Vista - LaCie drive: I installed LaCie-drive and now icon is missing
Old 06-22-2007   #1 (permalink)
PieterPaulus
june 22, 2007
Hello and Good Day. I bought a new PC and installed a LaCie drive; Now the
LaCie ICON is MISSING. How can I get the icon back??
I followed the steps on the Lacie website (" To change the drive icon:
# Do “Get Info” (command i) on both the hard drive and the icon file.
# The icon for each will show in the upper left corner of the “Get Info”
window.) but that doesn't work. (Command i ???).
I think they wrote it for Windows XP.
Who can help me pls?
Thanks from PieterPaulus.
Old 06-23-2007   #2 (permalink)
IscaComps
RE: LaCie drive: I installed LaCie-drive and now icon is missing
Hi
It could be that .ico file is either corrupt or missing. Normally all you
need is an icon file (.ico) situated at the root of the drive/cd/dvd to
enable a logo.
"PieterPaulus" wrote:
> june 22, 2007
Old 06-26-2007   #3 (permalink)
PieterPaulus
Hello IscaComps,
Thanks for your answer. Can you pls. explain to me how do I ' situated at
the root of the drive/cd/dvd to enable a logo'. I'm not so 'into computers'.
Thanks in advance; Good day!
PieterPaulus.
"IscaComps" wrote:
> Hi
> enable a logo.
> > june 22, 2007
Old 07-11-2007   #4 (permalink)
PieterPaulus
Hello IscaComps,
PieterPaulus.
I also asked LaCie but unfortunately they cannot help me because they say
they don't know the way Vista handles this. Grrr.
> Hello IscaComps,
> PieterPaulus.
> "IscaComps" wrote:
> > Hi
> > enable a logo.
> > > june 22, 2007
problem with lacie 1tb nas Vista General
Lacie two big, Photoshop and eSATA Vista hardware & devices
missing hard drive C (local drive) icon Vista General
LaCie Ethernet disk and Vista Vista networking & sharing
Lacie Ethernet Disk 1TB and Vista???? Vista hardware & devices
Designer Media Ltd
