| | VISTA HOME PREMIUM HARD DRIVE I have a 320GB P4M900M2 hard drive. I am using windows vista Home Premium. When I install Vista hard drive capacity came down to 298GB. Then I have transferred some files (MP3) from my old computer 20GB. Now my available space should be 278GB but for some unknown reason every time I use the computer (listen to music, paly DVD) the hard drive space come down. It came down from 268GB to 236GB then I have deleted all the files I have transferred 20GB and emptied the recycle bin. But still it shows as 256GB free from 298GB. I have done a search but can't find any big files. 38GB missing from the hard drive. Why does it do this? Is this a problem with my hard drive? Please help. |
| | Re: VISTA HOME PREMIUM HARD DRIVE System Restore will be making restore points on a regular basis, which will account for a lot of that. I think by default System Restore can utilise 15% of your hard drive capacity. Older restore points will get deleted once it hits that limit. You can use Disk Cleanup to delete all but the latest restore point from the 'More Options' tab. -- Jane, not plain 64 bit enabled :-)Batteries not included. Braincell on vacation ;-) MVP Windows Shell/User "RAJIV7" <RAJIV7@discussions.microsoft.com> wrote in message news:2FE46FE4-AD6A-4FF5-9301-52D864BF868B@microsoft.com... >I have a 320GB P4M900M2 hard drive. I am using windows vista Home Premium. > When I install Vista hard drive capacity came down to 298GB. Then I have > transferred some files (MP3) from my old computer 20GB. Now my available > space should be 278GB but for some unknown reason every time I use the > computer (listen to music, paly DVD) the hard drive space come down. It > came > down from 268GB to 236GB then I have deleted all the files I have > transferred > 20GB and emptied the recycle bin. But still it shows as 256GB free from > 298GB. I have done a search but can't find any big files. 38GB missing > from > the hard drive. Why does it do this? Is this a problem with my hard drive? > Please help. > |
| | Re: VISTA HOME PREMIUM HARD DRIVE System restore will eat up a big chunk of your drive. Program installs like office will keep the installed "files" on drive C: as well as install the program to wherever you decided you want it to go. Any program you install will create many temporary files that are not necessarily deleted after the install. Go to the start orb. Type Disk Cleanup in search. Highlight in the top window and then press enter to run disk cleanup. It will get back some of your used space. -- Regards, Richard Urban Microsoft MVP Windows Shell/User (For email, remove the obvious from my address) "RAJIV7" <RAJIV7@discussions.microsoft.com> wrote in message news:2FE46FE4-AD6A-4FF5-9301-52D864BF868B@microsoft.com... >I have a 320GB P4M900M2 hard drive. I am using windows vista Home Premium. > When I install Vista hard drive capacity came down to 298GB. Then I have > transferred some files (MP3) from my old computer 20GB. Now my available > space should be 278GB but for some unknown reason every time I use the > computer (listen to music, paly DVD) the hard drive space come down. It > came > down from 268GB to 236GB then I have deleted all the files I have > transferred > 20GB and emptied the recycle bin. But still it shows as 256GB free from > 298GB. I have done a search but can't find any big files. 38GB missing > from > the hard drive. Why does it do this? Is this a problem with my hard drive? > Please help. > |
| external hard drive for vista home premium | General Discussion | |||
| hard drive question vista home premium | General Discussion | |||
| Vista home premium drain my hard drive | Vista General | |||
| Vista home premium drain my hard drive | Vista installation & setup | |||
| 80GB hard drive is too small for Vista Home Premium??? | Vista installation & setup | |||
