Jnorge,
First, you must look in Device Manager to confirm that the CD/DVD-ROM drive
is working. Right click Computer (formerly My Computer) and select
Properties. In the upper left corner, select Device Manager. In Device
Manager, notice whether DVD/CD-ROM Drives shows a problem, like a red X, or
some other indication of a problem. Unfold DVD/CD-ROM Drives and right click
the drive and then select Properties. In the window that opens, you should
see the words This device is working properly. If you see some indication of
a problem, then you must resolve the problem before you can continue.
If Device Manager has no problem with the drive, then you should open
Windows Explorer, as explained earlier. In Windows Explorer find your burner
drive. It will be shown as DVD/CD-RW Drive (D) (that's your burner drive),
or something similar to that. Now follow my previous instructions. Report
back.
freddy
"Jnorge" wrote:
> Hi Freddy,
> Thank you so much for your help. In fact I am in my office now with a big
> problem since that I need to have access for some file that they are in CD
> but mine DVD+RW/CDRW Internal Combro Drive not work.
> Well, I do not understand about computer very, but I see that your
> instructions below are easy to follow. Anyway, I have read "Now right click
> the burner drive and select Paste...". Sorry, but I think that I do not have
> "Burner Drive" since this do not show in my system. Sorry, but could you
> continue helping me until solving this? How I make to have access to "burner
> drive"?
> Thanks,
> Jnorge
> "freddy" wrote:
> > Jnorge,
> > Check whether Device Manager shows a problem with the drive or whether it
> > shows that the drive is working properly. If Device Manager indicates that
> > the drive is working, try using Windows built-in burning capability, just as
> > a test to see what happens.
> > Here is how you do that. Use Windows Explorer (Start > All Programs >
> > Accessories). In Windows Explorer, copy a file, like in Documents, by right
> > clicking it and selecting Copy. Now right click the burner drive and select
> > Paste. The file should appear in the right pane opposite the burner drive.
> > Right click the file and select Properties. Note where the file is located.
> > Windows stashes files until you're ready to burn all of them. Now, right
> > click the burner drive and select Burn to Disk (words to that effect). If
> > everything is working, the file should be burned to disk. Now right click
> > the file, (in the right pane) and note its location. It should be on the
> > disk. If it is, then the drive burn function is working. Just something to
> > try.
> > In addition, check the CD/DVD area in Control Panel to select those options
> > you need to obtain the behavior you expect when you insert a disk into the
> > drive. Sometimes you have to uncheck Auto Play to get the results you are
> > looking for. For more detailed information on how to manage these functions,
> > look in the Windows Help and Support feature under Start. Launch the feature
> > and search on burn CD, or burn DVD, or on anything you want to know. These
> > functions are a little tricky until you get used to using them.
> > freddy
> > "Jnorge" wrote:
> > > Hello,
> > > I have bought a new "DVD+RW/CDRW Internal Combro Drive GX620 SX280 X300 M65"
> > > through eBay (eBay item number #220128391831) for my Dell OptiPlex 745 Ultra
> > > Small Form Factor *Vista System.
> > > After I to receive this I only plug drive in the desktop and Windows Vista
> > > installed automatically a software. The problem is I simply do NOT get to
> > > have access to the driver and I do not get to see this in my micro. I already
> > > placed some CD's and DVD´s but nothing happened.
> > > Please, tell me what I must doing?
> > > Thanks,
