Vista - DVD not load CODE 39
Old 06-18-2006   #1 (permalink)
Fábio
RE: DVD not load CODE 39
I have the same problem. After installing Windows Vista, the DVD Drive stop
working.
"Roberto" wrote:
> Windows cannot load the device driver for this hardware. The driver may be
> corrupted or missing. (Code 39)
> thanks
> rob
Old 06-19-2006   #2 (permalink)
Roberto
thanks
rob
Old 06-20-2006   #3 (permalink)
Keith
Do the upperfilters / lowerfilters fix from windows xp, it has worked for me
and many others in this forum
Manual steps to delete the UpperFilters and LowerFilters registry values
that can cause CD access problems
Warning Serious problems might occur if you modify the registry incorrectly
by using Registry Editor or by using another method. These problems might
require that you reinstall your operating system. Microsoft cannot guarantee
that these problems can be solved. Modify the registry at your own risk.
To manually delete the UpperFilters and LowerFilters registry values, follow
these steps: 1. Start Registry Editor (Regedt32.exe).
2. Locate the UpperFilters value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
3. On the Edit menu, click Delete, and then click OK.
4. Locate the LowerFilters value under the same key in the registry:
5. On the Edit menu, click Delete, and then click OK.
6. Quit Registry Editor.NOTE: After you remove the Upperfilters value and
the Lowerfilters value, if you notice lost functionality in a particular
program, such as CD recording software, you may need to reinstall that
software. If the problem recurs, consult with the software vendor for
assistance.
7. Restart your computer.
http://support.microsoft.com/default...b;en-us;314060
> working.
> > thanks
> > rob
Old 06-20-2006   #4 (permalink)
Fábio
Thank you, Keith. I did a more drastic procedure. I reinstaled Vista and the
DVD came back !!!!
> assistance.
> > working.
> > > thanks
> > > rob
Old 06-21-2006   #5 (permalink)
Beta Tester
Keith,
To make it short, with a clean install we are able to use the Plextor
PX-760. However, as soon as we install AnyDvd, the CD/DVD fails to appear in
the System Devices.
If you go into Registry,
HKEY_LOCALMACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318
and remove the Lower Filters - Reg_Multi-SZ - AnyDvd, the CD/DVD Rom will
work. This is where the problem exists.
I turned off Use User Account Control (UAC), and still cannot get AnyDvd to
start.
Has anyone experienced this problem with the Slysoft products?
Thanks...
> assistance.
> > working.
> > > thanks
> > > rob
Load or Install Application by Code VB Script
Load Web form with Excel row (code example) VB Script
windows vista cannot load dvd device driver error code 39 Vista General
dvd no load CODE 39 Vista General
