| | Problem with Samsung 226BW monitor? I recently bought this Samsung monitor and am running Vista Home Premium. There is a 2"white/grey streak running vertically down the center of the monitor especially visible on a black background. Can anyone tell me if this is a sign of backlight failure or is it a graphics card issue? TIA |
| | RE: Problem with Samsung 226BW monitor? radski, It's hard to say what is causing this problem. It could be a monitor issue, a driver issue, or even a graphics card issue. Try contacting Samsung support for possible explanation. Samsung may have seen this issue before and know exactly what the problem is. You can also try using google to see what others may have to say about this. Just some thoughts. -- freddy "radski" wrote: > I recently bought this Samsung monitor and am running Vista Home Premium. > There is a 2"white/grey streak running vertically down the center of the > monitor especially visible on a black background. Can anyone tell me if this > is a sign of backlight failure or is it a graphics card issue? > > TIA > |
| | Re: Problem with Samsung 226BW monitor? radski wrote: > I recently bought this Samsung monitor and am running Vista Home Premium. > There is a 2"white/grey streak running vertically down the center of the > monitor especially visible on a black background. Can anyone tell me if this > is a sign of backlight failure or is it a graphics card issue? > > TIA > The easy way to find out if the problem is with your monitor or your computer is to connect another computer to the monitor. If you see the same problem, you know it's the monitor. If the problem doesn't exist on another computer, you know it's your computer and probably a failing graphics card. Malke -- Elephant Boy Computers www.elephantboycomputers.com "Don't Panic!" MS-MVP Windows - Shell/User |
| | Re: Problem with Samsung 226BW monitor? "radski" <radski@community.nospam> wrote in message news:3363EA43-11DD-40F1-A92F-A63C74D67FE2@microsoft.com... >I recently bought this Samsung monitor and am running Vista Home Premium. > There is a 2"white/grey streak running vertically down the center of the > monitor especially visible on a black background. Can anyone tell me if > this > is a sign of backlight failure or is it a graphics card issue? > > TIA > Have you tried changing the refresh setting? Right click on the desktop and choose Personalize, choose Display Settings, Advanced Settings, click on the Monitor tab at the top, now change he refresh settings. 60 is usually safe. ;0) Captain Roberts |
| | RE: Problem with Samsung 226BW monitor? Hello, How's everything going? I think Malke provided a good idea, you may follow his way to determine what the cause is. Based on my experience, this problem is related to monitor. I recommend you to contact the hardware vendor to solve. If you have any concerns, please feel free to let me know. Thanks & Regards, Mike Luo Microsoft Online Partner Support Get Secure! - www.microsoft.com/security ===================================================== When responding to posts, please "Reply to Group" via your newsreader so that others may learn and benefit from your issue. ===================================================== This posting is provided "AS IS" with no warranties, and confers no rights. |
| | #6 (permalink) |
| | Re: Problem with Samsung 226BW monitor? radski wrote: > I recently bought this Samsung monitor and am running Vista Home Premium. > There is a 2"white/grey streak running vertically down the center of the > monitor especially visible on a black background. Can anyone tell me if this > is a sign of backlight failure or is it a graphics card issue? > > TIA > I'm running one of these monitors and it's superb, especially coming from a 19" CRT with an 8" blurry section down the centre. Did you install the drivers for the monitor or play with the brightness / colour settings? That said I didn't notice a band down the centre of the display using the default monitor drivers found in Vista so it could be a faulty monitor. |
| Samsung T220 Monitor | Drivers | |||
| Samsung DLP via VGA as second monitor? | Graphic cards | |||
| Samsung 226BW with 8800GTS - Magictune doesn't work | Graphic cards | |||
| Windows Explorer and Samsung 913v monitor problem | Vista hardware & devices | |||
| Help with my Samsung 913t LCD monitor, please ... | Vista hardware & devices | |||
