| | Problem with Epson CX5000 Scanner Driver When I try to install a Vista 32bit driver for the CX5000 All-In-One Epson Scanner (downloaded from Epson), I get the following message: Windows encountered a problem installing the driver software for your device. Windows found driver software for your device, but encountered an error while attempting to install it. EPSON CX4900/CX5000/DX5000. The system cannot find the file specified. I have tried every possible way to install this driver with no success. I have even downloaded the driver numerous times to try again. Epson tech rep tried, too, but gave up and told me to contact Microsoft. The downloaded Vista driver for the printer portion of the Epson CX5000 installed correctly. Only the scanner driver didn't install properly. |
| | RE: Problem with Epson CX5000 Scanner Driver harmonp, I'm assuming that the printer is working properly, but that only the scanner part isn't working. If that's correct, and if you don't get your scanner to function, I think you can buy scanner driver/software for your combo model to get it to work in Vista. I think Microsoft (Vista) changed the scanning technology from that used in prior versions of Windows, meaning that older technology scanners may not work in Vista, because the Vista compatible software needed to make them work hasn't been supplied. I don't know about the exact changes made, but it has something to do with Twain technology. I'll leave the details up to others to explain. My whole purpose in making this post is to say that I checked the site that sells drivers/software for scanners that have no Vista drivers. This site has Vista drivers for over 700 scanners, including an Epson Stylus CX5000. You can double check here: http://hamrick.com/ The only downside is the the driver/software package costs $40. I had to use it for my old scanner, and it works good in Vista for me. Just thought you'd like to know. -- freddy "harmonp" wrote: > When I try to install a Vista 32bit driver for the CX5000 All-In-One Epson > Scanner (downloaded from Epson), I get the following message: > Windows encountered a problem installing the driver software for your > device. Windows found driver software for your device, but encountered an > error while attempting to install it. EPSON CX4900/CX5000/DX5000. The > system cannot find the file specified. > > I have tried every possible way to install this driver with no success. I > have even downloaded the driver numerous times to try again. Epson tech rep > tried, too, but gave up and told me to contact Microsoft. > > The downloaded Vista driver for the printer portion of the Epson CX5000 > installed correctly. Only the scanner driver didn't install properly. |
| | RE: Problem with Epson CX5000 Scanner Driver Thank you for the information. I tried VueScan, but unfortunately it couldn't find a scanner on my system. I contacted the author and he said the Epson CX5000 scanner driver had to be present for VueScan to work. That leaves me with the same problem. The Epson Vista driver for the scanner (new) won't install. VueScan was certainly worth a try, and would seem to be a valuable program in most instances. I like the Epson CX5000 all-in-one because it prints photos well and the scanner does work from the printer control to easily make copies. I may just buy a separate scanner and hope I can make it work. "freddy" wrote: > harmonp, > > I'm assuming that the printer is working properly, but that only the scanner > part isn't working. If that's correct, and if you don't get your scanner to > function, I think you can buy scanner driver/software for your combo model to > get it to work in Vista. > > I think Microsoft (Vista) changed the scanning technology from that used in > prior versions of Windows, meaning that older technology scanners may not > work in Vista, because the Vista compatible software needed to make them work > hasn't been supplied. I don't know about the exact changes made, but it has > something to do with Twain technology. I'll leave the details up to others > to explain. > > My whole purpose in making this post is to say that I checked the site that > sells drivers/software for scanners that have no Vista drivers. This site > has Vista drivers for over 700 scanners, including an Epson Stylus CX5000. > You can double check here: > > http://hamrick.com/ > > The only downside is the the driver/software package costs $40. I had to > use it for my old scanner, and it works good in Vista for me. Just thought > you'd like to know. > -- > freddy > > > "harmonp" wrote: > > > When I try to install a Vista 32bit driver for the CX5000 All-In-One Epson > > Scanner (downloaded from Epson), I get the following message: > > Windows encountered a problem installing the driver software for your > > device. Windows found driver software for your device, but encountered an > > error while attempting to install it. EPSON CX4900/CX5000/DX5000. The > > system cannot find the file specified. > > > > I have tried every possible way to install this driver with no success. I > > have even downloaded the driver numerous times to try again. Epson tech rep > > tried, too, but gave up and told me to contact Microsoft. > > > > The downloaded Vista driver for the printer portion of the Epson CX5000 > > installed correctly. Only the scanner driver didn't install properly. |
| | RE: Problem with Epson CX5000 Scanner Driver harmonp, That's a bummer, for sure. -- freddy "harmonp" wrote: > Thank you for the information. I tried VueScan, but unfortunately it > couldn't find a scanner on my system. I contacted the author and he said the > Epson CX5000 scanner driver had to be present for VueScan to work. That > leaves me with the same problem. The Epson Vista driver for the scanner > (new) won't install. VueScan was certainly worth a try, and would seem to be > a valuable program in most instances. I like the Epson CX5000 all-in-one > because it prints photos well and the scanner does work from the printer > control to easily make copies. I may just buy a separate scanner and hope I > can make it work. > > "freddy" wrote: > > > harmonp, > > > > I'm assuming that the printer is working properly, but that only the scanner > > part isn't working. If that's correct, and if you don't get your scanner to > > function, I think you can buy scanner driver/software for your combo model to > > get it to work in Vista. > > > > I think Microsoft (Vista) changed the scanning technology from that used in > > prior versions of Windows, meaning that older technology scanners may not > > work in Vista, because the Vista compatible software needed to make them work > > hasn't been supplied. I don't know about the exact changes made, but it has > > something to do with Twain technology. I'll leave the details up to others > > to explain. > > > > My whole purpose in making this post is to say that I checked the site that > > sells drivers/software for scanners that have no Vista drivers. This site > > has Vista drivers for over 700 scanners, including an Epson Stylus CX5000. > > You can double check here: > > > > http://hamrick.com/ > > > > The only downside is the the driver/software package costs $40. I had to > > use it for my old scanner, and it works good in Vista for me. Just thought > > you'd like to know. > > -- > > freddy > > > > > > "harmonp" wrote: > > > > > When I try to install a Vista 32bit driver for the CX5000 All-In-One Epson > > > Scanner (downloaded from Epson), I get the following message: > > > Windows encountered a problem installing the driver software for your > > > device. Windows found driver software for your device, but encountered an > > > error while attempting to install it. EPSON CX4900/CX5000/DX5000. The > > > system cannot find the file specified. > > > > > > I have tried every possible way to install this driver with no success. I > > > have even downloaded the driver numerous times to try again. Epson tech rep > > > tried, too, but gave up and told me to contact Microsoft. > > > > > > The downloaded Vista driver for the printer portion of the Epson CX5000 > > > installed correctly. Only the scanner driver didn't install properly. |
| Epson Vista twain driver problem | Vista print fax & scan | |||
| Epson CX5000 Help | Vista print fax & scan | |||
| Epson 4990 Scanner problem | Vista print fax & scan | |||
| Hitachi Prinfina Color CX5000 Printer Vista Driver | Vista print fax & scan | |||
