| | low disc space in d drive (recovery i am getting a message i have low space in d drive, it came set up with 9.9 gb. my os is on c drive . c drive has 222 gb free. an i asign more memory to d drive? how? is that what i shoul do? thanks nick |
| | Re: low disc space in d drive (recovery Your D: drive is most likely a Recovery Partition set up by your computer manufacturer in order for you to recover your system to a factory default state and even if you made recovery DVDs or CDs should just be left alone. To get rid of the messages go to Control Panel > Administrative Tools > Computer Management, under Storage click Disk Management, right click on your D: drive and select Change drive letter and paths..., click the Remove button, OK the warning confirmation, OK again and close Computer Management. You will no longer see your D: drive in Windows Explorer or Computer, but no harm will be done and the low disk space alerts should stop. -- I Bleed Blue and Gold GO BEARS! "nicklondon" <nicklondon@discussions.microsoft.com> wrote in message news:93CC2898-B8B1-4306-8712-9B536A8B0018@microsoft.com... >i am getting a message i have low space in d drive, it came set up with 9.9 > gb. my os is on c drive . c drive has 222 gb free. an i asign more memory to > d drive? how? is that what i shoul do? > > thanks nick |
| | Re: low disc space in d drive (recovery Thank you! After messing around with this problem for about a month I am finally rid of that warning message! Great advice! "Cal Bear '66" wrote: Quote: > Your D: drive is most likely a Recovery Partition set up by your computer > manufacturer in order for you to recover your system to a factory default state > and even if you made recovery DVDs or CDs should just be left alone. > > To get rid of the messages go to Control Panel > Administrative Tools > Computer > Management, under Storage click Disk Management, right click on your D: drive > and select Change drive letter and paths..., click the Remove button, OK the > warning confirmation, OK again and close Computer Management. You will no longer > see your D: drive in Windows Explorer or Computer, but no harm will be done and > the low disk space alerts should stop. > > -- > I Bleed Blue and Gold > GO BEARS! > > > "nicklondon" <nicklondon@xxxxxx> wrote in message > news:93CC2898-B8B1-4306-8712-9B536A8B0018@xxxxxx Quote: > >i am getting a message i have low space in d drive, it came set up with 9.9 > > gb. my os is on c drive . c drive has 222 gb free. an i asign more memory to > > d drive? how? is that what i shoul do? > > > > thanks nick > |
| | Re: low disc space in d drive (recovery You're very welcome. Glad it worked your you. And, thank you for your generous compliment. I Bleed Blue and Gold GO BEARS! "saddie" <saddie@xxxxxx> wrote in message news:B021E11D-8557-4E8A-9ECE-376DAADA37DD@xxxxxx Quote: > Thank you! After messing around with this problem for about a month I am > finally rid of that warning message! Great advice! > > "Cal Bear '66" wrote: > Quote: >> Your D: drive is most likely a Recovery Partition set up by your computer >> manufacturer in order for you to recover your system to a factory default >> state >> and even if you made recovery DVDs or CDs should just be left alone. >> >> To get rid of the messages go to Control Panel > Administrative Tools > >> Computer >> Management, under Storage click Disk Management, right click on your D: drive >> and select Change drive letter and paths..., click the Remove button, OK the >> warning confirmation, OK again and close Computer Management. You will no >> longer >> see your D: drive in Windows Explorer or Computer, but no harm will be done >> and >> the low disk space alerts should stop. >> >> -- >> I Bleed Blue and Gold >> GO BEARS! >> >> >> "nicklondon" <nicklondon@xxxxxx> wrote in message >> news:93CC2898-B8B1-4306-8712-9B536A8B0018@xxxxxx Quote: >> >i am getting a message i have low space in d drive, it came set up with 9.9 >> > gb. my os is on c drive . c drive has 222 gb free. an i asign more memory >> > to >> > d drive? how? is that what i shoul do? >> > >> > thanks nick >> |
| | Re: low disc space in d drive (recovery Thank you ''Cal Bear '66'' I finaly sorted it out with the help of Del suport but your way seems much simpler. Nicklondon "Cal Bear '66" wrote: Quote: > Your D: drive is most likely a Recovery Partition set up by your computer > manufacturer in order for you to recover your system to a factory default state > and even if you made recovery DVDs or CDs should just be left alone. > > To get rid of the messages go to Control Panel > Administrative Tools > Computer > Management, under Storage click Disk Management, right click on your D: drive > and select Change drive letter and paths..., click the Remove button, OK the > warning confirmation, OK again and close Computer Management. You will no longer > see your D: drive in Windows Explorer or Computer, but no harm will be done and > the low disk space alerts should stop. > > -- > I Bleed Blue and Gold > GO BEARS! > > > "nicklondon" <nicklondon@xxxxxx> wrote in message > news:93CC2898-B8B1-4306-8712-9B536A8B0018@xxxxxx Quote: > >i am getting a message i have low space in d drive, it came set up with 9.9 > > gb. my os is on c drive . c drive has 222 gb free. an i asign more memory to > > d drive? how? is that what i shoul do? > > > > thanks nick > |
