Vista - 32-bit color not working
Old 07-02-2007   #1 (permalink)
ALEX
My computer defaults the color quality to 16-bit when i put my computer on
1440x900 resolution. When i change it back to 32-bit, it goes to a lower
resolution. I do not know why.
Old 07-02-2007   #2 (permalink)
babaloo
Re: 32-bit color not working
How much memory does your video card have?
Old 07-02-2007   #3 (permalink)
freddy
RE: 32-bit color not working
ALEX,
The resolution that you can obtain depends upon the interaction between the
capabilities of the graphics card and its drivers and the capabilities of the
monitor.
That is, graphics cards and their drivers are made to produce a certain
range of resolutions. Likewise, a monitor is made to be able to accept a
certain range of resolutions.
Therefore, you need to know what the capabilities are of your graphics card
as well as that of your monitor.
For instance, a LCD monitor is usually made to run best at it so called
native resolution. For example, a 17" LCD monitor typically has a native
resolution or 1280 x 1024, 32 bit. Therefore, a user should set the
resolution to match that requirement. If his graphics card is not capable of
doing this, he should upgrade to a card that can.
It follows, then, that you must know the capabilities and requirements of
your graphics system to be able to settle your issue. Also, graphics card
drivers can become out of date, and updating to the latest drivers can
resolve problems. In order to do this update, you need to know the name
(ATI, nVidia, Intel, etc.) and model number (like ATI 9600 AGP) of you
graphics card.
freddy
Old 07-02-2007   #4 (permalink)
Richard Urban
That is a function of the capabilities of your video card and the drivers.
Regards,
Richard Urban
"ALEX" <ALEX@discussions.microsoft.com> wrote in message
news:5E0051EA-436A-49F3-B442-FC4398C705F3@microsoft.com...
Old 07-02-2007   #5 (permalink)
ALEX
it has 128 mb dedicated memory.
HP Color LaserJet 2840 Scanner not working Vista hardware & devices
Built-in color selection (eyedropper) tool not working anywhere Vista General
HP Color Laser Jet stopped working Vista print fax & scan
Can't change Color of pages using color/appearance Vista installation & setup
Not all color names give right color? PowerShell
