Yes... I did, I ran the driver Vista_R159.exe file
(...\Drivers\windows\audio\Vista\Vista_R159.exe), I went through the
installation, and when it finished it said, "Maintenance Complete
InstallShield Wizard has finished performing maintenance operations on
Realtek High Definition Audio Driver.
(-) Yes, I want to restart my computer now.
( ) No, I will restart my computer late.
Remove any disks from their drive, and then click Finish to complete setup."
I selected Yes, and pressed finish, restarted, then logged back in and still
nothing, it still said, "No Audio Output Device Installed"
The 2nd time I attempted to install this driver I used, "Run as
Administrator," same results
"freddy" wrote:
> Scrtcwlvl,
> Usually, a driver that you download and unzip includes a setup.exe file.
> That's the installer. You launch that file by double clicking it and then it
> installs the driver automatically for you. Are you sure you don't have such
> a file, or something similar, to install that driver?
> freddy
> "Scrtcwlvl" wrote:
> > I am looking for a possible option that allows me to solve it without
> > spending a large amount of money, if I had to at all about $20. The sound
> > controller works on XP Pro x64, but my wireless adapter doesn't. So I am
> > stuck between XP Pro x64 which has Audio, but no internet, and Vista, which
> > as internet but no audio.
> > "freddy" wrote:
> > > Scrtcwlvl,
> > > A correction for the Creative link:
> > > http://us.creative.com/
> > > freddy
> > > "Scrtcwlvl" wrote:
> > > > I did contact Sun support, I was told "Perhaps ask Microsoft? (It's their OS
> > > > that has the issue.)"
> > > > "freddy" wrote:
> > > > > Scrtcwlvl,
> > > > > Contact Sun Support and tell them about your problem. They should have an
> > > > > answer for you.
> > > > > freddy
> > > > > "Scrtcwlvl" wrote:
> > > > > > When I installed Vista Ultimate onto my Sun Ultra 20 Workstation it did not
> > > > > > have drivers for my audio controller (The default one on an Ultra 20
> > > > > > Workstation) nor could it find them. I went onto sun.com and searched for the
> > > > > > ultra 20 drivers,
> > > > > > I downloaded "Sun Ultra 20 M2 Workstation Tools & Drivers CD 1.6A"
> > > > > > Containing "Sun Ultra 20 M2 Workstation Tools & Drivers CD 1.6A
> > > > > > Image Contents:
> > > > > > * Bios Version 1.45.0
> > > > > > * Graphics, Chipset and Audio Drivers
> > > > > > * Drivers for Windows Server 2003 and Windows Vista (NEW!)
> > > > > > * PC-Check Diagnostic Program"
> > > > > > I ran the install for the Vista Audio drivers twice, restarted, nothing. I
> > > > > > opened device manager and had it search in the folder I extracted all the
> > > > > > files to for the audio drivers, Windows said no drivers were found.
> > > > > > This is the only problem I have had with vista, everything else I throw at
> > > > > > it works fine.
> > > > > > What should I do?
