Vista Tutorial - Installing a printer on wireless home network
Old 08-03-2007   #1 (permalink)
ccook
Guest
I am trying to install a printer on my new Toshiba with Vistas home edition.
The printer is attached to another computer (with XP) and there is a wireless
Linksys router that provides the home network. The laptop identifies the
printer (sees it through the residential gateway) when I view computers and
devices in the Network and Sharing centre but doesn't find it when I try to
Add a Printer. Help?
Old 08-03-2007   #2 (permalink)
BigJim
Guest
Re: Installing a printer on wireless home network
if vista doesn't have the drivers for the printer you are out of luck.
check the printer manufacture site for drivers.
"ccook" <ccook@discussions.microsoft.com> wrote in message
news:AF11845E-9D87-4425-BF8C-B1E83CB38577@microsoft.com...
>edition.
> wireless
> and
> to
Old 09-20-2007   #3 (permalink)
Kim [MS]
Guest
RE: Installing a printer on wireless home network
ccook,
Perhaps this article is a good place to start, if it's not a driver issue:
http://windowshelp.microsoft.com/Win...1dc451033.mspx
Vista says my home network wireless is a hidden network Network & Sharing
Can't see other Computer on Network after installing network printer Vista networking & sharing
installing hp 8180 (wireless) printer to vista Vista print fax & scan
Problem with Network printer over wireless network. Vista print fax & scan
Network Printer and Wireless Network problem Vista installation & setup
