| | Some extended keys (Calculator) do not work on Wireless Natural Multimedia Keyboard under Vista (32 bit) Hello. I have Wireless Natural Multimedia Keyboard; it works great under XP Professional on same machine (it is dual-boot machine) but some of keys (very important, Calculator key for example) does not work under Vista Enterprise 32 bit. Details about configuration: OS: Vista Enterprise 32 bit with all latest Windows Update patches installed Keyboard: Microsoft Wireless Natural Multimedia Keyboard attached to PS/2 port Software: IntelliType Pro 6.1 (latest from http://www.microsoft.com/hardware/mo.../Download.mspx) Registry: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\i8042prt\Start = 1 HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\kbdhid\Start = 4 Any idea how this can be resolved? -- Regards, Dejan Vesić MCAD for .Net technology Home: http://www.vesic.org/english/ |
| | RE: Some extended keys (Calculator) do not work on Wireless Natural Mu DejanVesic, Hardware not functioning properly is most likely caused by driver issues. The following is a link to a Microsoft article for troubleshooting keyboard problems: http://support.microsoft.com/default.aspx/kb/258826 Oftentimes, hardware issues can be resolved by installing the latest drivers, if any are available. -- freddy "DejanVesic" wrote: > Hello. > > I have Wireless Natural Multimedia Keyboard; it works great under XP > Professional on same machine (it is dual-boot machine) but some of > keys (very important, Calculator key for example) does not work under > Vista Enterprise 32 bit. > > Details about configuration: > > OS: Vista Enterprise 32 bit with all latest Windows Update patches > installed > > Keyboard: Microsoft Wireless Natural Multimedia Keyboard attached to > PS/2 port > > Software: IntelliType Pro 6.1 (latest from > http://www.microsoft.com/hardware/mo.../Download.mspx) > > Registry: > > HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\i8042prt\Start = > 1 > HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\kbdhid\Start = 4 > > Any idea how this can be resolved? > > -- > Regards, > Dejan Vesić > > MCAD for .Net technology > Home: http://www.vesic.org/english/ > > |
| | Re: Some extended keys (Calculator) do not work on Wireless Natural Mu > Hardware not functioning properly is most likely caused by driver issues. > The following is a link to a Microsoft article for troubleshooting keyboard > problems: > > http://support.microsoft.com/default.aspx/kb/258826 > > Oftentimes, hardware issues can be resolved by installing the latest > drivers, if any are available. I forgot in last post that I tried all above before; MsKey do not show that Calculator key is even pressed. Also, I can't find any newer drivers than those on Windows Update / IntelliType Pro 6.1. Regards, Dejan Vesić MCAD for .Net technology Home:http://www.vesic.org/english/ > -- > freddy > > "DejanVesic" wrote: > > Hello. > > > I have Wireless Natural Multimedia Keyboard; it works great under XP > > Professional on same machine (it is dual-boot machine) but some of > > keys (very important, Calculator key for example) does not work under > > Vista Enterprise 32 bit. > > > Details about configuration: > > > OS: Vista Enterprise 32 bit with all latest Windows Update patches > > installed > > > Keyboard: Microsoft Wireless Natural Multimedia Keyboard attached to > > PS/2 port > > > Software: IntelliType Pro 6.1 (latest from > >http://www.microsoft.com/hardware/mo.../Download.mspx) > > > Registry: > > > HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\i8042prt\Start = > > 1 > > HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\kbdhid\Start = 4 > > > Any idea how this can be resolved? > > > -- > > Regards, > > Dejan Vesić > > > MCAD for .Net technology > > Home:http://www.vesic.org/english/ |
| | Re: Some extended keys (Calculator) do not work on Wireless Natura DejanVesic, It's OK to forget. I often forget to include information. From what you say, it seems you will need to wait for new drivers, or some other unknown fix, to correct the problem. -- freddy "DejanVesic" wrote: > > Hardware not functioning properly is most likely caused by driver issues. > > The following is a link to a Microsoft article for troubleshooting keyboard > > problems: > > > > http://support.microsoft.com/default.aspx/kb/258826 > > > > Oftentimes, hardware issues can be resolved by installing the latest > > drivers, if any are available. > > I forgot in last post that I tried all above before; MsKey do not show > that Calculator key is even pressed. Also, I can't find any newer > drivers than those on Windows Update / IntelliType Pro 6.1. > > Regards, > Dejan Vesić > > MCAD for .Net technology > Home:http://www.vesic.org/english/ > > > -- > > freddy > > > > "DejanVesic" wrote: > > > Hello. > > > > > I have Wireless Natural Multimedia Keyboard; it works great under XP > > > Professional on same machine (it is dual-boot machine) but some of > > > keys (very important, Calculator key for example) does not work under > > > Vista Enterprise 32 bit. > > > > > Details about configuration: > > > > > OS: Vista Enterprise 32 bit with all latest Windows Update patches > > > installed > > > > > Keyboard: Microsoft Wireless Natural Multimedia Keyboard attached to > > > PS/2 port > > > > > Software: IntelliType Pro 6.1 (latest from > > >http://www.microsoft.com/hardware/mo.../Download.mspx) > > > > > Registry: > > > > > HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\i8042prt\Start = > > > 1 > > > HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\kbdhid\Start = 4 > > > > > Any idea how this can be resolved? > > > > > -- > > > Regards, > > > Dejan Vesić > > > > > MCAD for .Net technology > > > Home:http://www.vesic.org/english/ > > > |
| Wireless Natural Multimedia Keyboard, No volume control? | Vista hardware & devices | |||
| Microsoft Natural Keyboard 4000 Keys Repeating | Vista hardware & devices | |||
| Problem with microsoft natural multimedia keyboard 1.0A | Vista General | |||
| MS Natural Keyboard 4000 F keys... | Vista hardware & devices | |||
| Logitech keyboard multimedia keys not working in Vista | Vista hardware & devices | |||
