Vista - Print Spooler Locks up After first Print
Old 06-11-2007   #1 (permalink)
JBKAYAK
Using Windows Vista, most (75%) laptops lock up the print spooler after the
first print. I am using a networked (TCP\IP) OKIDATA 5100C printer. Of
course, the driver is written for windows XP since OKI hasnt created a vista
driver. I see other people experiencing the same problem with other brand
name printers. I am hoping for a fix in VISTA... any IDEAS?
Thanks
Old 06-11-2007   #2 (permalink)
freddy
RE: Print Spooler Locks up After first Print
JBKAYAK,
I doubt that Microsoft will develop drivers for Oki printers. If Oki has no
Vista compatible printer drivers for its printers, then I don't see any
alternative to buying a printer that is compatible with Vista. You can try
using google to search the Internet for 3rd party printer drivers to see what
you fined, but don't count on finding anything.
freddy
> Thanks
Old 06-12-2007   #3 (permalink)
Richard G. Harper
Re: Print Spooler Locks up After first Print
I don't think Microsoft *can* fix Vista so that Windows XP drivers and
unsupported devices will work. Device driver problems are the fault of the
hardware manufacturer and they need to step up and release Vista drivers.
Richard G. Harper [MVP Shell/User] rgharper@gmail.com
* NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/
* PLEASE post all messages and replies in the newsgroups
* The Website - http://rgharper.mvps.org/
* HELP us help YOU ... http://www.dts-l.org/goodpost.htm
"JBKAYAK" <JBKAYAK@discussions.microsoft.com> wrote in message
news:F2891F63-38A6-4AC7-9569-6A8622745AF0@microsoft.com...
> the
> vista
> Thanks
Old 06-14-2007   #4 (permalink)
JBKAYAK
I know the problem resides with okidata. Seems the XP driver doesnt have a
character string to "hang up the print spooler"
is there a work around such as:
print directly to printer rather tham start printer imediately under printer
properties.
or
can you use a net use in command prompt to reset the print spooler after it
locks up??
Thanks for any ideas?
> > the
> > vista
> > Thanks
Old 06-14-2007   #5 (permalink)
Richard G. Harper
You could try running NET STOP SPOOLER followed by NET START SPOOLER at an
elevated command prompt. Or you could get a supported printer. :-)
news:24C5F4F9-7371-4075-B6A4-23C00142A571@microsoft.com...
> printer
> properties.
> or
> it
> locks up??
>> the
>> > the
>> > Of
>> > vista
>> > brand
>> > Thanks
Old 07-03-2007   #6 (permalink)
BigPhil63
I have a similar configuration with an OKI 5200n and OKI's response to my
request for tech assist was to check windows update for an updated driver. I
am looking for an answer in the open source world where I have had success
before and if I find something I will post a link. For now, I use the new HP
printer that is windows
compatible but I will be working for a solution
Phil T
> Thanks
email locks up & will not print msg Vista mail
HOw do I start the print spooler so I can install my print drivers? Vista installation & setup
Print Spooler hangs and doesn't print Vista print fax & scan
print spooler Vista print fax & scan
Print Spooler Lock up After first Print Vista General
