| Guest | Installation/Running period problems, check my system for known in ....compatibility problems please. I can't get Vista Beta 2 to install without running it in safe mode. It sucks, even when I install it it has problems running at all, crashes at boot unless it's at safe mode or run last good configuration. Here is my system: ASRock 939 SATA 2 (With the sata2, gameport and onboard sound disabled) Radeon 9700 Non-pro Sound Blaster Audigy Gamer 2GB RAM Athlon 64 3200+ overclocked to 2.4ghz The ethernet port is an onboard ULi brand network adapter and I also have one of those magic 5 extra USB port PCI cards. Any idea what could be causing the problems? Windows XP and Linux run fine, I am running it on a dual boot XP/Vista configuration and have tried both 64-bit and 32-bit versions, even though I'd rather use the 32-Bit version for the drivers. |
| Guest | Re: Installation/Running period problems, check my system for known in Have you tried to install it when NOT overclocked? Any diference? "Wisgary" <Wisgary@discussions.microsoft.com> wrote in message news:0ADD896D-25F7-4318-9666-DA4F7B70D2EF@microsoft.com... > ...compatibility problems please. > > I can't get Vista Beta 2 to install without running it in safe mode. It > sucks, even when I install it it has problems running at all, crashes at > boot > unless it's at safe mode or run last good configuration. Here is my > system: > > ASRock 939 SATA 2 (With the sata2, gameport and onboard sound disabled) > Radeon 9700 Non-pro > Sound Blaster Audigy Gamer > 2GB RAM > Athlon 64 3200+ overclocked to 2.4ghz > > The ethernet port is an onboard ULi brand network adapter and I also have > one of those magic 5 extra USB port PCI cards. Any idea what could be > causing > the problems? Windows XP and Linux run fine, I am running it on a dual > boot > XP/Vista configuration and have tried both 64-bit and 32-bit versions, > even > though I'd rather use the 32-Bit version for the drivers. > |
| Guest | Re: Installation/Running period problems, check my system for known in In article <0ADD896D-25F7-4318-9666-DA4F7B70D2EF@microsoft.com>, Wisgary says... > ...compatibility problems please. > > I can't get Vista Beta 2 to install without running it in safe mode. It > sucks, even when I install it it has problems running at all, crashes at boot > unless it's at safe mode or run last good configuration. Here is my system: > > ASRock 939 SATA 2 (With the sata2, gameport and onboard sound disabled) > Radeon 9700 Non-pro > Sound Blaster Audigy Gamer > 2GB RAM > Athlon 64 3200+ overclocked to 2.4ghz > > The ethernet port is an onboard ULi brand network adapter and I also have > one of those magic 5 extra USB port PCI cards. Any idea what could be causing > the problems? Windows XP and Linux run fine, I am running it on a dual boot > XP/Vista configuration and have tried both 64-bit and 32-bit versions, even > though I'd rather use the 32-Bit version for the drivers. > > Apart from the graphics card and the fact I have a Athlon64 3500+, we have exactly the same kit and it works fine for me to the point where I completely ditched XP. If you go to Asrocks website and download the version 3.51 LAN drivers, they support Vista for the LAN. The link is here: http://download.asrock.com/drivers/U...ista(v351).zip The onboard sound drivers then get installed via Windows Update. -- Conor Who the **** said I was trying to endear myself to anyone? |
| Guest | RE: Installation/Running period problems, check my system for known in Oh my god I can't believe it worked, I'm such an idiot for not trying this before, what a moron, working perfectly now, thank you everyone! "Wisgary" wrote: > ...compatibility problems please. > > I can't get Vista Beta 2 to install without running it in safe mode. It > sucks, even when I install it it has problems running at all, crashes at boot > unless it's at safe mode or run last good configuration. Here is my system: > > ASRock 939 SATA 2 (With the sata2, gameport and onboard sound disabled) > Radeon 9700 Non-pro > Sound Blaster Audigy Gamer > 2GB RAM > Athlon 64 3200+ overclocked to 2.4ghz > > The ethernet port is an onboard ULi brand network adapter and I also have > one of those magic 5 extra USB port PCI cards. Any idea what could be causing > the problems? Windows XP and Linux run fine, I am running it on a dual boot > XP/Vista configuration and have tried both 64-bit and 32-bit versions, even > though I'd rather use the 32-Bit version for the drivers. > |
| required certificate is not within its validity period when verifyingagainst the current system clock... | Vista General | |||
| Problems With the Installation System in Vista | Vista installation & setup | |||
| Vista system file check problems! | Vista General | |||
| Standby lasts for a short period after which the system resumes | Vista hardware & devices | |||
| Installation/Running period problems, check my system for known in | Vista hardware & devices | |||
