Vista - CPU showing wrong speed on vista
Old 06-13-2007   #1 (permalink)
camachoboss
Hi here´s the deal i have a Core2 duo 6600 CPU it should work at 2.4 ghz and
vista is telling me it works 900mhz, because of that i cannot play halo 2
because of low cpu speed it doens even install.
i have an Abit ADW9 chipset intel 975X
Pls help
Old 06-13-2007   #2 (permalink)
mikeyhsd
Re: CPU showing wrong speed on vista
change your power setting to High Performance.
mikeyhsd@comcast.net
"camachoboss" <camachoboss@discussions.microsoft.com> wrote in message news:3213E3D5-ADC1-4DC6-841E-A66EED92E6E4@microsoft.com...
Pls help
Old 06-13-2007   #3 (permalink)
Richard Urban
Make certain that the FSB (front side bus)speed in the bios is correct for
your installed hardware. On my board an improper startup can revert the FSB
speed to it's default settings. This will make the CPU run a lot slower. My
AMD Athlon XP 3200, for instance, will show up as running at 1.2 meg instead
of at the correct 2.2 meg.
Regards,
Richard Urban
> and
> Pls help
Old 06-14-2007   #4 (permalink)
Captain Roberts
"Richard Urban" <richardurbanREMOVETHIS@hotmail.com> wrote in message
news:%23dFhg$hrHHA.4764@TK2MSFTNGP06.phx.gbl...
> FSB speed to it's default settings. This will make the CPU run a lot
> slower. My AMD Athlon XP 3200, for instance, will show up as running at
> 1.2 meg instead of at the correct 2.2 meg.
meg? You meant GHz, right? ;0)
Captain Roberts
Old 06-14-2007   #5 (permalink)
Richard Urban
Oops! You are so right
Regards,
Richard Urban
"Captain Roberts" <none@given.hyar> wrote in message
news:%23OHYaLkrHHA.192@TK2MSFTNGP02.phx.gbl...
>> for your installed hardware. On my board an improper startup can revert
>> the FSB speed to it's default settings. This will make the CPU run a lot
> Captain Roberts
Problem| Vista isn't showing my actual cpu speed! General Discussion
RE: Normal to report the wrong CPU speed in a VM? Virtual PC
Vista 64 showing the wrong capacity for Lacie 1 TB USB HDD Vista General
Wrong CPU speed, with Q6600 Vista performance & maintenance
Wrong processor speed detected Vista hardware & devices
