| | Install UPS (uninterruptable power supply) in Vista Hi All, I am trying to install my UPS in Vista Ultimate. It connects to the com port to monitor the power and configure shut down options. .. In XP I could configure it in Control Panel/Power options. I've searched Vista and can't find where to configure it. Any suggestions welcome. Regards |
| | Re: Install UPS (uninterruptable power supply) in Vista I don't believe Vista support serial port UPSes, only USB port UPSes. -- Richard G. Harper [MVP Shell/User] rgharper@gmail.com * NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/ * PLEASE post all messages and replies in the newsgroups * The Website - http://rgharper.mvps.org/ * HELP us help YOU ... http://www.dts-l.org/goodpost.htm "AlecR" <AlecR@discussions.microsoft.com> wrote in message news:03944F4F-6B65-4236-B935-6B868D50A8C3@microsoft.com... > Hi All, > > I am trying to install my UPS in Vista Ultimate. It connects to the com > port > to monitor the power and configure shut down options. > . > In XP I could configure it in Control Panel/Power options. > > I've searched Vista and can't find where to configure it. > > Any suggestions welcome. > > Regards |
| | Re: Install UPS (uninterruptable power supply) in Vista Vista will not use a com port for a UPS. (XP would) You will need to get a UPS that uses USB. (been there done that grrrr.) Michael "AlecR" <AlecR@discussions.microsoft.com> wrote in message news:03944F4F-6B65-4236-B935-6B868D50A8C3@microsoft.com... > Hi All, > > I am trying to install my UPS in Vista Ultimate. It connects to the com > port > to monitor the power and configure shut down options. > . > In XP I could configure it in Control Panel/Power options. > > I've searched Vista and can't find where to configure it. > > Any suggestions welcome. > > Regards |
| | Re: Install UPS (uninterruptable power supply) in Vista The UPS will still work till the battery runs down. You just can't control the options. In fact, you don't even need to connect the parallel cable at all. I have the same problem. I will live with it till it goes bad and needs to be replaced. -- Regards, Richard Urban Microsoft MVP Windows Shell/User (For email, remove the obvious from my address) "AlecR" <AlecR@discussions.microsoft.com> wrote in message news:03944F4F-6B65-4236-B935-6B868D50A8C3@microsoft.com... > Hi All, > > I am trying to install my UPS in Vista Ultimate. It connects to the com > port > to monitor the power and configure shut down options. > . > In XP I could configure it in Control Panel/Power options. > > I've searched Vista and can't find where to configure it. > > Any suggestions welcome. > > Regards |
| | Re: Install UPS (uninterruptable power supply) in Vista Has anyone tried one of those cables that coverts serial to usb. If this is plugged into a USB port, would Vista recognise the UPS as being connected to USB? "Richard Urban" wrote: > The UPS will still work till the battery runs down. You just can't control > the options. In fact, you don't even need to connect the parallel cable at > all. > > I have the same problem. I will live with it till it goes bad and needs to > be replaced. > > -- > > > Regards, > > Richard Urban > Microsoft MVP Windows Shell/User > (For email, remove the obvious from my address) > > "AlecR" <AlecR@discussions.microsoft.com> wrote in message > news:03944F4F-6B65-4236-B935-6B868D50A8C3@microsoft.com... > > Hi All, > > > > I am trying to install my UPS in Vista Ultimate. It connects to the com > > port > > to monitor the power and configure shut down options. > > . > > In XP I could configure it in Control Panel/Power options. > > > > I've searched Vista and can't find where to configure it. > > > > Any suggestions welcome. > > > > Regards > > |
| | #6 (permalink) |
| | Re: Install UPS (uninterruptable power supply) in Vista Tried that with a geek squad UPS from Best buy, did not work for me. Appeared to make the USB port on the computer look like a serial port rather that make the serial port on the UPS look like a USB port. Michael "AlecR" <AlecR@discussions.microsoft.com> wrote in message news C894747-69DE-48B5-A724-B5C4255D9778@microsoft.com...> Has anyone tried one of those cables that coverts serial to usb. If this > is > plugged into a USB port, would Vista recognise the UPS as being connected > to > USB? > > > "Richard Urban" wrote: > >> The UPS will still work till the battery runs down. You just can't >> control >> the options. In fact, you don't even need to connect the parallel cable >> at >> all. >> >> I have the same problem. I will live with it till it goes bad and needs >> to >> be replaced. >> >> -- >> >> >> Regards, >> >> Richard Urban >> Microsoft MVP Windows Shell/User >> (For email, remove the obvious from my address) >> >> "AlecR" <AlecR@discussions.microsoft.com> wrote in message >> news:03944F4F-6B65-4236-B935-6B868D50A8C3@microsoft.com... >> > Hi All, >> > >> > I am trying to install my UPS in Vista Ultimate. It connects to the com >> > port >> > to monitor the power and configure shut down options. >> > . >> > In XP I could configure it in Control Panel/Power options. >> > >> > I've searched Vista and can't find where to configure it. >> > >> > Any suggestions welcome. >> > >> > Regards >> >> |
