| | Primary Monitor switching Before I went out of town last week for business I had my monitors setup the way i wanted them for primary and secondary. A flat screen as my primary and my laptop as secondary. When I came back the primary and secondary had switched to my laptop being primary and my flat screen as secondary. Under the settings tab in the Display Properties window the 'Use this device as the primary monitor.' is grayed out for both and it won't let me switch them. Any suggestions on how to fix it or switch my primary back? |
| | RE: Primary Monitor switching Hi, Have you tried rebooting? Any error messages in Device Manager? -- freddy "knucklehead" wrote: > Before I went out of town last week for business I had my monitors setup the > way i wanted them for primary and secondary. A flat screen as my primary and > my laptop as secondary. When I came back the primary and secondary had > switched to my laptop being primary and my flat screen as secondary. Under > the settings tab in the Display Properties window the 'Use this device as the > primary monitor.' is grayed out for both and it won't let me switch them. > Any suggestions on how to fix it or switch my primary back? |
| | RE: Primary Monitor switching Hi, I found this multiple monitor troubleshooting guide on the Internet: http://www.microsoft.com/technet/pro....mspx?mfr=true Determine whether the guide has anything useful for you. -- freddy "knucklehead" wrote: > Before I went out of town last week for business I had my monitors setup the > way i wanted them for primary and secondary. A flat screen as my primary and > my laptop as secondary. When I came back the primary and secondary had > switched to my laptop being primary and my flat screen as secondary. Under > the settings tab in the Display Properties window the 'Use this device as the > primary monitor.' is grayed out for both and it won't let me switch them. > Any suggestions on how to fix it or switch my primary back? |
| | RE: Primary Monitor switching Hi, again, I've been searching the Internet on this problem, and it seems you are not alone. Do you use an nVidia graphics card by any chance? A lot of the dual monitor problems I'm seeing on the Internet seem to involve nVidia products. Updating to the latest video card drivers, regardless of manufacturer, may be beneficial. It's usually a driver problem when hardware doesn't function properly, though there are exceptions. For instance, does you problem usually occur when coming out of sleep, standby, or hibernate mode? If so, that could be a sign of a problem apart from video card drivers. Just some thoughts. -- freddy "knucklehead" wrote: > Before I went out of town last week for business I had my monitors setup the > way i wanted them for primary and secondary. A flat screen as my primary and > my laptop as secondary. When I came back the primary and secondary had > switched to my laptop being primary and my flat screen as secondary. Under > the settings tab in the Display Properties window the 'Use this device as the > primary monitor.' is grayed out for both and it won't let me switch them. > Any suggestions on how to fix it or switch my primary back? |
| | RE: Primary Monitor switching Since you said this I remembered I had a "Physical System Dump" occur twice on my computer last week. I wounder if this has anything to do with it. My IS department is looking into this. "freddy" wrote: > Hi, again, > > I've been searching the Internet on this problem, and it seems you are not > alone. Do you use an nVidia graphics card by any chance? A lot of the dual > monitor problems I'm seeing on the Internet seem to involve nVidia products. > Updating to the latest video card drivers, regardless of manufacturer, may be > beneficial. It's usually a driver problem when hardware doesn't function > properly, though there are exceptions. For instance, does you problem > usually occur when coming out of sleep, standby, or hibernate mode? If so, > that could be a sign of a problem apart from video card drivers. Just some > thoughts. > -- > freddy > > > "knucklehead" wrote: > > > Before I went out of town last week for business I had my monitors setup the > > way i wanted them for primary and secondary. A flat screen as my primary and > > my laptop as secondary. When I came back the primary and secondary had > > switched to my laptop being primary and my flat screen as secondary. Under > > the settings tab in the Display Properties window the 'Use this device as the > > primary monitor.' is grayed out for both and it won't let me switch them. > > Any suggestions on how to fix it or switch my primary back? |
| | #6 (permalink) |
| | Re: Primary Monitor switching "knucklehead" <knucklehead@discussions.microsoft.com> wrote in message news:C4144D85-76EE-4F2E-9F69-4639628E215A@microsoft.com... > Before I went out of town last week for business I had my monitors setup > the > way i wanted them for primary and secondary. A flat screen as my primary > and > my laptop as secondary. When I came back the primary and secondary had > switched to my laptop being primary and my flat screen as secondary. > Under > the settings tab in the Display Properties window the 'Use this device as > the > primary monitor.' is grayed out for both and it won't let me switch them. > Any suggestions on how to fix it or switch my primary back? Did you take your laptop out of town with you? If you used your laptop without the external monitor connected Windows had no choice but to take your setup back to default and make the laptop monitor the primary monitor. Makes sense doesn't it? If you can uncheck the "Extend the desktop onto this monitor" for the external monitor... do that and start over. Might work. |
| | #7 (permalink) |
| | Re: Primary Monitor switching It makes sense. I've taken my laptop with me hundreds of times before but never had this problem when I'm back in the office. I've tried the external thing but it doesn't work either. I've tried picking different setups in the BIOS on start up as well. I've narrowed it down to being caused by a "physical system dump" my laptop did on me twice last week. A co-worker on site had the samething happen to their laptop as well. I'm going to try to restore back to a date before the system dump and see if that helps. "DanR" wrote: > > "knucklehead" <knucklehead@discussions.microsoft.com> wrote in message > news:C4144D85-76EE-4F2E-9F69-4639628E215A@microsoft.com... > > Before I went out of town last week for business I had my monitors setup > > the > > way i wanted them for primary and secondary. A flat screen as my primary > > and > > my laptop as secondary. When I came back the primary and secondary had > > switched to my laptop being primary and my flat screen as secondary. > > Under > > the settings tab in the Display Properties window the 'Use this device as > > the > > primary monitor.' is grayed out for both and it won't let me switch them. > > Any suggestions on how to fix it or switch my primary back? > > Did you take your laptop out of town with you? If you used your laptop > without the external monitor connected Windows had no choice but to take > your setup back to default and make the laptop monitor the primary monitor. > Makes sense doesn't it? If you can uncheck the "Extend the desktop onto this > monitor" for the external monitor... do that and start over. Might work. > > |
| | #8 (permalink) |
| | RE: Primary Monitor switching I figured it out. I went into the BIOS when my copmuter was starting and set everything back to default. With my computer in its docking station it now uses my monitor as the default and my laptop as my secondary. I'm assuming it has to do with changing the display settings in BIOS. I haven't rebooted to look at the change. "knucklehead" wrote: > Before I went out of town last week for business I had my monitors setup the > way i wanted them for primary and secondary. A flat screen as my primary and > my laptop as secondary. When I came back the primary and secondary had > switched to my laptop being primary and my flat screen as secondary. Under > the settings tab in the Display Properties window the 'Use this device as the > primary monitor.' is grayed out for both and it won't let me switch them. > Any suggestions on how to fix it or switch my primary back? |
| VMs wont start after changing primary monitor | Virtual PC | |||
| Primary Monitor will not always come out of sleep mode. | General Discussion | |||
| Switching my primary display | PowerShell | |||
| Set primary display (monitor) | PowerShell | |||
| Please read, cross post: dim primary monitor | Vista hardware & devices | |||
