Sound trough speakers AND headphones
  1. #1
    Esben Guest
    Hello,
    In windows XP when i want to use my headphones i connect them to the audio
    jack in the front of my PC and turn off the power to the speakers(connected
    to audio jack in the back) because both audio jacks have the same sound.
    This doesn't seem to be the case in windows Vista, here i have to set the
    headphones as the default sound device and then restart the program i was
    using.
    Is there a way to do one of the following:
    -Have both audio jacks have the same sound
    -Stop the sound from the speakers and enable the sound for my headphones
    when i plug them in like with a stereo-installation.
    Thanks!
    Esben
  2. #2
    Cal Bear '66 Guest
    Re: Sound trough speakers AND headphones
    What audio adapter do you have?
    For Realtek, check out Control Panel > Realtek HD Audio Manager. With the
    Creative Audio Console and Creative cards you can have the speakers mute when
    you plug in headphones.
    I Bleed Blue and Gold
    GO BEARS!
    "Esben" <Esben@discussions.microsoft.com> wrote in message
    news:8652E705-1761-4011-94E6-C2F1857692E5@microsoft.com...
    > Hello,
    > using.
    > Thanks!
    > Esben
  3. #3
    Esben Guest
    Thanks for your reply!
    I have onboard audio on my motherboard (Asus p5b P965)
    After what you wrote i decided to install the drivers for them instead of
    using the windows vista drivers (on XP i already have the asus drivers
    installed)
    Now i have the same sound trough speakers and headphones so that's good.
    But i can't seem to find a place with settings that i can change.
    Under xp i have an icon in my taskbar where i can change all the settings...
  4. #4
    Vista x64
    Local Time: 11:15 AM
    I have the same issue with the realtek...
    The system is capable of 7.1+2 and the +2 is not outputting.
    The other issue i see is that i do not have a headphone in the audio output devices.. There is no way to add it.
  5. #5
    djmulls Guest
    I am having a similar problem as well. My headphone socket works, however the
    back analog socket it doesn't work and I can't find anyway to select either
    of them. Its as if Vista can only see the one.
    I have an Asus P4C800D mobo and I have used the Vista drivers, the Dell
    drivers, some old ones from Asus, and anything I can find on the web, still
    no joy. The only option I get in the audio control panel is Speakers.
    Arrgghh
    > the highlander
  6. #6
    Cal Bear '66 Guest
    Have you right clicked on the Playback Devices window and selected both Show
    Disabled Devices and Show Disconnected Devices?
    Is this a Realtek High Definition Audio device?
    Have you downloaded and installed the latest Realtek HD Audio drivers (ver
    1.71)?
    http://www.realtek.com.tw/downloads/...Audio%20Codecs
    GO BEARS!
    "djmulls" <djmulls@discussions.microsoft.com> wrote in message
    news:BC0439CC-ADB9-4F14-A1D4-B0466D162093@microsoft.com...
    > Arrgghh
    >> the highlander
  7. #7
    djmulls Guest
    Done and only speakers shows.
    And it is a Soundmax driver
  8. #8
    Vista x64
    same here.. only speakers show...
    When you plug in a device.. you get a notification box on the tray but there is no way to give me the opportunity to select what i want.
  9. #9
    Cristian from Italy Guest
    I had spent 599€ (820 USD!!!) for a copy of Vista Ultimate Retail, this is
    the price M$ as gift to us (Europe), With Windows XP both speakers 5.1
    (coaxial) and headphones function at same time, with "the no sense expensive"
    Vista I must switch the sound to speakers or headphones, I can't listen both
    at same time, and the procedure to switch the sound isn't so user friendly...
    open control panel... restart the application...
    I've Asus M2N32 WS Professional, with SoundMax chip.
    How is possible that a so expensive OS do less than XP? where's the solution
    M$? if there's...
  10. #10
    Marjay Guest
    Check your soundcard drivers and make sure they are up to date. Then
    check to see if you have an audio control panel (in Control Panel) and
    there should be an opption in there as to what to do with your speaker
    sound when you plug earphones in...
    On Sun, 29 Jul 2007 23:32:02 -0700, Cristian from Italy <Cristian from
    >M$? if there's...
Page 1 of 2 12 LastLast
Sound trough speakers AND headphones problems?
Sound heard in headphones, but not speakers!!! lmwilson2009 Sound & Audio 10 29 Sep 2009
Sound from headphones but not internal speakers andejame1217 Sound & Audio 2 01 May 2009
No sound on speakers or headphones. glm Sound & Audio 2 03 Mar 2009
Sound through Headphones Not Speakers LyndaLou Vista hardware & devices 2 26 Jun 2008
No sound through headphones, speakers working Chloe Vista General 4 28 May 2008
