your > card in device manager and edit the original inf file for the installation. > > More info on this stack here: > http://forum.gsmhosting.com/vbb/showthread.php?t=291473 > > > Patrick. > > > "RoccoP" wrote: > > > OK here is my remaining list > > > > 1) Bluetooth Bus Enumerator > > 2) Broadcom 2045 Bluetooth 2.0 USB Device > > 3) Microsoft WPD FileSystem Volume Driver > > > > I'm not sure what #3 does or even if it's supposed to be working yet. As > > for 1 and 2 they are both Bluetooth related. I went to the Broadcom site and > > search several others for any Vista support with no luck. I've tried to > > reinstall the driver and it says that "Windows can not load the device driver > > for this hardware". > > > > Any help would be appreciated. > > > > --Rocco-- > > |
| USB device issues | General Discussion | |||
| Vista & External Storage Device & NAS device Issues | Vista file management | |||
| Device Issues | Vista hardware & devices | |||
