Vista Forums Home Join Vista Forums Donate Windows 7 Forum Vista Tutorials Tags
Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks.
MSFT VX6000 Lifecam not showing in "Scanners & Cameras"
LinkBack Thread Tools Display Modes
Old 06-12-2007   #1 (permalink)
Peter
Guest
Latest Vista driver from MSFT too. (1.3VX for Lifecam VX6000). It can't be added either because the only option is to insert a disk and the driver software comes from MSFT's website.
Also why can't we show Printers and Cameras in "My Computer" like we can in XP?
Peter
Toronto, Canada
XP Pro SP2 x 2 + Vista Ultimate Triple Boot
P4 HT @ 3ghz, 4gb DDR, 700gb HDD
Soundblaster Audigy 4 PCI Sound
ATI Radeon X1650 Pro AGP Graphics
Old 06-12-2007   #2 (permalink)
freddy
Guest
RE: MSFT VX6000 Lifecam not showing in "Scanners & Cameras"
Peter,
I searched the Internet and found this instruction posted by someone who
installed the VX600 on an earlier version of Vista (note use of earlier 1.2
software):
"find driver disk or download the 1.2 software from microsoft
http://www.microsoft.com/hardware/di...=Lifecam%201.0
expand to a folder
plug in webcam
find 2 entrys in device manager
go to driver update
install driver for device from subdirectory from folder
(just the driver you do not need the software) 32bit or 64bit directory
microsoft and skype (new beta) are fine with the webcam microsoft has a
close beta under wraps but you need to get either a new nx device or wait
till release date for the driver which will be made available."
I'll look around some more to see whether I can find something better. Post
back if you think the above instruction useful.
As far as showing printers and cameras in My Computer (now Computer in
Vista), I don't recall ever seing printers in My Computer in WinXP, but the
camera shows up there in both WinXP and in Vista after you connect it. It
displays as a drive of some sort, no? That's my recollection from the last
time I connected my camera.
freddy
> in XP?
> Peter
> Toronto, Canada
Old 06-12-2007   #3 (permalink)
freddy
Guest
Peter,
Here is another quote from a website where the poster installed the llifecam
in Vista:
"Setting up the webcam proved to be straightforward, although we had to
download software for Vista instead of installing it from the included CD.
Nevertheless, the entire process took only a few minutes."
I think this shows that users are installing the VX6000 on Vista. If you
have further problems, please post back.
freddy
> in XP?
> Peter
> Toronto, Canada
Old 06-12-2007   #4 (permalink)
Peter
Guest
Re: MSFT VX6000 Lifecam not showing in "Scanners & Cameras"
Thanks. I installed the camera OK right from the start...no problems and I
had to use the drivers from MSFT website because the CD is old. Just
wondered why the heck it doesn't show in Scanners & Cameras.
Peter
Toronto, Canada
"freddy" <fkirschen@tidalwave.net> wrote in message
news:AFADB98C-4DFD-4F55-9419-3089FBF81461@microsoft.com...
> Peter,
> llifecam
> in Vista:
> freddy
>> driver
>> in XP?
>> Peter
>> Toronto, Canada
Old 06-12-2007   #5 (permalink)
freddy
Guest
Peter,
It's hard determining what you want to know. You need to work on your use
of the written word.
freddy
> Peter
> Toronto, Canada
> > Peter,
> > llifecam
> > in Vista:
> > freddy
> >> driver
> >> in XP?
> >> Peter
> >> Toronto, Canada
Old 06-12-2007   #6 (permalink)
Peter
Guest
Considering that I am English and have a degree in it, not sure how else I
could explain it.
I had no problems installing the camera using MSFT's Vista drivers from
their website. Considering it is a Microsoft product and Vista is also a
Microsoft product, why doesn't it show up in the Scanner and Cameras module?
As I said, it shows fine in XP. I'm just assuming that it is a glitch with
Vista awaiting some sort of fix down the line.
never mind, it isn't really that important.
Peter
Toronto, Canada
news:B1BEBA7D-956D-4B36-960B-43356EADF41C@microsoft.com...
> Peter,
> freddy
>> I
>> Peter
>> Toronto, Canada
>> > Peter,
>> > llifecam
>> > in Vista:
>> > CD.
>> > you
>> > freddy
>> >> can't
>> >> driver
>> >> can
>> >> in XP?
>> >> Peter
>> >> Toronto, Canada
Old 06-12-2007   #7 (permalink)
Cal Bear '66
Guest
Where is this Scanner and Cameras module?
Computer (not My Computer) does not have it.
