| | Vista - Installation/Running period problems, check my system for known in |
| 06-20-2006 | #1 |
| | Installation/Running period problems, check my system for known in ....compatibility problems please. I can't get Vista Beta 2 to install without running it in safe mode. It sucks, even when I install it it has problems running at all, crashes at boot unless it's at safe mode or run last good configuration. Here is my system: ASRock 939 SATA 2 (With the sata2, gameport and onboard sound disabled) Radeon 9700 Non-pro Sound Blaster Audigy Gamer 2GB RAM Athlon 64 3200+ overclocked to 2.4ghz The ethernet port is an onboard ULi brand network adapter and I also have one of those magic 5 extra USB port PCI cards. Any idea what could be causing the problems? Windows XP and Linux run fine, I am running it on a dual boot XP/Vista configuration and have tried both 64-bit and 32-bit versions, even though I'd rather use the 32-Bit version for the drivers. |
| My System Specs |
| Similar Threads for: Installation/Running period problems, check my system for known in | ||||
| required certificate is not within its validity period when verifyingagainst the current system clock... | Vista General | |||
| Problems With the Installation System in Vista | Vista installation & setup | |||
| Vista system file check problems! | Vista General | |||
| Standby lasts for a short period after which the system resumes | Vista hardware & devices | |||
| Installation/Running period problems, check my system for known in | Vista hardware & devices | |||
