Vista - USB Hard Drive Write Protect Error
Old 07-22-2007   #1 (permalink)
Michael Gerbasio
I'm running Vista x64 on a T61 notebook. I have a Western Digital Passport
usb hard drive. I need to copy files larger than allowed by FAT32 so using
my WinXP Pro desktop I shrunk the existing FAT32 partition, created a new
partition, formatted it as NTFS.
Using any WinXP PC, I have no problems accessing the NTFS partition on the
hard drive. However, using Vista, I can read the partition, but not write to
it. When I try to write to the NTFS partition, I get an error saying the
drive is write protected. Any idea how I can fix this problem? Thanks.
Regards-Michael G.
Old 07-23-2007   #2 (permalink)
freddy
RE: USB Hard Drive Write Protect Error
Michael,
Since you're not getting any action on this, I though I'd throw out a
suggestion to consider. Try partitioning and formatting the drive in Vista
using Disk Management. Just a thought that maybe Vista doesn't recognize
something about WinXP's way of doing things.
Also, does your USB port provide sufficient power for the hard drive. Try
using an external power source, if you're not already doing so. Laptops
sometimes provide little power to USB ports to conserve battery. Just some
thoughts.
freddy
"Michael Gerbasio" wrote:
> Hi,
> Regards-Michael G.
Old 07-23-2007   #3 (permalink)
Michael Gerbasio
Re: USB Hard Drive Write Protect Error
Freddy,
Thanks for the suggestion. I didn't even bother with disk manager because I
couldn't format from explorer. I tried it in disk manager, it formatted and
is working now.
Regards-Michael G.
"freddy" <fkirschen@tidalwave.net> wrote in message
news:1CAF4033-AB74-40F7-95B7-8E4A4FD36458@microsoft.com...
> Michael,
> Vista
> some
> thoughts.
> freddy
>> Hi,
>> Passport
>> using
>> the
>> to
>> Regards-Michael G.
Old 05-19-2009   #4 (permalink)
Ultimate x64
Had the same problem.
the solution was disable write caching on the usb hdd in device manager.
You can choose in the disk propeties for optimize for quick removal or optimize for performance. CHOOSE optimize for quick removal.
Hard Drive is Write Protected? Vista General
write protect error exception processing message Vista security
Drive being recognized incorrectly as write protect. Vista hardware & devices
very slow hard drive write speed Vista hardware & devices
Hard drive write protected Vista General
