Vista - advanced hard drive power managment
Old 08-01-2007   #1 (permalink)
jush
I have multiple hard drives. Does Vista have some kind of hdd power
management tool where I can turn them off and on while running Vista
Old 08-01-2007   #2 (permalink)
JW
Re: advanced hard drive power managment
Using advanced Power settings in Control Panel you can have HDDs turn off
after a set period of time of non-use.
"jush" <jush@discussions.microsoft.com> wrote in message
news:E4894BA1-8614-4876-8140-A62F51F96979@microsoft.com...
Old 08-01-2007   #3 (permalink)
jush
Can I use different settings with each drive and does Vista turn hard drives
completely off. I'm concerned about the noise, heat and power consumption and
whats the minimal time delay for turning hard drive off after non-use? As I
understand when I try to access the hard disk it turns on again. Are you able
to turn this function off. I'm thinking about equivalent to hard on/off like
hot-swap but purely by software
Old 08-01-2007   #4 (permalink)
JW
As best I can tell it uses the same setting for all drives, however, it only
turns drives off that you are not using it does not turn off ones in use.
news:CBEE8807-72C0-4C7B-8016-2F71CC2FDDB2@microsoft.com...
> drives
> and
> I
> able
> like
Old 08-14-2007   #5 (permalink)
D.Thomas
how can u disable the power management on ur hard drive cuz my second hd
keeps turning off and on. i want it to stay on.
Old 08-15-2007   #6 (permalink)
JW
If using the Control Panel set the HDD turn off time in advanced settings to
"NEVER".
Some HDD's especially those designed for RAID systems will spin down to a
lower power use settings when not in use. Check the specs for your drive.
"D.Thomas" <D.Thomas@discussions.microsoft.com> wrote in message
news:3472CF9B-9C52-4AEC-AF09-EBC776C1C801@microsoft.com...
Useful tool for power enthusiasts on the go (advanced power options) General Discussion
PC Power Managment Program Overclocking & Cooling
Enable Advanced Performance for the Hard Drive Vista hardware & devices
Power Options and Hard Drive Vista General
DVD-drive power managment Vista hardware & devices
