| | Booting with a USB connected hard drive I have installed the 64-bit version of Vista beta 2 on a 60 gig ide hard drive connected to my computer through a USB adapter. I have a 64-bit processor (AMD Athlon64 3500+). It won't boot all the way. After the Windows black screen with the gas gauge at the bottom the screen blinks blue for a split second and then reboots. I read in another post about problems with Vista trying to find a product connected via the USB port. Anyone know this for sure? Am I SOL trying to run it from a USB hard drive? Thanks for your time. |
| | Re: Booting with a USB connected hard drive It can't be run from a USB connected hard drive. -- Jane, not plain 64bit enabled ![]() Batteries not included. Braincell on vacation ![]() "North" <North@discussions.microsoft.com> wrote in message news:A7BE64F2-8C1F-4509-A3DB-BC26B7EC76C7@microsoft.com... >I have installed the 64-bit version of Vista beta 2 on a 60 gig ide hard > drive connected to my computer through a USB adapter. I have a 64-bit > processor (AMD Athlon64 3500+). It won't boot all the way. After the > Windows black screen with the gas gauge at the bottom the screen blinks > blue > for a split second and then reboots. I read in another post about > problems > with Vista trying to find a product connected via the USB port. Anyone > know > this for sure? Am I SOL trying to run it from a USB hard drive? Thanks > for > your time. |
| | RE: Booting with a USB connected hard drive same case here. i tried to install vista beta2 for trial in a USB hard drive, however after installation, it just can't boot into it. After that, i connect my drive to my SATA port then it works. I think this is a bug/ limitation, but if it is a limitation, i think Vista should able to detect it during the installation and at least a warning is expected. "North" wrote: > I have installed the 64-bit version of Vista beta 2 on a 60 gig ide hard > drive connected to my computer through a USB adapter. I have a 64-bit > processor (AMD Athlon64 3500+). It won't boot all the way. After the > Windows black screen with the gas gauge at the bottom the screen blinks blue > for a split second and then reboots. I read in another post about problems > with Vista trying to find a product connected via the USB port. Anyone know > this for sure? Am I SOL trying to run it from a USB hard drive? Thanks for > your time. |
| Will a dead secondary hard drive stop Vista from booting? | General Discussion | |||
| Booting vista ultimate 64bit from external hard drive? | Software | |||
| Booting from external hard drive | Vista General | |||
| Vista (64) Not booting with hard drive? | Drivers | |||
| Idea: A USB Hard Drive of a 16bit MS ME OS booting from a 32BIT Vista - would it work? | Vista file management | |||
