RB
Vista - SigmaTel audio driver installation - solved
05-29-2007   #1 (permalink)
Shahar
I solved the driver installtion problem as follow.
1) The Kaparsky anti-virus removed a necessary file in the system although
it admitted afterward it is not infected. It was windows\syswow64\setup.exe.
2) I installed several drivers with manager privilege, the last one is the
one from Intel but I think it uses a component not supplied in the recent
driver 6.10.0.5405.
(my board is Intel D946GZIS).
RB
Similar Threads for: SigmaTel audio driver installation - solved
Stereo Mix and Sigmatel Audio and driver problem! Sound & Audio
HEELP!!!!I HAVE A BIG SIGMATEL HD AUDIO DRIVER PROBLEM FOR VISTA Vista hardware & devices
SigmaTel High Definition Audio Driver Vista hardware & devices
SOLVED: SigmaTel Audio problem in Windows Vista Ultimate Vista hardware & devices
Sigmatel Audio Driver Vista hardware & devices