| | #7 (permalink) |
| | Re: Install UPS (uninterruptable power supply) in Vista No you have to install the drivers for those (convertor) cables and then you do have a serial port which can be addressed. Ko "AlecR" <AlecR@discussions.microsoft.com> schreef in bericht news C894747-69DE-48B5-A724-B5C4255D9778@microsoft.com...> Has anyone tried one of those cables that coverts serial to usb. If this > is > plugged into a USB port, would Vista recognise the UPS as being connected > to > USB? > > > "Richard Urban" wrote: > >> The UPS will still work till the battery runs down. You just can't >> control >> the options. In fact, you don't even need to connect the parallel cable >> at >> all. >> >> I have the same problem. I will live with it till it goes bad and needs >> to >> be replaced. >> >> -- >> >> >> Regards, >> >> Richard Urban >> Microsoft MVP Windows Shell/User >> (For email, remove the obvious from my address) >> >> "AlecR" <AlecR@discussions.microsoft.com> wrote in message >> news:03944F4F-6B65-4236-B935-6B868D50A8C3@microsoft.com... >> > Hi All, >> > >> > I am trying to install my UPS in Vista Ultimate. It connects to the com >> > port >> > to monitor the power and configure shut down options. >> > . >> > In XP I could configure it in Control Panel/Power options. >> > >> > I've searched Vista and can't find where to configure it. >> > >> > Any suggestions welcome. >> > >> > Regards >> >> |
| | #8 (permalink) |
| | Re: Install UPS (uninterruptable power supply) in Vista All the USB to Serial converter does is create a new serial port - which Vista still will not support for plugging the UPS into. So no, it won't work. -- Richard G. Harper [MVP Shell/User] rgharper@gmail.com * NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/ * PLEASE post all messages and replies in the newsgroups * The Website - http://rgharper.mvps.org/ * HELP us help YOU ... http://www.dts-l.org/goodpost.htm "AlecR" <AlecR@discussions.microsoft.com> wrote in message news C894747-69DE-48B5-A724-B5C4255D9778@microsoft.com...> Has anyone tried one of those cables that coverts serial to usb. If this > is > plugged into a USB port, would Vista recognise the UPS as being connected > to > USB? > > > "Richard Urban" wrote: > >> The UPS will still work till the battery runs down. You just can't >> control >> the options. In fact, you don't even need to connect the parallel cable >> at >> all. >> >> I have the same problem. I will live with it till it goes bad and needs >> to >> be replaced. >> >> -- >> >> >> Regards, >> >> Richard Urban >> Microsoft MVP Windows Shell/User >> (For email, remove the obvious from my address) >> >> "AlecR" <AlecR@discussions.microsoft.com> wrote in message >> news:03944F4F-6B65-4236-B935-6B868D50A8C3@microsoft.com... >> > Hi All, >> > >> > I am trying to install my UPS in Vista Ultimate. It connects to the com >> > port >> > to monitor the power and configure shut down options. >> > . >> > In XP I could configure it in Control Panel/Power options. >> > >> > I've searched Vista and can't find where to configure it. >> > >> > Any suggestions welcome. >> > >> > Regards >> >> |
| | #9 (permalink) |
| | Re: Install UPS (uninterruptable power supply) in Vista Oops. I meant the serial cable. <grin> -- Regards, Richard Urban Microsoft MVP Windows Shell/User (For email, remove the obvious from my address) "Richard Urban" <richardurbanREMOVETHIS@hotmail.com> wrote in message news:u1fVnNr1HHA.1100@TK2MSFTNGP06.phx.gbl... > The UPS will still work till the battery runs down. You just can't control > the options. In fact, you don't even need to connect the parallel cable at > all. > > I have the same problem. I will live with it till it goes bad and needs to > be replaced. > > -- > > > Regards, > > Richard Urban > Microsoft MVP Windows Shell/User > (For email, remove the obvious from my address) > > "AlecR" <AlecR@discussions.microsoft.com> wrote in message > news:03944F4F-6B65-4236-B935-6B868D50A8C3@microsoft.com... >> Hi All, >> >> I am trying to install my UPS in Vista Ultimate. It connects to the com >> port >> to monitor the power and configure shut down options. >> . >> In XP I could configure it in Control Panel/Power options. >> >> I've searched Vista and can't find where to configure it. >> >> Any suggestions welcome. >> >> Regards > |
| | #10 (permalink) |
| | Re: Install UPS (uninterruptable power supply) in Vista "Michael" <mexxwalraven@verson.net> wrote in message news 6498746-8317-4077-ABC5-8B9D1CEE541F@microsoft.com...> Vista will not use a com port for a UPS. (XP would) > You will need to get a UPS that uses USB. > (been there done that grrrr.) > > Michael Not necessarily true. My Vista 64 installation recognizes my APC Smart-UPS 1400, which uses a serial port, via the APC software just fine. |
| Power Supply or Vista Bug? | General Discussion | |||
| When shut down Vista, must disconnect the power supply and reconnect before booting | General Discussion | |||
| Major Troubles: Power Supply or Corrupt Install?? | Vista General | |||
| Has Windows Vista it’s own UPS (Un-interrupted Power Supply) softw | Vista General | |||
| USB power supply issue causes BSOD but only during Vista boot! | Vista General | |||
