Vista Tutorial - wireless desktop problems
Old 06-29-2007   #1 (permalink)
celfyddydau
Guest
My keyboard and mouse are now playing up. They were fine for a couple of
days after installing VISTA.
I have a Microsoft Wireless Comfort Keyboard and the accompanying optical
mouse.
Problems include mouse freezing
Mouse not going where I am trying to point it
Keyboard repeating a letter even if the letter has been lightly touched and
by this I mean
rrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
Keyboard not printing a pressed letter
Backspace deleting 2 -3 lines of text when only pressed long enough to take
out one or two letters.
I have been into the settings and altered them to the lowest repeat etc
I have also been into the drivers to update them but they report back as up
to date
And I have pressed the reset buttons so many times it feels like it's after
every letter. This is an intermitent problem, in that it might be fine for a
while and then jsut decide to go whacky. Time ranging from PC switching on to
having been on a couple of hours.
Any ideas or similar problems? BTW I have just moved the reciever to see
if that helps. I have also been on MS site to look for drivers but it
doesn't give a UK English language option just a US one
Old 06-29-2007   #2 (permalink)
freddy
Guest
RE: wireless desktop problems
celfyddydau,
It seems that you have already done all the troubleshooting you can do, but
just to make sure, check out this Microsoft troubleshooting guide for
keyboards:
http://support.microsoft.com/default.aspx/kb/258826
Improper functioning of hardware almost always is caused by something
incompatible with the drivers, but it's sometimes hard to be sure. If you
can't resolve your issue, try contacting Microsoft directly for help. You
can learn how to make the contact by visiting the Microsoft website and
looking for contact information.
freddy
> mouse.
> by this I mean
> to date
Old 07-05-2007   #3 (permalink)
djollie111
Guest
I have the same wireless desktop combo set and am glad/mad that someone else
has an issue - at least it's not just me. Have you downloaded the most
recent Intellipoint/Intellitype software? Go to microsoft's hardware site to
get it: http://www.microsoft.com/hardware/wi...a/support.mspx
The thing is, for this particular set, you need to get both Intellipoint 6.1
AND Intellitype 6.1 (be sure to uninstall previous versions first).
But, don't get your hopes up. My keyboard and mouse still just lose the
connection without warning, sometimes locks up vista, and all the time Vista
will not shut down - I have to do a forced power down. Luckily, I am on a
laptop and the touchpad/keyboard still work when this happens. I think this
is a compatibility/driver issue with Vista. The set works fine on my XP
system.
Hope I will find something that works.
> mouse.
> by this I mean
> to date
Problems Reinstalling Wireless Desktop 6000 V.20 Set Drivers
problems connecting wireless desktop pc to belkin g router Network & Sharing
Sporadic Wireless Laser Desktop 6000 Problems Vista hardware & devices
Problems with a Linksys wireless card on a desktop computer Vista networking & sharing
Problems with a Linksys wireless card on a desktop computer. Vista hardware & devices
