Vista - Dual Monitor Locks up System - Completely
Old 06-08-2007   #1 (permalink)
Jared
Well, I had been running dual monitor way back in XP, switched to Vista at
Beta2 and continued using it as my main system since then. About 2 weeks
ago, I started to get weird randon crashes, with no sign of why in any of the
log files. This was on a P4 3.4 Ghz system with 1.5 Gb Ram and an Nvidia
Geforce 6800 Ultra. I began to investigate the problem thinking something
might be failing hardware wise. I started checking CPU temperatures, hard
disk validation, etc. So after playing around, the system seemed only to get
worse, and since I hadn't reinstalled since the RTM came out, I figured I
would just take my finalized Vista CD and reinstall, just to see if maybe all
the software I had on it might be causing the issue. Well, after backing up
personal files and moving everything to storage drives, I reinstalled, and
started setting everything back up. Lo and behold, a fresh copy of Vista
hung also (let me describe the hang - screen goes black, system does nothing,
does not respond to RDC or file sharing). So, I figured that hardware had
seen its days, and since I had three other newer machines (two Core Duo T2600
Desktops, and One Core 2 Duo E6700 Desktop), I figured I would migrate to
some new hardware. Well after two days of frustration and reinstalling the
OS to no previal, I had about given up on vista, when I though to myself that
the only thing left in common to this mysterious crash was the keyboard and
mouse and the two monitors. After doing a little more testing, and internet
searching, I have found that dual monitors under vista is causing this system
hang. I tested this on a Intel 915 Video based motherboard, a Geforce 6800
Ultra, a Geforce 7300 GS, and a Geforce 7600 GT. I have two Samsung 215tw
and run 1650x1080 on both monitors, with windows setup to extend the desktop
to the second monitor. Also, just a note, I could run DVI to both screens,
but rather use a DVI to VGA adapter on my video card to run the VGA into a
KVM switch. So I have one running VGA and one running DVI. The lockups had
different attributes depending on the motherboard & video card combination.
On some the computer would just stop responding, but you could still see
everything, and others, you would loose video signal all together. All in
all, I wasted about three days time figuring this out, mostly because I had
no issue with Dual Monitor setups up until a couple weeks ago. Oh, and
system restore back to a previous date does not help either. All in all, I
am very frustrated, and I have a feeling it has to do the your handshaking
for content protection... Thank you Microsoft.
This post is a suggestion for Microsoft, and Microsoft responds to the
suggestions with the most votes. To vote for this suggestion, click the "I
Agree" button in the message pane. If you do not see the button, follow this
link to open the suggestion in the Microsoft Web-based Newsreader and then
click "I Agree" in the message pane.
http://windowshelp.microsoft.com/com...rdware_devices
Solved System won't shutdown completely General Discussion
Completely hiding System Tray Icons General Discussion
System Locks Media Center
Pictures on system-color is completely off Vista music pictures video
DUAL-Monitor-System with ATI&NVIDIA Vista hardware & devices
