Vista Forums Home Join Vista Forums Donate Windows 7 Forum Vista Tutorials Tags
Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks.
No Audio Output Device Installed
LinkBack Thread Tools Display Modes
Old 06-14-2007   #1 (permalink)
Jenny
Guest
So, I have read the majority of these questions posted..and I have also the
same problem. I did a clean install of Vista and I have an Analog Devices
SoundMAX soundcard I believe.. I have been through the dell website as well
as softpedia.com. I did find some drivers but none are for my system. I have
a Dell Dimension 4700C. I have tried everything! I have tried going to the
Device Manager..and I have tried the Driver Reset Tool. Nothing helps. I
tried to update it through Windows Update as well and it will not give me an
update.
Can anyone help me please?
I 'd really really really appreciate it!
Old 06-15-2007   #2 (permalink)
freddy
Guest
RE: No Audio Output Device Installed
Jenny,
The following site has a link to SoundMax drivers for Vista:
http://neosmart.net/blog/2006/vista-sound-drivers/
Post back on whether this does anything. People like to know.
freddy
> update.
Old 06-15-2007   #3 (permalink)
freddy
Guest
Jenny,
I just noticed that my previous post links to digital drivers, but you have
analog. I found this other post for installing analog:
1. Go To: Device Manage - Sound, Video And Game Controllers
2. "Update Driver"
3. "Browse My Computer For Driver Software"
4. "AD188X_AD198X_V5.12.01.3890_WDM" -> "Other" -> "Analog" -> "Ok"
5. Instaling Drivers!
If the above doesn't work for you, post back and we'll try again.
freddy
> update.
Old 06-17-2007   #4 (permalink)
Jenny
Guest
Hi Freddy,
When I browse my computer for driver software..it doesn't find anything.Any
idea where I can get "AD188X_AD198X_V5.12.01.3890_WDM" ? It just says that it
doesn't find any driver software to update it.
Any ideas?
Thanks!
Jenny
"freddy" wrote:
> Jenny,
> 2. "Update Driver"
> freddy
> > update.
Old 06-18-2007   #5 (permalink)
freddy
Guest
Hi Jenny,
These legacy sound card drivers are usually available from the manufacturer
of the computer (Dell, HP, Compaq, etc.). Check more carefully at your
computer manufacturer's website, or at the website of the manufacturer of
your motherboard. Another approach is to contact them via their support
links at their respective websites. You can also use google to search on a
term such as:
soundmax drivers vista
or something similar. I think you will have success.
freddy
"Jenny" wrote:
> Hi Freddy,
> Any ideas?
> Thanks!
> Jenny
> "freddy" wrote:
> > Jenny,
> > 2. "Update Driver"
> > freddy
> > > update.
Old 06-18-2007   #6 (permalink)
Jenny
Guest
Hi Freddy,
I know it was a longer process..but I went back to Windows XP and
re-installed the driver for the sound card. The sound started working
again..then I put my upgrade disc in for Vista and went back to Vista and the
sound is working fine. I guess it only happens when you do a clean install
because it gets rid of your drivers all together..and even tho there are
drivers out there for my soundcard for Vista none of them worked. Thanks for
yr help!
Everything is working great now. *crosses fingers*
Jenny
"freddy" wrote:
> Hi Jenny,
> term such as:
> freddy
> "Jenny" wrote:
> > Hi Freddy,
> > Any ideas?
> > Thanks!
> > Jenny
> > "freddy" wrote:
> > > Jenny,
> > > 2. "Update Driver"
> > > freddy
> > > > update.
Old 06-18-2007   #7 (permalink)
freddy
Guest
Jenny,
That's using your noodle.
freddy
"Jenny" wrote:
> Hi Freddy,
> yr help!
> Jenny
> "freddy" wrote:
> > Hi Jenny,
> > term such as:
> > freddy
> > "Jenny" wrote:
> > > Hi Freddy,
> > > Any ideas?
> > > Thanks!
> > > Jenny
> > > "freddy" wrote:
> > > > Jenny,
> > > > 2. "Update Driver"
> > > > freddy
> > > > > update.
Old 05-12-2008   #8 (permalink)
Newbie
vista home 32 bit
Re: No Audio Output Device Installed
Happened to me a few days ago. I tried reinstalling drivers, bios change etc. nothing worked.
This site worked for me:
http://www.mydigitallife.info/2007/0...audio-problem/
Display Modes
No Audio Output Device is Installed. Chanderjeet Rai Vista music pictures video 20 12-09-2008 10:22 PM
No Audio Output Device is Installed. JimG Vista General 3 10-06-2007 11:35 PM
Audio Output Device Not Installed trainsteve Vista hardware & devices 2 08-18-2007 12:18 PM
No Audio Output Device is installed lostazndork Vista hardware & devices 1 04-17-2007 01:58 AM
no audio output device installed acornsometime Vista installation & setup 1 10-22-2006 11:20 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