| | #6 (permalink) |
| | Re: low disc space in d drive (recovery You're welcome. I Bleed Blue and Gold GO BEARS! "nicklondon" <nicklondon@xxxxxx> wrote in message news:2F2A08C3-1686-4575-A58B-ECC430D40F90@xxxxxx Quote: > > Thank you ''Cal Bear '66'' > > I finaly sorted it out with the help of Del suport but your way seems much > simpler. > > Nicklondon > > "Cal Bear '66" wrote: > Quote: >> Your D: drive is most likely a Recovery Partition set up by your computer >> manufacturer in order for you to recover your system to a factory default >> state >> and even if you made recovery DVDs or CDs should just be left alone. >> >> To get rid of the messages go to Control Panel > Administrative Tools > >> Computer >> Management, under Storage click Disk Management, right click on your D: drive >> and select Change drive letter and paths..., click the Remove button, OK the >> warning confirmation, OK again and close Computer Management. You will no >> longer >> see your D: drive in Windows Explorer or Computer, but no harm will be done >> and >> the low disk space alerts should stop. >> >> -- >> I Bleed Blue and Gold >> GO BEARS! >> >> >> "nicklondon" <nicklondon@xxxxxx> wrote in message >> news:93CC2898-B8B1-4306-8712-9B536A8B0018@xxxxxx Quote: >> >i am getting a message i have low space in d drive, it came set up with 9.9 >> > gb. my os is on c drive . c drive has 222 gb free. an i asign more memory >> > to >> > d drive? how? is that what i shoul do? >> > >> > thanks nick >> |
| | #7 (permalink) |
| | Re: low disc space in d drive (recovery Hi, I have the same problem. Will your fix prevent my pc from making recovery points in the future? Thanks Stevei "Cal Bear '66" wrote: Quote: > Your D: drive is most likely a Recovery Partition set up by your computer > manufacturer in order for you to recover your system to a factory default state > and even if you made recovery DVDs or CDs should just be left alone. > > To get rid of the messages go to Control Panel > Administrative Tools > Computer > Management, under Storage click Disk Management, right click on your D: drive > and select Change drive letter and paths..., click the Remove button, OK the > warning confirmation, OK again and close Computer Management. You will no longer > see your D: drive in Windows Explorer or Computer, but no harm will be done and > the low disk space alerts should stop. > > -- > I Bleed Blue and Gold > GO BEARS! > > > "nicklondon" <nicklondon@xxxxxx> wrote in message > news:93CC2898-B8B1-4306-8712-9B536A8B0018@xxxxxx Quote: > >i am getting a message i have low space in d drive, it came set up with 9.9 > > gb. my os is on c drive . c drive has 222 gb free. an i asign more memory to > > d drive? how? is that what i shoul do? > > > > thanks nick > |
| | #8 (permalink) |
| | Re: low disc space in d drive (recovery There is a difference between a "Recovery Partition" that the computer manufacturer places on the hard drive with all of the necesary files to revert your computer back to "when 1st purchased" and the Recovery Points created by Vista once a day .....called "system restore" under start you will see Computer in the right hand dark section...right click and select properties...in the box that opens select Systen Protection...there you will see your HD with the latest restore point listed.If you uncheck the drive..all restore points will be deleted...in you recheck the drive restore points will be created again.Click the blue "how much etc etc line for a more detailed explanation... peter "stevox" <stevox@xxxxxx> wrote in message news:0C4AFC1E-A5F1-495A-A7A8-F4BEAF1F9C82@xxxxxx Quote: > Hi, > I have the same problem. Will your fix prevent my pc from making recovery > points in the future? > Thanks > > Stevei > > "Cal Bear '66" wrote: > Quote: >> Your D: drive is most likely a Recovery Partition set up by your computer >> manufacturer in order for you to recover your system to a factory default >> state >> and even if you made recovery DVDs or CDs should just be left alone. >> >> To get rid of the messages go to Control Panel > Administrative Tools > >> Computer >> Management, under Storage click Disk Management, right click on your D: >> drive >> and select Change drive letter and paths..., click the Remove button, OK >> the >> warning confirmation, OK again and close Computer Management. You will no >> longer >> see your D: drive in Windows Explorer or Computer, but no harm will be >> done and >> the low disk space alerts should stop. >> >> -- >> I Bleed Blue and Gold >> GO BEARS! >> >> >> "nicklondon" <nicklondon@xxxxxx> wrote in message >> news:93CC2898-B8B1-4306-8712-9B536A8B0018@xxxxxx Quote: >> >i am getting a message i have low space in d drive, it came set up with >> >9.9 >> > gb. my os is on c drive . c drive has 222 gb free. an i asign more >> > memory to >> > d drive? how? is that what i shoul do? >> > >> > thanks nick >> |
| | #9 (permalink) |
