| | Please help! Installed new motherboard... Vista won't load.. I installed new motherboard, ram and CPU.. all vista compatible. Now Vista won't load. I tried to load from DVD to do a repair. All that happens is it sits at the blue curtian thing after the windows logo bar that says loading. What do I have to do? Why won't Vista load? Do I have to do a clean install? IF I have to do a clean install how do I do that... Please I am frusterated... I am needing some immediate help with this.. I have been at is for at least 6 hours now... |
| | Re: Please help! Installed new motherboard... Vista won't load.. When you changed the mb that changed everything for Vista. If a repair wont' work you may have to reinstall. Ikeyre wrote: > I installed new motherboard, ram and CPU.. all vista compatible. Now Vista > won't load. I tried to load from DVD to do a repair. All that happens is it > sits at the blue curtian thing after the windows logo bar that says loading. > > What do I have to do? Why won't Vista load? Do I have to do a clean > install? IF I have to do a clean install how do I do that... > > Please I am frusterated... I am needing some immediate help with this.. I > have been at is for at least 6 hours now... |
| | RE: Please help! Installed new motherboard... Vista won't load.. Ikeyre, You may find the following helpful. The following link contains information on how to do a repair, a reinstall, and a clean install: http://www.windowsreinstall.com/ Find the Vista link (near top left) and go from there. -- freddy "Ikeyre" wrote: > I installed new motherboard, ram and CPU.. all vista compatible. Now Vista > won't load. I tried to load from DVD to do a repair. All that happens is it > sits at the blue curtian thing after the windows logo bar that says loading. > > What do I have to do? Why won't Vista load? Do I have to do a clean > install? IF I have to do a clean install how do I do that... > > Please I am frusterated... I am needing some immediate help with this.. I > have been at is for at least 6 hours now... |
| | Re: Please help! Installed new motherboard... Vista won't load.. Hi, The repair option just fixes the boot configuration. Ikeyre has changed the hardware that Vista was installed under and will require a fresh installation to rebuild the system files to match. Unlike XP, there is no 'repair installation' to (re)install on top of an existing install. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "freddy" <fkirschen@tidalwave.net> wrote in message news:788C3C9F-AB21-49F2-94FE-7F10591304EF@microsoft.com... > Ikeyre, > > If you want to do a repair install, you have to boot to the Vista DVD, not > the Vista on the hard drive. You set the 1st boot device (CD/DVD-ROM > drive) > in BIOS. After booting to the Vista DVD, you then select the proper > option > for repair. > -- > freddy > > > "Ikeyre" wrote: > >> I installed new motherboard, ram and CPU.. all vista compatible. Now >> Vista >> won't load. I tried to load from DVD to do a repair. All that happens >> is it >> sits at the blue curtian thing after the windows logo bar that says >> loading. >> >> What do I have to do? Why won't Vista load? Do I have to do a clean >> install? IF I have to do a clean install how do I do that... >> >> Please I am frusterated... I am needing some immediate help with this.. I >> have been at is for at least 6 hours now... |
| | Re: Please help! Installed new motherboard... Vista won't load.. Rick, I realized that issue later, so I posted the instructions below after my above comment. -- freddy "Rick Rogers" wrote: > Hi, > > The repair option just fixes the boot configuration. Ikeyre has changed the > hardware that Vista was installed under and will require a fresh > installation to rebuild the system files to match. Unlike XP, there is no > 'repair installation' to (re)install on top of an existing install. > > -- > Best of Luck, > > Rick Rogers, aka "Nutcase" - Microsoft MVP > http://mvp.support.microsoft.com/ > Windows help - www.rickrogers.org > My thoughts http://rick-mvp.blogspot.com > > "freddy" <fkirschen@tidalwave.net> wrote in message > news:788C3C9F-AB21-49F2-94FE-7F10591304EF@microsoft.com... > > Ikeyre, > > > > If you want to do a repair install, you have to boot to the Vista DVD, not > > the Vista on the hard drive. You set the 1st boot device (CD/DVD-ROM > > drive) > > in BIOS. After booting to the Vista DVD, you then select the proper > > option > > for repair. > > -- > > freddy > > > > > > "Ikeyre" wrote: > > > >> I installed new motherboard, ram and CPU.. all vista compatible. Now > >> Vista > >> won't load. I tried to load from DVD to do a repair. All that happens > >> is it > >> sits at the blue curtian thing after the windows logo bar that says > >> loading. > >> > >> What do I have to do? Why won't Vista load? Do I have to do a clean > >> install? IF I have to do a clean install how do I do that... > >> > >> Please I am frusterated... I am needing some immediate help with this.. I > >> have been at is for at least 6 hours now... > > |
| Motherboard fried, new motherboard, oh oh disk driver issues, blue screen rebooty time! | Vista General | |||
| Activation fails after having installed new motherboard. | Vista installation & setup | |||
| ASUS P5N32 SLI DELUXE Motherboard will not load Vista | Vista hardware & devices | |||
| GDI software cannot load unless it has win Media 9 installed | Vista General | |||
| Vista installed but dont load | Vista installation & setup | |||
