| Guest | Dual Monitors don't keep settings after startup I have connected an Eizo screen on the left hand side of my Dell laptop. When I startup Windows Vista the Eizo screen is the primary one for like 1 second. When the startup process is complete the screen of my laptop, somehow, automatically becomes the primary one. This is very annoying and means that every time I reboot my machine I need to go into Display Settings and change the settings so that the Eizo is considered the primary one. So, I want Windows to remember this setting after re-boot. But it doesn't. Any ideas how to change this? I have tried to delete the Eizo screen in the Device manager and then re-installing it. That didn't help. |
| Senior Member | Re: Dual Monitors don't keep settings after startup could be a problem with the video card drivers, try getting the lastest ones from the manufacturer´s website. post info about your computer |
| Guest | RE: Dual Monitors don't keep settings after startup I have the same problem... Not that it helps you, but I look forward to seeing what you find out. It's really a pain! "Joel" wrote: > I have connected an Eizo screen on the left hand side of my Dell laptop. When > I startup Windows Vista the Eizo screen is the primary one for like 1 second. > When the startup process is complete the screen of my laptop, somehow, > automatically becomes the primary one. > > This is very annoying and means that every time I reboot my machine I need > to go into Display Settings and change the settings so that the Eizo is > considered the primary one. > > So, I want Windows to remember this setting after re-boot. But it doesn't. > Any ideas how to change this? > > I have tried to delete the Eizo screen in the Device manager and then > re-installing it. That didn't help. |
| Senior Member | Re: Dual Monitors don't keep settings after startup if you have an NVIDIA video card try this Alienware : The Best Custom Built Gaming PC for the Ultimate PC Gamer! |
| retaining display settings on dual monitors | Vista installation & setup | |||
| settings changed - 3 monitors - maximises window across all 3 monitors instead of 1 | Vista performance & maintenance | |||
| Dual monitor display settings revert on startup | Vista General | |||
| Using Dual Monitors - Won't Retain Settings | Vista General | |||
| Using Dual Monitors - Won't Retain Settings | Vista hardware & devices | |||