In Device Manager it is under "Imaging devices".
I Bleed Blue and Gold
GO BEARS!
"Peter" <ex_brit@discussions.microsoft.com> wrote in message
news:75C99969-9994-4565-B7D7-0DE4943753EC@microsoft.com...
> could explain it.
> I had no problems installing the camera using MSFT's Vista drivers from their
> website. Considering it is a Microsoft product and Vista is also a Microsoft
> Peter
> Toronto, Canada
>> Peter,
>> freddy
>>> Peter
>>> Toronto, Canada
>>> > Peter,
>>> > llifecam
>>> > in Vista:
>>> > freddy
>>> >> driver
>>> >> in XP?
>>> >> Peter
>>> >> Toronto, Canada
Old 06-12-2007   #8 (permalink)
Peter
Guest
Start/Control Panel/Hardware & Sound/
Peter
Toronto, Canada
"Cal Bear '66" <xxx@xxx.org> wrote in message
news:28B7B7B2-9A21-4FC3-B0FE-CC8FF71699DB@microsoft.com...
> GO BEARS!
>> I could explain it.
>> module?
>> with Vista awaiting some sort of fix down the line.
>> Peter
>> Toronto, Canada
>>> Peter,
>>> use
>>> freddy
>>>> and I
>>>> Peter
>>>> Toronto, Canada
>>>> > Peter,
>>>> > llifecam
>>>> > in Vista:
>>>> > to
>>>> > included CD.
>>>> > you
>>>> > freddy
>>>> >> can't
>>>> >> driver
>>>> >> can
>>>> >> in XP?
>>>> >> Peter
>>>> >> Toronto, Canada
Old 06-12-2007   #9 (permalink)
Cal Bear '66
Guest
Oh, THAT Control Panel view. Never use it, to many clicks to get to what I
want. I use Classic view, and have Control Panel as a menu on my Start Menu.
My Logitech webcam also does not appear there and cannot be added. It must be
only useful for handheld digital cameras not webcams.
GO BEARS!
news:069BC950-1C81-4513-AB89-E64D2EE95521@microsoft.com...
> Peter
> Toronto, Canada
>> GO BEARS!
>>> could explain it.
>>> Peter
>>> Toronto, Canada
>>>> Peter,
>>>> freddy
>>>>> I
>>>>> Peter
>>>>> Toronto, Canada
>>>>> > Peter,
>>>>> > llifecam
>>>>> > in Vista:
>>>>> > CD.
>>>>> > you
>>>>> > freddy
>>>>> >> can't
>>>>> >> driver
>>>>> >> can
>>>>> >> in XP?
>>>>> >> Peter
>>>>> >> Toronto, Canada
Old 06-12-2007   #10 (permalink)
Peter
Guest
I guess that's the case. Tried Classic view, haven't decided yet which one
I prefer.
Peter
Toronto, Canada
news:20DE94F0-6456-4B20-8A0B-048D013DA8EF@microsoft.com...
> I want. I use Classic view, and have Control Panel as a menu on my Start
> Menu.
> must be only useful for handheld digital cameras not webcams.
> GO BEARS!
>> Peter
>> Toronto, Canada
>>> GO BEARS!
>>>> else I could explain it.
>>>> a Microsoft product, why doesn't it show up in the Scanner and Cameras
>>>> module?
>>>> Peter
>>>> Toronto, Canada
>>>>> Peter,
>>>>> use
>>>>> freddy
>>>>>> and I
>>>>>> Just
>>>>>> Peter
>>>>>> Toronto, Canada
>>>>>> > Peter,
>>>>>> > llifecam
>>>>>> > in Vista:
>>>>>> > had to
>>>>>> > included CD.
>>>>>> > If you
>>>>>> > freddy
>>>>>> >> It can't
>>>>>> >> the
>>>>>> >> driver
>>>>>> >> we can
>>>>>> >> in XP?
>>>>>> >> Peter
>>>>>> >> Toronto, Canada
Display Modes
No Wireless connection in "Scanners and Cameras" Zeus Vista print fax & scan 3 02-02-2008 11:14 PM
Re: Scanners and Cameras Zeus Vista print fax & scan 0 01-22-2008 08:05 PM
Scanners and Cameras MrB Vista General 9 05-26-2007 10:48 AM
Microsoft LifeCam VX6000 drivers Jdr Vista music pictures video 0 01-26-2007 11:55 AM
MSFT Announces "Support" (Convergys of Ohio/India in Reality?) for English CPP Chad Harris Vista General 0 12-14-2006 11:37 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
