Vista - hard self test problem with Vista
Old 06-06-2007   #1 (permalink)
Alexis
At start-up windows starts the hard drive self test, but seconds later the
computer freezes completely.
This happen every time I boot the computer, if I skip the test then
everything is fine.
I check the HD from BIOS for errors and it is fine.
Any ideas?
Old 06-07-2007   #2 (permalink)
freddy
RE: hard self test problem with Vista
Alexis, skip the test.
freddy
> everything is fine.
> Any ideas?
Old 06-12-2007   #3 (permalink)
Alexis
Freddy,
I do skip the test, but the test returns next time I start windows!
Thanks,
Alexis
> freddy
> > everything is fine.
> > Any ideas?
E6850 Oc problem vista 64 bsod when stress test Overclocking & Cooling
hard to describe vista problem Vista performance & maintenance
Installing Vista on a test hard drive Vista installation & setup
