| | Recording sound from applications I am using EXPstudio Audio Editor with Vista Home Premium. When I used this application with XP there was a recording device "Microsoft Sound Mapper" that when selected would allow me to record directly from an application. That device is not present with Vista as far as I can tell. Is there an equivalent wtih Vista that I can use to record sound directly from an application? -- Thanks, Jed |
| | Re: Recording sound from applications Control Panel > Sound, right click Recording Devices window and select Show Disabled Devices and Show Disconnected Devices, do you have and item such as "What U Hear" (Creative) or "Stereo Mix" (Realtek), if so, set it as default. "Jed" <Jed@discussions.microsoft.com> wrote in message news:115CBD8A-D768-4768-8B44-61E061D29A36@microsoft.com... >I am using EXPstudio Audio Editor with Vista Home Premium. When I used this > application with XP there was a recording device "Microsoft Sound Mapper" > that when selected would allow me to record directly from an application. > That device is not present with Vista as far as I can tell. Is there an > equivalent wtih Vista that I can use to record sound directly from an > application? > -- > Thanks, > Jed |
| | Re: Recording sound from applications /Jed/ said: > I am using EXPstudio Audio Editor with Vista Home Premium. When I used this > application with XP there was a recording device "Microsoft Sound Mapper" > that when selected would allow me to record directly from an application. > That device is not present with Vista as far as I can tell. Is there an > equivalent wtih Vista that I can use to record sound directly from an > application? Audio in Vista has been reworked, and hard/software not specifically Vista compliant may not function. For a more thorough explanation see... http://forums.creative.com/creativel...essage.id=1694 Vista's built-in SOUND RECORDER may be able to accomplish what you want. Depending upon the Vista version being used, it will record in either WAV or WMA format (not selectable). Go into your sound card's Record PROPERTIES configuration and enable "what-u-hear" or similar. |
| | RE: Recording sound from applications okay!!!! I FOUND A SOLUTION TO EVRYONES PROBLEMM!!! i had the same problem. get an audio cable that has 2 ends like a set of headphones, and a headphone splitter divice. put the splitter inthe speaker jack on the computer, and then put the speakers in one side of the splitter, and then the audio chord in the other side. plug the other end of the audio chord into the microphone. record from the microphone jack!! "Jed" wrote: > I am using EXPstudio Audio Editor with Vista Home Premium. When I used this > application with XP there was a recording device "Microsoft Sound Mapper" > that when selected would allow me to record directly from an application. > That device is not present with Vista as far as I can tell. Is there an > equivalent wtih Vista that I can use to record sound directly from an > application? > -- > Thanks, > Jed |
| | RE: Recording sound from applications I think you have come upon a really simple solution that will work. Thanks for the idea. I will give this a try. -- Thanks, Jed "acdcbiggestfan" wrote: > okay!!!! I FOUND A SOLUTION TO EVRYONES PROBLEMM!!! i had the same problem. > get an audio cable that has 2 ends like a set of headphones, and a headphone > splitter divice. put the splitter inthe speaker jack on the computer, and > then put the speakers in one side of the splitter, and then the audio chord > in the other side. plug the other end of the audio chord into the microphone. > record from the microphone jack!! > > "Jed" wrote: > > > I am using EXPstudio Audio Editor with Vista Home Premium. When I used this > > application with XP there was a recording device "Microsoft Sound Mapper" > > that when selected would allow me to record directly from an application. > > That device is not present with Vista as far as I can tell. Is there an > > equivalent wtih Vista that I can use to record sound directly from an > > application? > > -- > > Thanks, > > Jed |
| | #6 (permalink) |
| | Re: Recording sound from applications I sure hope someone is still checking this thread because I'm having the same issue and the solutions offered arent available to me. I have no " What you Hear ' option on my built in Vista sound card. I suppose i could do the mini to mini suggestion but I shouldn't have to. I was able to record directly off of applications or internet streams on XP. I csn't see why I can't with Vista, especially because it's so much more expensive and supposedly " so much better " Still looking for a solution short of having to purchase an express sound card. Speaking of that, only ONE card available from ONE vendor? No choices? What the hell is that? "dev" wrote: Quote: > /Jed/ said: > Quote: > > I am using EXPstudio Audio Editor with Vista Home Premium. When I used this > > application with XP there was a recording device "Microsoft Sound Mapper" > > that when selected would allow me to record directly from an application. > > That device is not present with Vista as far as I can tell. Is there an > > equivalent wtih Vista that I can use to record sound directly from an > > application? > Audio in Vista has been reworked, and hard/software not specifically > Vista compliant may not function. For a more thorough explanation see... > http://forums.creative.com/creativel...essage.id=1694 > > Vista's built-in SOUND RECORDER may be able to accomplish what you want. > Depending upon the Vista version being used, it will record in either > WAV or WMA format (not selectable). > > Go into your sound card's Record PROPERTIES configuration and enable > "what-u-hear" or similar. > |
| Help making sound recording, no sound mix option | Sound & Audio | |||
| Sound Recording Mixer will not open in Vista for Line In recording | Vista hardware & devices | |||
| No sound recording in MCE on RC1 | Vista General | |||
| SOUND RECORDING | Vista hardware & devices | |||
