Vista - Lan Not Recognized in Vista Ultimate - Fresh Installation
Old 07-12-2007   #1 (permalink)
danoco
Vista is not recognizing my lan device. The motherboard is an Asus K8V Deluxe.
Vista does not find the driver from the motherboard installation CD. Anyone
have a solution?
Old 07-12-2007   #2 (permalink)
freddy
RE: Lan Not Recognized in Vista Ultimate - Fresh Installation
danocok,
Likely the driver on the motherboard installation CD is not Vista
compatible. Note the name of your NIC card and find the Vista compatible
driver on the Internet, likely at the motherboard manufacturer's website, and
download and install that. I suppose you'll have to use another computer to
do that.
freddy
> have a solution?
VISTA Ultimate fresh reformat clean Installation failure - hangs... Vista installation & setup
fresh clean Vista Installation FAILURE General Discussion
Why does a fresh Vista installation create a partition at LBA 2048 ? Vista General
I can't update, : Fresh vista installation. Windows Updates
Vista Crash/Freeze from fresh installation -_-;; Vista General
