Vista Tutorial - ZyDAS Wifi problem. can't seem to fix it
Old 08-02-2007   #1 (permalink)
Newbie
Windows Vista
Hello,
I have a major problem with the Wifimax ZyDAS dongle.
OS: vista 32bit
My normal internet connection does work correctly.
I do have the new driver from the site of codejunkies. the ZyDAS icon does appear in my status bar. It also appears in the Connections section. But there it says it isn't connected. I tried everything, but it seems my pc thinks that if I try to turn it on, he needs to connect to this acces point... But I want it to be an acces point for my ds and wii. When I try to connect my ds to it, it gives a signal at first, but than dies out with the error "unable to obtain IP address" So I think my wireless connection is not connected to the internet on my pc.
Can somebody tell me exact what to do, so that it will work?
I somebody please wants to tell me from start till end.
Thankyou.
Old 08-03-2007   #2 (permalink)
Newbie
Windows Vista
Re: ZyDAS Wifi problem. can't seem to fix it
Help, anybody?
Old 08-03-2007   #3 (permalink)
Barb Bowman
Guest
see
http://www.wiichat.com/nintendo-wii-...c-network.html
sounds like you need to setup an adhoc network between the wireless
and the device(s) and then bridge to the wired lan adapter in the
computer.
My recommendation is to buy a router.
On Thu, 2 Aug 2007 16:12:22 -0500, Dream
<Dream.2upir8@no-mx.forums.net> wrote:
>Hello,
>OS: vista 32bit
>I -do- have the new driver from the site of codejunkies. the ZyDAS icon
>-does -appear in my status bar. It also appears in the Connections
>to this acces point... But I want it to -be- an acces point for my ds
>Thankyou.
Barb Bowman
MS Windows-MVP
http://www.microsoft.com/windowsxp/e...ts/bowman.mspx
http://blogs.digitalmediaphile.com/barb/
ZyDAS ZD1211 WiFi dongle not working Vista hardware & devices
Zydas major problem Drivers
Atheros, ZYdas, USB wireless adapter drivers Vista General
Atheros, ZYdas, USB wireless adapter drivers Vista hardware & devices
wifi problem Vista networking & sharing
