Vista - Mouse Problem
Old 07-16-2007   #1 (permalink)
Martin Racette
Mouse Problem
On this computer, we are three user witheach our user account,but the mouse
keep it's setting on only one account, on the other two we have to reset the
mouse configuration every time (we are all lefties)
What can I do to make the setting for left-handed stick to all account, and
also the motion settings
Thank You in Advance
Merci a l'avance
Martin
Old 07-18-2007   #2 (permalink)
Rishi
Re: Mouse Problem
Hello,
Are all of the accounts admin accounts? I suppose there might be a rule set
so as to only allow admin accounts to keep their settings and certain types
of accounts to discard them. Try to find out if your computer has such a
rule.
Rishi
email: rishi@vista-news.com | web: http://vista-news.com
"Martin Racette" <rat7_2001@hotmail.com> wrote in message
news:7A280651-158F-45BC-BCD0-85724A841BD6@microsoft.com...
> Hi,
> mouse keep it's setting on only one account, on the other two we have to
> reset the mouse configuration every time (we are all lefties)
> and also the motion settings
> Merci a l'avance
> Martin
Old 07-20-2007   #3 (permalink)
Daniel
Re: Mouse Problem
did you find a fix for this problem, I have the same problem?
thanks
Daniel
> Hi,
> Merci a l'avance
> Martin
Old 07-20-2007   #4 (permalink)
Martin Racette
Re: Mouse Problem
No, I haven't yet found a solution
"Daniel" <noone@nowhere.com> wrote in message
news:OV4xS9vyHHA.5584@TK2MSFTNGP02.phx.gbl...
> thanks
> Daniel
>> Hi,
>> Merci a l'avance
>> Martin
Merci a l'avance
Martin
Old 07-23-2007   #5 (permalink)
JW
Re: Mouse Problem
Do all accounts have administrator rights? If not temporarily change them
one at a time and try setting the mouse parameters and then remove the
administrator rights afterwards after rebooting/restarting while the account
is in use.
news:C6CA0680-603F-40DC-9787-429B7CF5FAF1@microsoft.com...
>> thanks
>> Daniel
>>> Hi,
>>> Merci a l'avance
>>> Martin
> Merci a l'avance
> Martin
Old 07-23-2007   #6 (permalink)
Martin Racette
Re: Mouse Problem
Two of the account are with administrative right and other isn't. My account
is with Administrative rights and so is another, in mine Vista do remember
that the mouse is left-handed, but not in the other
"JW" <JW@nospam.nspam> wrote in message
news:0E1CBC17-ADF7-4A45-BA0A-02DBFE20BFFF@microsoft.com...
> account is in use.
>>> thanks
>>> Daniel
>>>> Hi,
>>>> to reset the mouse configuration every time (we are all lefties)
>>>> Merci a l'avance
>>>> Martin
>> Merci a l'avance
>> Martin
Merci a l'avance
Martin
Old 07-23-2007   #7 (permalink)
JW
Re: Mouse Problem
In general changes are not saved till you do a normal shutdown or restart of
your computer. So if in the other administrator account after changing the
mouse setting you do a shutdown or restart while still in that account is
the change still not saved?
news:2ABAA1DE-4B92-4197-85AF-06B2B6D8D9C3@microsoft.com...
> account is with Administrative rights and so is another, in mine Vista do
> remember that the mouse is left-handed, but not in the other
>> them one at a time and try setting the mouse parameters and then remove
>> the administrator rights afterwards after rebooting/restarting while the
>> account is in use.
>>>> thanks
>>>> Daniel
>>>>> Hi,
>>>>> account, and also the motion settings
>>>>> Merci a l'avance
>>>>> Martin
>>> Merci a l'avance
>>> Martin
> Merci a l'avance
> Martin
Old 07-25-2007   #8 (permalink)
Martin Racette
Re: Mouse Problem
That is exactly what's happening, when I restart if I log into any of the
other account but mine all of the mouse settings are lost, and I have to
redo them all over again
news:77C456E3-9965-405F-AD04-581CBEDA89FE@microsoft.com...
> of your computer. So if in the other administrator account after changing
> the mouse setting you do a shutdown or restart while still in that account
> is the change still not saved?
>>> account is in use.
>>>>> thanks
>>>>> Daniel
>>>>>> Hi,
>>>>>> Merci a l'avance
>>>>>> Martin
>>>> Merci a l'avance
>>>> Martin
>> Merci a l'avance
>> Martin
Merci a l'avance
Martin
Old 08-05-2007   #9 (permalink)
minkokiss
Re: Mouse Problem
> other account but mine all of themousesettingsare lost, and I have to
> "JW" <J...@nospam.nspam> wrote in message
> > In general changes arenotsavedtill you do a normal shutdown or restart
> > themousesetting you do a shutdown or restart while still in that account
> > is the change stillnotsaved?
> > "Martin Racette" <rat7_2...@hotmail.com> wrote in message
> >> account is with Administrative rights and so is another, in mineVistado
> >> remember that themouseis left-handed, butnotin the other
> >>> Do all accounts have administrator rights? Ifnottemporarily change
> >>> them one at a time and try setting themouseparameters and then remove
> >>> account is in use.
> >>>> "Daniel" <no...@nowhere.com> wrote in message
> >>>>> thanks
> >>>>> Daniel
> >>>>>> Hi,
> >>>>>>mousekeep it's setting on only one account, on the other two we have
> >>>>>> to reset themouseconfiguration every time (we are all lefties)
> >>>>>> account, and also the motionsettings
> >>>>>> Merci a l'avance
> >>>>>> Martin
> >>>> Merci a l'avance
> >>>> Martin
> >> Merci a l'avance
> >> Martin
> Merci a l'avance
> Martin
I have the exact same issue. Tried with couple different wireless and
wired mice on the same computer, checked drivers, software. group
policy , anything you can think of and still no luck. As soon as I log
off my mouse settings are reset!!!! Please if anybody knows what
causes that it will be very very helpful. I am running Vista Business
and my current Wireless Desktop Set is Microsoft Natural Desktop 7000.
Any help will be greatly appreciated.
Best Regards,
Minko Kissiov
Old 08-05-2007   #10 (permalink)
JW
Re: Mouse Problem
How about if instead of logging off you just go to shutdown?
"minkokiss" <minkokiss@gmail.com> wrote in message
news:1186300818.217947.104230@j4g2000prf.googlegroups.com...
>> > changing
>> > account
>> >> mineVistado
>> >>> remove
>> >>> the
>> >>> account is in use.
>> >>>>> thanks
>> >>>>> Daniel
>> >>>>>> Hi,
>> >>>>>> the
>> >>>>>>have
>> >>>>>> Merci a l'avance
>> >>>>>> Martin
>> >>>> Merci a l'avance
>> >>>> Martin
>> >> Merci a l'avance
>> >> Martin
>> Merci a l'avance
>> Martin
> Best Regards,
> Minko Kissiov
Mouse Problem General Discussion
MOUSE PROBLEM Vista General
Mouse problem General Discussion
Help me: mouse problem Vista General
Mouse problem Vista General
