| | #11 (permalink) |
| | Re: Install UPS (uninterruptable power supply) in Vista John, Interesting, the Serial UPS that I tried had no drivers included with it, the user interface depended on the native operating system drivers. (XP had native serial and UPS drivers). My current USB UPS (say that five times fast) is dependent on the native 'batteries' driver. Just as a point of curiosity does your UPS show up in Device Manager? (Mine is labeled 'batteries). When checking Microsoft knowledge bases they said Vista did not support Serial. Perhaps the OP should continue to try, starting at the manufactures site to check for Vista drivers as well as user interface. (CyberPower battery backup, Vista(32) Home Premium) Michael "John" <noaddress@noaddress.invalid> wrote in message news:eMqRMh81HHA.5160@TK2MSFTNGP05.phx.gbl... > > "Michael" <mexxwalraven@verson.net> wrote in message > news 6498746-8317-4077-ABC5-8B9D1CEE541F@microsoft.com...>> Vista will not use a com port for a UPS. (XP would) >> You will need to get a UPS that uses USB. >> (been there done that grrrr.) >> >> Michael > > Not necessarily true. > My Vista 64 installation recognizes my APC Smart-UPS 1400, > which uses a serial port, via the APC software just fine. > > |
| | #12 (permalink) |
| | Re: Install UPS (uninterruptable power supply) in Vista Yes, the APC software should work. It's Vista's built-in power management that won't work with serial ports. "John" <noaddress@noaddress.invalid> wrote in message news:eMqRMh81HHA.5160@TK2MSFTNGP05.phx.gbl... > > "Michael" <mexxwalraven@verson.net> wrote in message > news 6498746-8317-4077-ABC5-8B9D1CEE541F@microsoft.com...>> Vista will not use a com port for a UPS. (XP would) >> You will need to get a UPS that uses USB. >> (been there done that grrrr.) >> >> Michael > > Not necessarily true. > My Vista 64 installation recognizes my APC Smart-UPS 1400, > which uses a serial port, via the APC software just fine. > > |
| | #13 (permalink) |
| | Re: Install UPS (uninterruptable power supply) in Vista "Michael" <mexxwalraven@verson.net> wrote in message news:FB4BA15E-043E-401E-BD05-B5CEF4828D30@microsoft.com... > Just as a point of curiosity does your UPS show up in Device Manager? > (Mine is labeled 'batteries). It does not show up in device manager. The APC software installs a driver to communicate with the UPS. On XP the first thing the driver installation did was to disable XP's built-in UPS feature. I don't remember if that happened on Vista but I suspect that it did. |
| | #14 (permalink) |
| | Re: Install UPS (uninterruptable power supply) in Vista On Aug 4, 7:42 pm, AlecR <Al...@discussions.microsoft.com> wrote: > Has anyone tried one of those cables that coverts serial to usb. If this is > plugged into a USB port, would Vista recognise the UPS as being connected to > USB? UPS uses serial port status lines such as Clear to Send and Carrier Detect to send signals to the computer. UPS is told to shutdown using Data Terminal Ready status line. How are these handshake signals carried on a USB port? Obviously if not, then USB port on Vista could not see those handshaking signals. To understand why USB converter does nothing useful, one would understand simple serial port functions and how USB works. |
| Power Supply or Vista Bug? | General Discussion | |||
| When shut down Vista, must disconnect the power supply and reconnect before booting | General Discussion | |||
| Major Troubles: Power Supply or Corrupt Install?? | Vista General | |||
| Has Windows Vista it’s own UPS (Un-interrupted Power Supply) softw | Vista General | |||
| USB power supply issue causes BSOD but only during Vista boot! | Vista General | |||
