| | hardware installation problems I'm having problems installing any hardware which use USB ports to my pc. I have tried installing my printer (cannon pixma ip4200) using the vista drivers recommended by cannon. Every time I get to the point where I attach the printer to the USB port, vista looks for the drivers (which are installed correctly) but can't find them! I know the drivers are intalled correctly because I can see them where they are installed. However, the printer works as a network printer which is attached to my other pc which has XP installed. I have tried attaching other devices (card reader, IDE HD adapter, USB hub etc) to my USB ports and I'm now having problems with all of them. When I attach a device, Vista looks for drivers for the device (even if it doesn't need one) and comes up with the same message (vista cannot find drivers for this device). I've tried a system restore to a point as far back as possible to resolve this problem....as I had no problems previously...but no luck. I know my printer works as I have tried using it with a pc using vista at work. I'm sure this is a windows problem and not the USB ports as they work perfectly well for items I installed a while back. I don't want to do a complete windows re-install!! Can anyone help please? |
| | RE: hardware installation problems johnny, Some folks have had good fortune in resolving such problems by deleting the INFCACHE.1 file. It's located at C:\Windows\inf (scroll down to the file). It's OK to delete the file even when it has nothing to do with the problem. Windows puts inf files in that cache when it has hardware to install but has information about that hardware that it doesn't know what to do with (layman's explanation). Inf stands for information, which Windows needs to know how to install the hardware properly. With that file removed, Windows will find the correct inf file and install the hardware, we hope. Post back on whether that suggestion works. -- freddy "johnny m" wrote: > I'm having problems installing any hardware which use USB ports to my pc. I > have tried installing my printer (cannon pixma ip4200) using the vista > drivers recommended by cannon. Every time I get to the point where I attach > the printer to the USB port, vista looks for the drivers (which are installed > correctly) but can't find them! I know the drivers are intalled correctly > because I can see them where they are installed. However, the printer works > as a network printer which is attached to my other pc which has XP > installed. I have tried attaching other devices (card reader, IDE HD adapter, > USB hub etc) to my USB ports and I'm now having problems with all of them. > When I attach a device, Vista looks for drivers for the device (even if it > doesn't need one) and comes up with the same message (vista cannot find > drivers for this device). I've tried a system restore to a point as far back > as possible to resolve this problem....as I had no problems previously...but > no luck. I know my printer works as I have tried using it with a pc using > vista at work. I'm sure this is a windows problem and not the USB ports as > they work perfectly well for items I installed a while back. I don't want to > do a complete windows re-install!! Can anyone help please? |
| | RE: hardware installation problems Thank you Freddy.....that has solved all my problems!!! My printer is now working with my vista pc....and I can also use my card reader etc which didn't install previously! Thanks again for your help....you have solved what was becoming a very frustrating problem!! "freddy" wrote: > johnny, > > Some folks have had good fortune in resolving such problems by deleting the > INFCACHE.1 file. It's located at C:\Windows\inf (scroll down to the file). > It's OK to delete the file even when it has nothing to do with the problem. > > Windows puts inf files in that cache when it has hardware to install but has > information about that hardware that it doesn't know what to do with > (layman's explanation). Inf stands for information, which Windows needs to > know how to install the hardware properly. With that file removed, Windows > will find the correct inf file and install the hardware, we hope. Post back > on whether that suggestion works. > -- > freddy > > > "johnny m" wrote: > > > I'm having problems installing any hardware which use USB ports to my pc. I > > have tried installing my printer (cannon pixma ip4200) using the vista > > drivers recommended by cannon. Every time I get to the point where I attach > > the printer to the USB port, vista looks for the drivers (which are installed > > correctly) but can't find them! I know the drivers are intalled correctly > > because I can see them where they are installed. However, the printer works > > as a network printer which is attached to my other pc which has XP > > installed. I have tried attaching other devices (card reader, IDE HD adapter, > > USB hub etc) to my USB ports and I'm now having problems with all of them. > > When I attach a device, Vista looks for drivers for the device (even if it > > doesn't need one) and comes up with the same message (vista cannot find > > drivers for this device). I've tried a system restore to a point as far back > > as possible to resolve this problem....as I had no problems previously...but > > no luck. I know my printer works as I have tried using it with a pc using > > vista at work. I'm sure this is a windows problem and not the USB ports as > > they work perfectly well for items I installed a while back. I don't want to > > do a complete windows re-install!! Can anyone help please? |
| | RE: hardware installation problems johnny, Frustration is not good for the soul. -- freddy "johnny m" wrote: > Thank you Freddy.....that has solved all my problems!!! My printer is now > working with my vista pc....and I can also use my card reader etc which > didn't install previously! Thanks again for your help....you have solved what > was becoming a very frustrating problem!! > > > > "freddy" wrote: > > > johnny, > > > > Some folks have had good fortune in resolving such problems by deleting the > > INFCACHE.1 file. It's located at C:\Windows\inf (scroll down to the file). > > It's OK to delete the file even when it has nothing to do with the problem. > > > > Windows puts inf files in that cache when it has hardware to install but has > > information about that hardware that it doesn't know what to do with > > (layman's explanation). Inf stands for information, which Windows needs to > > know how to install the hardware properly. With that file removed, Windows > > will find the correct inf file and install the hardware, we hope. Post back > > on whether that suggestion works. > > -- > > freddy > > > > > > "johnny m" wrote: > > > > > I'm having problems installing any hardware which use USB ports to my pc. I > > > have tried installing my printer (cannon pixma ip4200) using the vista > > > drivers recommended by cannon. Every time I get to the point where I attach > > > the printer to the USB port, vista looks for the drivers (which are installed > > > correctly) but can't find them! I know the drivers are intalled correctly > > > because I can see them where they are installed. However, the printer works > > > as a network printer which is attached to my other pc which has XP > > > installed. I have tried attaching other devices (card reader, IDE HD adapter, > > > USB hub etc) to my USB ports and I'm now having problems with all of them. > > > When I attach a device, Vista looks for drivers for the device (even if it > > > doesn't need one) and comes up with the same message (vista cannot find > > > drivers for this device). I've tried a system restore to a point as far back > > > as possible to resolve this problem....as I had no problems previously...but > > > no luck. I know my printer works as I have tried using it with a pc using > > > vista at work. I'm sure this is a windows problem and not the USB ports as > > > they work perfectly well for items I installed a while back. I don't want to > > > do a complete windows re-install!! Can anyone help please? |
| About proprietary hardware driver installation | Vista General | |||
| Hardware and installation (2 questions) | Vista installation & setup | |||
| Installation hardware advice | Vista installation & setup | |||
| Installation / Upgrading Hardware | Vista General | |||
| Installation / Upgrading Hardware. | Vista General | |||
