Vista - monitor issue
Old 06-23-2006   #1 (permalink)
Tony
monitor issue
I installed vista beta 2:
Intel p4 3.2 GHZ
2048 mb ram
3x 160 GB HDD Maxtor
nvidia 6800 128 mb
monitor, IIyama HM903DAT
the problem is the my screen keeps turning on and off.
I also installed the latest nvidia driver.
My PC is dual boot and under windows XP there is no problem with the screen.
Old 06-23-2006   #2 (permalink)
JW
Re: monitor issue
Are you using the NVIDIA Vista Beta Drivers?
http://www.nvidia.com/object/winvista_x86_88.61.html
"Tony" <Tony@discussions.microsoft.com> wrote in message
news:B919F1C7-282B-49A2-96E2-9191B4865BFB@microsoft.com...
> Intel p4 3.2 GHZ
> 2048 mb ram
> nvidia 6800 128 mb
> screen.
Old 06-23-2006   #3 (permalink)
Tony
Re: monitor issue
Yes i did, both put of the box ore the newest driver from nvidia. Both have
the same problem. And my screen is good sinds windows xp dos not give me any
trouble.
> > Intel p4 3.2 GHZ
> > 2048 mb ram
> > nvidia 6800 128 mb
> > screen.
Old 06-23-2006   #4 (permalink)
HDRDTD
Re: monitor issue
Dumb question perhaps, but have you checked your display settings to make
sure the resolution and refresh rates are within the specs for your monitor
and it's not just trying to display but can't because of improper settings,
so it reset's itself and trys again, etc..
> Intel p4 3.2 GHZ
> 2048 mb ram
> nvidia 6800 128 mb
> screen.
Old 06-23-2006   #5 (permalink)
Tony
Re: monitor issue
Good, point. It dos indeed give this error. But the resolutions are far below
max. the HM903DTA can do 1600*1200 @ 100 hz it runs on 1280*1024 @ 85 hz (
max is 1280*1024 @ 120 hz
> > Intel p4 3.2 GHZ
> > 2048 mb ram
> > nvidia 6800 128 mb
> > screen.
Another Multiple monitor issue Graphic cards
Monitor blinking issue Graphic cards
Monitor Issue Graphic cards
Dual Monitor Issue Vista hardware & devices
Monitor issue or full instal issue Vista installation & setup
