Vista - help me!
Old 06-18-2006   #1 (permalink)
AppleG5
help me!
Hi, I'm AppleG5, I installed Windows Vista on my eMachines PC a few weeks
ago, and I need help.
Windows Vista cannot detect my CD Drive!!!
I looked in device manager and saw that the DVD/CD-ROM Drive:
LITE-ON COMBO SOHC-4832K ATA Device
had the following problem:
Windows cannot start this hardware device because its configuration
information (in the registry) is incomplete or damaged. (Code 19)
Click 'Check for solutions' to send data about this device to Microsoft and
to see if there is a solution available.
I checked windows update, no luck. I tried updating the driver, nada. I
don't know what is wrong!!
Please help. Thank you SO MUCH in advance for any help.
Old 06-22-2006   #2 (permalink)
computerpro2
RE: help me!
Make Sure You BACKUP and Save This Key:
"{4D36E965-E325-11CE-BFC1-08002BE10318}"
1.)Open regedit (Start > Run > Type Regedit)
2.)Browse to the following:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}]
UpperFilters (Delete This Entry)
LowerFilters (Delete This Entry)
3.)Delete the entries for UpperFilters and LowerFilters (If you don't have
one of them that's ok)
4.)Exit regedit and reboot.
