| Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks. |
| | LinkBack | Thread Tools | Display Modes |
| Guest | Monitor resolution I have HP PC which has a Nvidea geforce 7500 LE display adapter, at present I'm running a normal ratio monitor at 1280 x 1024 but am considering going widescreen, can anybody tell me what sort of resolution this adapter can handle, I don't want to waste my money on something that won't work properly? Phil |
| Guest | Re: Monitor resolution The 7500LE is an OEM-only model, not sold at retail, which makes it a little harder to find specific information. (www.hp.com may offer some as part of the specs of your system. It would have been useful for you to post the model number.) The release notes on the latest Vista drivers: http://us.download.nvidia.com/Window...ease_Notes.pdf state that the 7500LE will support resolutions up to 2048X1536. 1920X1200 is included explicitly. These don't include the 1440X900 and 1680X1050 that are common for 19" and 22" widescreen monitors, but I expect that card will support them with drivers ( really just a .inf file) from the monitor's manufacturer. (The modes aren't listed for the Geforce 8 series cards either, which are the latest and greatest models.) Don't buy a 30" (2560X1600) monitor to use with it, as the 7500LE doesn't have the special DVI connector (dual link, which is not the same as having two DVI connectors) to drive it at full resolution. Return address scrambled. Replace nkbob with bobkn. "Phil" <p.tann@talk21.com> wrote in message news:OgZoqWy1HHA.1208@TK2MSFTNGP03.phx.gbl... >I have HP PC which has a Nvidea geforce 7500 LE display adapter, at present >I'm running a normal ratio monitor at 1280 x 1024 but am considering going >widescreen, can anybody tell me what sort of resolution this adapter can >handle, I don't want to waste my money on something that won't work >properly? > > Phil > |
| Guest | Re: Monitor resolution Thanks for reply, my PC is T3729 UK if that's any help?, Phil. "Bob Knowlden" <nkbob@comcast.net> wrote in message news:%23z6EOb31HHA.600@TK2MSFTNGP05.phx.gbl... > The 7500LE is an OEM-only model, not sold at retail, which makes it a > little harder to find specific information. (www.hp.com may offer some as > part of the specs of your system. It would have been useful for you to > post the model number.) > > The release notes on the latest Vista drivers: > > http://us.download.nvidia.com/Window...ease_Notes.pdf > > state that the 7500LE will support resolutions up to 2048X1536. 1920X1200 > is included explicitly. These don't include the 1440X900 and 1680X1050 > that are common for 19" and 22" widescreen monitors, but I expect that > card will support them with drivers ( really just a .inf file) from the > monitor's manufacturer. (The modes aren't listed for the Geforce 8 series > cards either, which are the latest and greatest models.) > > Don't buy a 30" (2560X1600) monitor to use with it, as the 7500LE doesn't > have the special DVI connector (dual link, which is not the same as having > two DVI connectors) to drive it at full resolution. > > Return address scrambled. Replace nkbob with bobkn. > > "Phil" <p.tann@talk21.com> wrote in message > news:OgZoqWy1HHA.1208@TK2MSFTNGP03.phx.gbl... >>I have HP PC which has a Nvidea geforce 7500 LE display adapter, at >>present I'm running a normal ratio monitor at 1280 x 1024 but am >>considering going widescreen, can anybody tell me what sort of resolution >>this adapter can handle, I don't want to waste my money on something that >>won't work properly? >> >> Phil >> > |
| Guest | Re: Monitor resolution Giving the model ought to be more help than it is. ;-) HP offers some Vista drivers for that model; they appear to be nVidia drivers, version 98.16. (I haven't seen those before.) Only the standard resolutions are listed, but I'm pretty certain that the normal widescreen LCD resolutions (1440X900 and 1680X1050) would be no problem. (1920X1200 is listed, but monitors that support that are 24" or larger, and still somewhat expensive.) HP does not appear to offer any .inf files for download for their monitors for Vista. I suppose that means that they aren't necessary. I would have liked to offer perfect certainty that your graphics card will correctly drive ordinary widescreen monitors. I think that you shouldn't worry, though. Bob Kn. "Phil" <p.tann@talk21.com> wrote in message news:%237dIHb61HHA.1188@TK2MSFTNGP04.phx.gbl... > Thanks for reply, my PC is T3729 UK if that's any help?, > > Phil. > > (snip) |
| Guest | Re: Monitor resolution Thanks for the advice, Phil. "Bob Knowlden" <nkbob@comcast.net> wrote in message news:ul5IFxJ2HHA.5360@TK2MSFTNGP03.phx.gbl... > Giving the model ought to be more help than it is. ;-) > > HP offers some Vista drivers for that model; they appear to be nVidia > drivers, version 98.16. (I haven't seen those before.) > > Only the standard resolutions are listed, but I'm pretty certain that the > normal widescreen LCD resolutions (1440X900 and 1680X1050) would be no > problem. (1920X1200 is listed, but monitors that support that are 24" or > larger, and still somewhat expensive.) > > HP does not appear to offer any .inf files for download for their monitors > for Vista. I suppose that means that they aren't necessary. > > I would have liked to offer perfect certainty that your graphics card will > correctly drive ordinary widescreen monitors. I think that you shouldn't > worry, though. > > Bob Kn. > > > "Phil" <p.tann@talk21.com> wrote in message > news:%237dIHb61HHA.1188@TK2MSFTNGP04.phx.gbl... >> Thanks for reply, my PC is T3729 UK if that's any help?, >> >> Phil. >> >> > (snip) |
| Display Modes | |
| Monitor Resolution and Bit Settings Keep changing | Byron | Vista hardware & devices | 2 | 07-16-2008 10:47 AM |
| Monitor resolution | Jim McGivney | Vista General | 3 | 04-28-2008 07:29 AM |
| Icons Size and Monitor Resolution | Kevin Gal | Vista General | 1 | 02-19-2008 04:29 PM |
| Monitor resolution | Drew | Vista General | 3 | 09-03-2007 04:06 PM |
| Monitor resolution | 1440 x 900 Resolution Problem | Vista hardware & devices | 2 | 04-06-2007 03:07 PM |
