Vista Forums Home Join Vista Forums Windows 7 help and support Forum Windows 8 Forum Vista Tutorials
Go Back   Vista Forums > Vista Newsgroup Archive > Vista Newsgroups > Vista hardware & devices
Vista - Vista 64bit audio driver problems
07-15-2007   #1 (permalink)
aalaptop
I have just build a new PC running Windows Vista home premium 64bit and I can
not get the audio drivers to work. The motherboard is a ASrock
ALiveSATA2-GLAN and it has realtek HD intergraded sound. I have downloaded
every driver version that I can find and everytime i try to install one I get
the blue screen with white writing. The sound card comes up as 'Unknown
device' in the device manager. I have tried everything i know to try and fix
it with no luck. This motherboard is suppose to support vista but I cant even
get the sound card to work, any new ideas?
07-15-2007   #2 (permalink)
vista ultimate 64
Re: Vista 64bit audio driver problems
have you run the windows update and with the realtek hd driver you need to get the latest driver from realtek or it will bsod
Realtek
07-15-2007   #3 (permalink)
aalaptop
> 'Realtek'
> (http://www.realtek.com.tw/downloads/...&GetDown=false)
> chinga69
> CHEERS CHINGA69
hi, i just finally figured it out, after 6 hours, it needed a bios update. i
didnt think of this because i kept getting windows errors. thanks for the
help anyway, i hope this helps anyone else with the same problem
 Vista 64bit audio driver problems problems?
Similar topics to: Vista 64bit audio driver problems
I have dual boot PC [VISTA 32BIT & 64BIT]---problems only in 64bit vista drivers Drivers
Audio driver problems. Drivers
SigmaTel High Definition Audio Codec 64bit Driver Needed Drivers
Realtek Audio = BSOD/Driver Problems (Vista Ultimate 64) Sound & Audio
Conexant HD Audio Driver problems Vista hardware & devices
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
