| | M-Audio Firewire Audio Drivers Good news to those who own an M-Audio Firewire Series sound card. Drivers (Beta) are finally available for Vista. Steve |
| Ultimate x64 | Re: M-Audio Firewire Audio Drivers Since 25 March 2008, x64 firewire audio drivers are available for m-audio beta testers. Does anyone have any ideea on where to download those drivers ? I need them badly... My Firewire Solo dosen't work at all under x64. |
| | Re: M-Audio Firewire Audio Drivers SP1 has better support for firewire. "86C415" <86C415.37r730@xxxxxx-mx.forums.net> wrote in message news:86C415.37r730@xxxxxx-mx.forums.net... Quote: > > Since 25 March 2008, x64 firewire audio drivers are available for > m-audio beta testers. > > Does anyone have any ideea on where to download those drivers ? > > I need them badly... My Firewire Solo dosen't work at all> under x64. > > > -- > 86C415 |
| uLTIMATE | Re: M-Audio Firewire Audio Drivers Does anybody know when the drivers will be available to the public ? Did they leak to the web already ? |
| Vista Business x64 | Re: M-Audio Firewire Audio Drivers There is an easy solution to make FW Solo drivers for WinXP64 work in Vista X64: you need to enable unsigned driver loading. You can do so using EasyBCD utility, see attached screenshot. I don't use any audio production software and can't say anything about system stability, but now i hear music using foobar2000 with ASIO output plugin and it works for me just fine. Good luck! And sorry for my english ![]() Added: For those who have Vista SP1 installed, option described above doesn't work anymore. You need to use something like this tool http://www.ngohq.com/home.php?page=dseo There are instruction how to use Driver Signature Enforcement Overrider and download link for this tool. You need enable test mode and sign following system file: YourWindowsDir\system32\drivers\deltafw.sys Last edited by darkmad; 07-30-2008 at 01:02 PM.. Reason: Additional information |
| | #6 (permalink) |
| Vista 32 SP1 | Re: M-Audio Firewire Audio Drivers Help! I just bought an M-Audio Firewire Solo, and I'm trying to print 24-bit mixes from my 02R coaxial SPDIF out to the SPDIF in on the M-Audio interface. I have selected the "external clock" option from the M-Audio hardware control panel, and I can record the mixes through the interface. Problem is, every 30 seconds or so, a little "tick" or "pop" gets recorded along with the audio - it definitely sounds like a clock issue. I have tried both sets of drivers (ASIO and WDM), and have set the buffer size as high as possible... I still have the problem. I've downloaded the latest VISTA 32-bit drivers from the M-Audio website, so I know I'm using the right drivers. And the problem is not the SPDIF output, which prints just fine to a Tascam CD-burner I have. The problem seems like it's that the SPDIF clock won't slave properly. It's close, but I can't have POPs in my audio every 30-40 seconds. Ideas? I thought Firewire was supposed to be the solution to everything! I just bought this unit to replace an M-Audio USB interface that had the same problem. Please help! DAVID |
| Virtual Pc 07/Firewire Audio Interface | Vista General | |||
| Audio drivers for Intel Sigmatel onboard audio | Vista hardware & devices | |||
| If you have a HP Laptop and No Audio Drivers/Audio Problems | Vista hardware & devices | |||
| Vista Beta 2 - Audio / Sound Drivers - Universal Audio Architectur | Vista hardware & devices | |||