| | Re: low disc space in d drive (recovery I am on Windows Vista and have followed your instructions and nothing changed. The clean up did not free up any space in the Recovery Drive. How could I have filled up that drive? Help! elizabeth "peter" wrote: Quote: > There is a difference between a "Recovery Partition" that the computer > manufacturer places on the hard drive with all of the necesary files to > revert your computer back to "when 1st purchased" and the Recovery Points > created by Vista once a day .....called "system restore" > under start you will see Computer in the right hand dark section...right > click and select properties...in the box that opens select Systen > Protection...there you will see your HD with the latest restore point > listed.If you uncheck the drive..all restore points will be deleted...in you > recheck the drive restore points will be created again.Click the blue "how > much etc etc line for a more detailed explanation... > peter > "stevox" <stevox@xxxxxx> wrote in message > news:0C4AFC1E-A5F1-495A-A7A8-F4BEAF1F9C82@xxxxxx Quote: > > Hi, > > I have the same problem. Will your fix prevent my pc from making recovery > > points in the future? > > Thanks > > > > Stevei > > > > "Cal Bear '66" wrote: > > Quote: > >> Your D: drive is most likely a Recovery Partition set up by your computer > >> manufacturer in order for you to recover your system to a factory default > >> state > >> and even if you made recovery DVDs or CDs should just be left alone. > >> > >> To get rid of the messages go to Control Panel > Administrative Tools > > >> Computer > >> Management, under Storage click Disk Management, right click on your D: > >> drive > >> and select Change drive letter and paths..., click the Remove button, OK > >> the > >> warning confirmation, OK again and close Computer Management. You will no > >> longer > >> see your D: drive in Windows Explorer or Computer, but no harm will be > >> done and > >> the low disk space alerts should stop. > >> > >> -- > >> I Bleed Blue and Gold > >> GO BEARS! > >> > >> > >> "nicklondon" <nicklondon@xxxxxx> wrote in message > >> news:93CC2898-B8B1-4306-8712-9B536A8B0018@xxxxxx > >> >i am getting a message i have low space in d drive, it came set up with > >> >9.9 > >> > gb. my os is on c drive . c drive has 222 gb free. an i asign more > >> > memory to > >> > d drive? how? is that what i shoul do? > >> > > >> > thanks nick > >> > >> > |
| | #10 (permalink) |
| | Re: low disc space in d drive (recovery On Sun, 8 Jun 2008 01:14:00 -0700, elabrandon <elabrandon@xxxxxx> wrote: Quote: >I am on Windows Vista and have followed your instructions and nothing >changed. The clean up did not free up any space in the Recovery Drive. How >could I have filled up that drive? Help! >elizabeth yourself a favor: stop worrying about it and turn OFF that warning. http://pcsupport.about.com/od/window...dislowdisk.htm Quote: > >"peter" wrote: > Quote: >> There is a difference between a "Recovery Partition" that the computer >> manufacturer places on the hard drive with all of the necesary files to >> revert your computer back to "when 1st purchased" and the Recovery Points >> created by Vista once a day .....called "system restore" >> under start you will see Computer in the right hand dark section...right >> click and select properties...in the box that opens select Systen >> Protection...there you will see your HD with the latest restore point >> listed.If you uncheck the drive..all restore points will be deleted...in you >> recheck the drive restore points will be created again.Click the blue "how >> much etc etc line for a more detailed explanation... >> peter >> "stevox" <stevox@xxxxxx> wrote in message >> news:0C4AFC1E-A5F1-495A-A7A8-F4BEAF1F9C82@xxxxxx Quote: >> > Hi, >> > I have the same problem. Will your fix prevent my pc from making recovery >> > points in the future? >> > Thanks >> > >> > Stevei >> > >> > "Cal Bear '66" wrote: >> > >> >> Your D: drive is most likely a Recovery Partition set up by your computer >> >> manufacturer in order for you to recover your system to a factory default >> >> state >> >> and even if you made recovery DVDs or CDs should just be left alone. >> >> >> >> To get rid of the messages go to Control Panel > Administrative Tools > >> >> Computer >> >> Management, under Storage click Disk Management, right click on your D: >> >> drive >> >> and select Change drive letter and paths..., click the Remove button, OK >> >> the >> >> warning confirmation, OK again and close Computer Management. You will no >> >> longer >> >> see your D: drive in Windows Explorer or Computer, but no harm will be >> >> done and >> >> the low disk space alerts should stop. >> >> >> >> -- >> >> I Bleed Blue and Gold >> >> GO BEARS! >> >> >> >> >> >> "nicklondon" <nicklondon@xxxxxx> wrote in message >> >> news:93CC2898-B8B1-4306-8712-9B536A8B0018@xxxxxx >> >> >i am getting a message i have low space in d drive, it came set up with >> >> >9.9 >> >> > gb. my os is on c drive . c drive has 222 gb free. an i asign more >> >> > memory to >> >> > d drive? how? is that what i shoul do? >> >> > >> >> > thanks nick >> >> >> >> >> |
| low disc space on D:\ drive | Vista performance & maintenance | |||
| Cd drive & recovery disc | Vista hardware & devices | |||
| Restoring recovery drive with disc | Vista General | |||
| Hard Drive Disc space | Vista performance & maintenance | |||
| low disc space drive c | General Discussion | |||
